» Sponsors
» Sponsors
Old 07-03-07, 05:16 PM   #1 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
DIY: G2 Manual Transmission service with pictures *5 & 6 speed*
Step 1. Raise the vehicle and properly align jack stands underneath vehicle. If you have access to a lift like I do, please use it.
Step 2. Locate the transmission fill and drain plugs as shown in this picture. This picture was taken from the rear of the car facing forward.
Step 3. Use a 3/8" ratchet and remove the drain bolt. About 2-3 quarts will come out, so make sure you use a container that can hold this much.
Step 4. While the fluid is draining, attach a 17mm socket to the end of the ratchet and remove the fill plug.
Step 5. Reinstall drain plug after all the fluid has drained and tighten it down.
Step 6. You can use many different types of pumps to get fluid back into the fill hole. You can pick these up from different parts stores for about $20. I use a Honda speed sensor with a couple hose attachments, and an air drill.
Whatever you use, you need to install 2.4 to 2.5 quarts of 10w-30 or 10w-40 engine oil back into the transmission. You will install oil into the fill hole until oil actually leaks back out of the fill hole, that's when you know it's full. If you're unsure, keep filling it up.
Step 7. When you're absolutely sure the oil in the transmission is full, reinstall the 17mm bolt and you're done.
I personally use a 50/50 mixture between Mobil 10w-30 and GM Synchromesh in my transmission for smoother shifting. You can test out a few different things, but do it at your own risk.
Mike Diaz is offline
Old 07-15-07, 11:17 PM   #2 (permalink)
Car 1: 1993 L Coupe
Car 2: 1989 Honda CRX
Send a message via AIM to The_Acid_Beaver Send a message via Yahoo to The_Acid_Beaver Send a message via Skype™ to The_Acid_Beaver
Take the fill off first, especially if you are on your back at night and don't have good tools to work with. This way, if you can't get the fill bolt out, you still have the fluid in the tranny.
I like the VSS trick.
Not so obvious and ruthlessly odd . . .
Yossarian Lives!
The_Acid_Beaver is offline
Old 07-16-07, 05:01 AM   #3 (permalink)
legend mechanic
What The Acid Beaver said.
And instead of using a pump, I used four feet of clear hoses with a funnel attached to it, and run it from the top of the engine bay to the fill hole. This made the filling process easier and cleaner, especially if you do not have a hoist.
the_invisible is offline
Old 07-30-07, 12:23 AM   #4 (permalink)
489,000 km's stil going
TO90LEGEND's Avatar
Car 1: 90 Legend V6L
Car 2: 93 Indy P/C Camaro
Car 3: 83 Trans AM
That's what I ended up doing as well. Thats also good advice above about the bolt. The quick lube people really crank them on. So you need some decent tools to get them off. (with extension pipe to make it easy) Mine let go with a big snapping sound.
TO90LEGEND is offline
Old 07-30-07, 08:24 AM   #5 (permalink)
That is true. The bolts are usually torqued down pretty good. Using a generic ratchet on these isn't recommended.
Old 05-18-08, 04:25 PM   #6 (permalink)
Car 1: Legend G2
This post has no picture; where's the fill hole? Is it also under the car? i looked everywhere by the engine, could not locate it.
ourytbtravel is offline
DIY Transmission Service (Filter + Drain) mrkeith DIYs 97 06-13-09 07:17 PM
Somebody asked for a manual transmission service DIY, here you go Mike Diaz Second Generation Legend (1991-1995) 1 07-03-07 08:55 PM
FOR SALE!! TYPE I MOTOR AND 5 SPEED MANUAL TRANSMISSION!! sleepinLegend Engine & Performance Modifications 3 06-12-06 07:37 PM
Ever heard of a 4 speed manual transmission? mondonalds Second Generation Legend (1991-1995) 30 06-06-06 10:15 PM
