Old 06-16-06, 02:50 PM   #1 (permalink)
Car 1: 92' White Sedan
Send a message via AIM to knucks3man
DIY: IAC Cleaning
First of all, this was due to the help of Mikey851.
Ok, now to the DIY:
Time: 20-40mins
Tools:
10mm socket
12mm socket (3/8 drive)
12mm open end
Throttle Body Cleaner (NOT Carb Cleaner)
Procedure:
1. Remove Air Intake
2. Remove Driver Side Valve Cover (2 10mm nuts)
3. Remove Clip from IAC, there is also another Clip shown that needs to be removed. Completely set these aside out of the way. *PicsBelow*
4. Locate the 2 Bolts holding the IAC in place.
5. Remove Bolts. For the Lower Bolt use a 12mm Open End. For Upper Bolt, use 3/8 drive 12mm Socket.
6. Pull IAC away from throttle body to expose the passages. *keep in mind the 2 coolant hoses attached, to not break or puncture them.*
7. Spray Cleaner and let sit for 4-8 hours. Clean out, and do reverse for install.
Hope this helps anyone needed to do this.
knucks3man is offline
Old 06-16-06, 02:52 PM   #2 (permalink)
XclusivLegend's Avatar
Car 1: 92 Legend (Phantom Grey Pearl) Sedan
sorry... i'm a noob... why is this good?
XclusivLegend is offline
Old 06-16-06, 02:55 PM   #3 (permalink)
If your car has trouble idling, stalling on hot starts, this could be your problem.
The passage gets clogged with carbon over time, and thus does not allow air to flow while idling, creating the stalling. Cleaning will solve the problem, in most cases.
Old 06-16-06, 07:16 PM   #4 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
Car 2: 94 Acura Legend L
After spraying, I used lots of Q-tips dipped in TB cleaner to clean both the IAC as well as the holes in the intake manifold. While I'm not sure how effective the q-tips were but it was kind of theraputic
-g
2002 Audi S4
S4gunn is offline
Old 10-03-06, 01:03 PM   #5 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
can we move this to the DIY section
~Alex
94 GS
Alperovich is offline
Old 10-03-06, 02:23 PM   #6 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
Sure I can
Mike Diaz is offline
Old 10-03-06, 03:27 PM   #7 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Thanx Mike! Glad to have ya back here with us
~Alex
94 GS
Old 10-03-06, 10:20 PM   #8 (permalink)
.The.Laos.Guy.
noudles's Avatar
Car 1: 1993 Acura Legend
Send a message via AIM to noudles Send a message via Yahoo to noudles
great DIY definitely doin this.. i need it
Legends of North Carolina
1993 Acura Legend L [SOLD]
2002 Lexus IS 300 [current driver]
noudles is offline
Old 10-04-06, 12:21 AM   #9 (permalink)
Aguy
guyad's Avatar
Car 1: 92 LS coupe 5spd
Car 2: 04 Silverado Z71
Send a message via AIM to guyad Send a message via Yahoo to guyad
So chances are if the RPMs on my car sometimes bounce up and down and drop randomly and sometimes stalls then most likely a Throttle body cleaning is all i need?
guyad is offline
Old 10-04-06, 12:29 AM   #10 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Your white coupe still has a Type 1 ecu, that may be affecting things as well. My idle was a little funny with my AC on occasionally, when I finally got a Type 2 ecu I had no more problems.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is online now
Old 10-04-06, 12:38 AM   #11 (permalink)
Aguy
guyad's Avatar
So how expensive is it to get a type II ECU and have it put in?
guyad is offline
Old 10-04-06, 05:13 PM   #12 (permalink)
Huh, chicken? GET HIM!!!
AckRite's Avatar
Car 1: 1991 3.5 Ack Legend Ls Coupe 5spd
Car 2: 1997 Sunfire
Send a message via AIM to AckRite Send a message via Skype™ to AckRite
Yo Henry (Dinero19) this one is for you! Nice write up too!
http://www.speedtest.net/result/216434638.png
AckRite is offline
Old 10-04-06, 09:16 PM   #13 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
you should talk with telion he should be able to help you out.
~Alex
94 GS
Old 10-08-06, 05:08 PM   #14 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
man these bolts are a pain in the ass... especially not removing the MLS bar
**Anti Alpine Type-R Thread**
bl420 is offline
Old 10-08-06, 07:50 PM   #15 (permalink)
'hood Garage
hotlavaflow's Avatar
Car 2: KA24DE-T S13
I'm gonna try this tomorrow morning, my idle is too high right now. I'm afraid to say.... it's 1700rpm. I have to check the vacuum system too.
DO NOT FEED THE ANIMALS
hotlavaflow is offline
DIY: Intake Manifold Removal and EGR Cleaning petthepeep First Generation RL (1996-2004) 15 04-16-08 11:29 PM
Acura-Legend.com/Acura-RL.com needs your help with making an official archive Mike Diaz Second Generation Legend (1991-1995) 23 01-11-08 01:58 AM
cleaning the iac JASON B Second Generation Legend (1991-1995) 35 04-11-06 11:14 PM
EGR valve cleaning DIY? Coderb64 Second Generation Legend (1991-1995) 3 06-12-05 04:38 AM
G1 cleaning front drainholes DIY Ken First Generation Legend (1986-1990) 3 01-12-04 07:45 AM
For advertising information, please visit our AutoForums.com website and Conta
