I'm the Stig!
DIY: Installing/Adjusting Blackend Motorsports Engine Damper
DIY Installing & Adjusting Blackend Motorsports Engine Damper Installation Required Tool list
Before beginning Ensure the car has warmed down as componants will be very hot and you can burn yourself. Step 1 Remove strut bar using the 12mm socket, remove all 5 bolts and 1 nut holding the strut bar in place. ![]() ![]() ![]() ![]() Step 2 Remove driverside strut bar brace ![]() using the 3/8" 12mm to remove the lower bolt and 1/4" 12mm with extension to remove upper bolt. take caution not to drop bolts, however they will not be reused. Step 3 Installing the new bracket. place the bracket with 2 bolt holes in front of the bracket you just removed, to make a U shape ![]() Then using the two 8mm (1/2" head) screws, ![]() tighten the brackets back into place ![]() Step 4 Installing Last bracket onto engine hook ![]() place the bolt thru the bracket with bolt head on the bend side. Manuals ONLY Using a 10mm socket/wrench remove bolt holding the clutch line in place. ![]() Step 5 Install bracket onto the engine hook with the bend facing towards the firewall. Place the washer between the engine hook and nut ![]() Using two 17mm wrenches tighten into place. ![]() You want to keep the bracket as low as possible Manuals only Tighten the 10mm bolt back on Step 6 Installing damper ![]() place the damper on top of the two brackets. Then insert the bolt from the bottom with a washer, thru the bracket and damper heim joint. Secure by hand tightening the nut on. ![]() tighten down using either 2 17mm wrenches Step 7 reinstall strut bar. ![]() ![]() Your DONE enjoy your new damper! Adjusting ****UNDER CONSTRUCTION***** ![]() disclaimers: PLEASE be sure to read the instructions provided by Blackend Motorsports fully. Use this only as a guide. Blackend motorsports nor I am responsible for damage to damper or vehicle due to improper installation. If you are not confident you can install the engine damper kit yourself, please pay a professional to do it for you. Brian if there is any corrections or anything else you would like to add, please be my guest and let me know i'll change it in the DIY. Last edited by Alperovich : 06-15-07 at 05:36 PM. |
Yo pedo en su dirección.
nice DIY! I was gonna video the whole thing, but now I may not bother.
1995 Acura Legend LS Coupe 6 speed NSX seats - JDM Headlights - OEM Fogs - MLS Copy strut bar - Legend specific Tie bars - Addco F&R Sways - KSport suspension - Sr5Guy Stage 2 Chip - RangerJoe Short shifter - Aluminum Pulleys - Injen intake - Stromung 2.5 inch cat-back - S2000 Battery Coming soon to a theater near you... 2005 RL BBK - Upgraded Final drive and LSD - Custom header - Cams - adjustable ball joints - adjustable end links |
Just Another Guy
Well written right up. Along with Blackend's instructions noone should have any problem.
-Ed
Custom CAI - sr5guy stage II chip - EGR Block - TB Bypass - Blackend's Damper - Custom 2" Y Pipe - Magnaflow Cat - 2.5" B Pipe - Type II IM - Labrat Crank Pulley - NA1 NSX Rims - ME 6000k HID. 14.99 @ 94.12 before manifold, pulley, & rims. |
Great stuff Alex! The only thing you need to change is the title of the DIY...
#7 (permalink) | |
I'm the Stig!
mods, can we move this to the DIY sections, and can u rename it? i changed it but the front page still shows it as b4 |
DV8 said that he had to lengthen his fuel line, does everyone with a sedan have to do the same?
Toronto Sprint Meet Photos http://www.acura-legend.com/vbulleti...6/#post1277655 Looking for Coupe Front Speaker Covers PM me if you got 'em! |
Just Another Guy
Coming from Ingalls website(damper looks similar):
http://www.ingallseng.com/parts/ETD/ETD-Specs.htm Greatly improved off-the-line acceleration Reduced wheel hop Improved vehicle stability Reduced shock loads on driveline components Smoother shifting Reduced wear on exhaust system joints Less vibration transmission to the driver compared to polyurethane motor mounts. Less shock load, compared to torque straps and chains. Drifting – helps reduce shock loads when wheels gain traction. Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
#12 (permalink) | |
CAN U SAY FUGLY?
Car 1: 91 LS Black window trim EDM/Hids Remus 2 1/2 cat back Headers stage 3 ecu Car 2: ,Red tails, Type 2 Car 3: 6 speed, EDM spoiler iTrader: (35)
Some patients side effects, (although minimal). Bloody stool mild to severe menstual cramps, (females only) heart palpitations slight rise in blood pressure boner lasting for more than 4 hours painfull ejaculation. These side effects although mild and rare, are not expected to cause any lasting symptoms! ![]()
TO BLEED AIR FROM COOLANT, CLICK HERE: http://www.acura-legend.com/vbulletin/883766-post7.html 91 with type II engine, 6 speed tranny, EDM headlights, EDM spoiler, carbon fiber interior trim, type II cluster, OBX headers, 2 1/2" Catback to Remus Rev 3, CAI. |
"the Don"
You forgot all the torque specifications for each and every bolt!
#15 (permalink) |
Hey Alex - I just realized that the instructions for tightening up the preload are wrong. The nut right up against the damper body is actually the jam nut for the preload which is the 2nd nut from the damper body.
You have to loosen the 1st big nut and then the preload will go into the body by tightening, or out of the body by loosining. Then tighten down the big nut to lock the preload down. The 3rd nut away from the damper body is the jam nut for the length of the damper. |
