Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
DIY lhd folding mirrior switch.
Ok 1st of all i have to give thanks to V.A. who showed me this and a few other diys.
ok you will need bothe mirrior control switch. trace out the folding switch then using a drimel out the hole.
next pic up a toggle switch the push button kind. it needs to be small so that the switch can fit on it. drill the hole in the usdm switch place the toggle switch in it and bolt it down and drill a smaller hole for the wires to run out of. it should look like this.
now some modding may have to be done to the folding mirrior button like in the pic notice the bottom of the switch was trimmed.
no when its done it should look like this.
Now run the wires to the relay.
Originally Posted by Blackend
i will revised this with a better right up soon this was made in a rush for a fourm member.
first off, thanks for this write up, pretty much explains how to do it...my only question is to what wires on the relay do you splice these 2 wires from the button?
here you go
i have a question...im using a relay from the prelude...7 wire as well and i read you could use the lude relay if you dont have the legend relay...my question is can i connect the yellow & white wire from the relay to the yellow & white wire from the switch? can i do the same with the black wire from the relay and connect it to the black wire on the switch?...oh and does the rest of the wiring to the mirrors and switch look good? im hopefully planning on doing this on Sunday so we'll see how it all goes. thx
the yellow wire with the ??? should go to a 12v power source.
Originally Posted by arrozburner
so could i just splice into the the yellow/white wire coming from the harness on the car?
im not sure as i have the legend relay but i dont see why not
well i finally finished wiring up the mirrors and got them to work properly...just incase anyone needs it, this is how i wired up my mirrors with the oem 7-wire relay and with the push-button switch mod...hope it helps
thanks for adding this and im glad you have them fixed.
__________________ EDM '95 TCS Coupe with USDM Mod's (Trunk Lid/Taillights/Cupholder/Audio Switch/Bose EQ) rolling on 225/45/17 Tires Acura | Honda V6 Forum / Photo Gallery
English isn't my 1st language. So please consider it by way of apology of my bad grammars! Thank you.
To my Friend FUT who I unfortunately never met in person. Rest in peace, you will not be forgotten.
