Old 06-07-06, 04:13 PM   #16 (permalink)
KJLegend's Avatar
Car 1: 1995 Acura Legend LS Sdn. Blk on Blk
Send a message via AIM to KJLegend
is that diagram up top wrong or am i just dumb?!!? I have it perfect and it does not sound that way when you read the instructions written out...please help!
KJLegend is offline
Old 06-07-06, 11:17 PM   #17 (permalink)
KJLegend's Avatar
ok i figured it out...and that is totally wrong on that diagram! dont follow that diagram it does not work right. you have to cross wires in order to use it, and it still wont work. Use 1 relay per headlight and hook them up seperately! and follow the typed instructions above! Thank you Train for the help and no thanks mike diaz for your diagram, its all good it just wasted like 4 hours of my time and 20 dollars in wires but oh well.
KJLegend is offline
Old 06-08-06, 12:56 AM   #18 (permalink)
Fran's Avatar
Car 1: 95 Legend GS Blk/Type F
Send a message via AIM to Fran
So you only need one relay for each headlight? What did you do with the fogs?
Fran is offline
Old 06-10-06, 12:54 AM   #19 (permalink)
KJLegend's Avatar
I hooked them up to a seperate switch inside the car, and connected them together w/o a relay, just power then ground the other wire. It was simple I would rather have the option of having the fogs on or off at any time i want instead of having them on when the headlights are on, I dk it worked out better for me this way i dont know about you. But when you hook your lights up for the highs and low dont use the diagram up top it wont work right...any questions PM me I did that crap 3 different ways so im a pro by now..,
KJLegend is offline
Old 10-24-06, 11:36 PM   #20 (permalink)
Prez of ACURA-HOLIKS
L3GDKANG/JDM-KANG's Avatar
Car 1: 91 Sedan sprite green
Car 2: 92 LS coupe
Car 3: 93&94 LS sedans
Send a message via Yahoo to L3GDKANG/JDM-KANG
whatever happend to the wire diagram pics for this post?
L3GDKANG/JDM-KANG is offline
Old 10-25-06, 08:47 AM   #21 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
Not sure. It's definitely not being hosted anymore. Let me find the pic.
Mike Diaz is offline
Old 10-25-06, 10:03 AM   #22 (permalink)
Car 2: 92 LS coupe
thanks mike!
Old 11-11-06, 05:30 PM   #23 (permalink)
94 6MT KA7_8
VDM GS's Avatar
here's a diagram of how i wired up my JDMs (thanks to train for his info), as u can tell this is the correct method to wire the highs and lows so one or the other is switched on (not both), if u're unsure about which USDM wire is which, just connect them to the relays and u'll find out if u got it right when u switch ur lights on.. hope this helps:
DIYs: Bumper Lights MOD - Rebasing 9006s for JDMs - JDM 1-Piece Install
BHG Survivor. Overheating? Combustion leak tester sold @ www.rxauto.com
VDM GS is offline
Old 11-11-06, 05:33 PM   #24 (permalink)
94 6MT KA7_8
VDM GS's Avatar
as u can tell u wired it up so the FOGS turn on when the parking lights turn on, (so i dont forget to turn off my fogs, unless i forget to turn off my lights!) and you can opt to install a switch where i pointed out. the other method is to wire up a switch to the 86 and 85 terminals and switch the FOGS on urself every time.
VDM GS is offline
Old 11-11-06, 07:52 PM   #25 (permalink)
Car 2: 92 LS coupe
thanks alot!
Old 11-13-06, 04:09 AM   #26 (permalink)
EDM KA8 owner
lgnd's Avatar
Car 1: EDM KA8 '91
Car 2: EDM KA8 '91 RIP
lgnd is offline
Old 11-13-06, 09:29 PM   #27 (permalink)
THE BROOKLYN DON
Drizzle359's Avatar
Car 1: 92 conversion to 95
DO The h4h Bulbs come in the Hid Conversions Kits?
Drizzle359 is offline
Old 11-18-06, 07:41 AM   #28 (permalink)
94 6MT KA7_8
VDM GS's Avatar
if u find hid conversion kits specifically for H4H like the one below then yes
http://cgi.ebay.com/ebaymotors/JDM-JAPAN-NEW-H4H-6000K-8000K-HID-Conversion-Kit_W0QQcmdZViewItemQQcategoryZ36476QQihZ010QQitem Z200047912420QQrdZ1QQsspagenameZWDVW
VDM GS is offline
Old 11-28-06, 12:29 AM   #29 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
hey mike how come in the diagram it says constant on on the parking light wire?? and could i just splice into all the wires before the usdm harnesses so i can just get back to stock later for safety check..sorry about all the questions. and i dont think the HID kit listed above has both high and low function. but only glanced so correct me if im wrong. jdm should be coming in tomorrow. Great DIY
dgandul is offline
Old 11-28-06, 09:13 PM   #30 (permalink)
The Sicilian
MrPeacock72's Avatar
Car 1: 91 L Sedan (wrecked)
Car 2: 03 3.2 TL
Car 3: 91 Escort
Send a message via AIM to MrPeacock72 Send a message via Yahoo to MrPeacock72 Send a message via Skype™ to MrPeacock72
I hope the mods don't mind me adding some additional info to this thread. I figured it would be helpful to someone. I wasn't aware this was even a possibility. I took this from a thread that I started.
Originally Posted by mrpeacock72 View Post
WORD TO THE WISE: If you ever plan on doing the mod yourself, do not buy your relays from Oreilly's Autoparts. Although they are 5-pin SPDT relays (Single Pole, Double Throw), they are NOT the correct ones that you need. The correct ones have pins for 30, 85, 86, 87, and 87a. The relays from Oreily's are 30, 85, 86, 87, and 87. That "a" makes a HUGE difference and I'll explain the difference below.
I'm 'bout to go into DYI mode:
When you send power (low beam from the car) to the 30, it should send it directly out the 87a (to the low beam wire on the JDM harness), which will be your default setting. And when you activate the high beam wire (from the car), power is sent to the relay coil 85 to shut the low beam filament off and activate the 87 high beam filament (the high beam wire on your JDM harness).
Oreilly's relays:
Since there is no 87a pin on the relay, and just two 87 pins, there is no low beam, or default setting. When you send power to their 85 relay coil, both filaments activate, since there are two 87 pins, prematurely burning up your bulbs and possibly your wiring. Basically, when you turn your lights on, you have no low beams at all, but you flick the switch and you have lows and highs coming on at the same time. That's not suppose to happen. You're only suppose to have one filament come on at a time.
It took me 3 days of anger, frustration, trial, and error to finally figure out that it wasn't my wiring that was wrong, it's just that I had bought 4 brand new pieces of "caca el toro." That's "bullsh*t" for those who don't speak Spanish. Your best bet is to get some Bosch or Bosch-style relays from ebay. and make sure you look for the 87a. I hope this helped or helps someone out so you have to endure what I endured. If you have any questions, feel free to PM me. Being that I'm somewhat of an expert at these things now, I may be able to help you out if you don't understand something.
Daryll
Daryll
THE BIONIC LEGEND
"1991 Acura Legend, sedan, a car barely alive.
Gentlemen, we can rebuild it, we have the technology.
We have the capability to make the worlds first Bionic Legend.
The Acura Legend will be that car. Better than it was before.
Better... Stronger... Faster..."
Antenna relay DIY
Forum rules
MrPeacock72 is offline
