#61 (permalink) |
Illegally Legal
A little bit off topic but my transmission has the hard shifts as well as some slippage. So I decided to disconnect the battery for a few minutes to reset the ECU. Voila, my car is not slipping anymore but still has hard shifts. Will still drop the pan when my order arrives though.
#62 (permalink) |
legend mechanic
With the pan off, I let the transmission drain overnight. A little more than 4liter drained out. I filled it back up with 3.6L of fluid. Transmission shifts smoother, 1st to 2nd shift is still rough, but much more tolerable. Car accelerates a lot smoother and quicker because of the new fluid and possibly because there's less drag on the tranny pump. I noticed that some of the slipping is gone. Shifting becomes much quicker as well. The most noticible difference is the shift between 2nd and 3rd. It's seamless.
#63 (permalink) |
legend mechanic
For my car, the filter replacement has completely eliminated the rough shift my car had. I let my transmission drip over night with the filter and pan removed. No amount of flushing improved my transmission rough shift problem. But the filter replacement eliminated it. The car also accelerated much smoother now too because the transmission pump operates smoother. Idle is also smoother when it is in the D4 position. The car feels like new again.
#67 (permalink) |
OK all you good guys, i want to know just how to check the trans fluid levels.
On mine the stick shows high fluid when motor not run, but none on stick when engine has been run...help...which is correct way to check... |
#68 (permalink) | |
#70 (permalink) | |
heres what i am doing this weekend, spark plugs, fuel filters, and tranny flush. taking my car to the mechanic to change the timing belt and the alternator belt. this could cost over $500. but since i got my tax stimules check, its all going for my legend. got $900 from the IRS ![]() |
#71 (permalink) |
Do a drain and refill. Do NOT perform a tranny power flush.
http://img294.imageshack.us/img294/8787/flyer2sb2.jpg Looking for 94/95 Trunk Emblem (The "A" ) Coupe Front Speakers PM me if you got 'em! |
#72 (permalink) |
what about the tranny filter?
Projects completed = may 12 ,08 - timing belt , altenator belt, steering belt, serpantine belt, Cam Gear. new radiator cap = $800 may 13 , 08 - . 4 Michelin tires = $300 next projects = fuel filter, spark plugs , water pump, dent repair, paint job, new front bumper, . will finish by 2009. later projects = new rims. |
| OEM Cabin Air Filter Replacement with NON Oem Filter | Mtnduey | DIYs | 23 | 12-17-07 10:41 AM |
| Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true | dreno74 | Second Generation Legend (1991-1995) | 14 | 02-04-05 02:59 PM |
| 6 Speed Fixer Upper | hondaman23 | Legend | 7 | 12-28-04 01:56 PM |
| FS: K&N High-Flow Air filter and filter service kit | Stu | OEM Parts | 17 | 02-28-04 11:23 PM |
| Added larger filter and converted to diy CAI the Legend has responded very well..... | 97SE | Engine & Performance Modifications | 4 | 05-13-03 01:43 AM |
