Old 04-19-07, 08:27 PM   #61 (permalink)
Illegally Legal
Car 1: 1992 Acura Legend L Sedan
A little bit off topic but my transmission has the hard shifts as well as some slippage. So I decided to disconnect the battery for a few minutes to reset the ECU. Voila, my car is not slipping anymore but still has hard shifts. Will still drop the pan when my order arrives though.
MidgetWarrior is offline
Old 04-20-07, 09:15 PM   #62 (permalink)
legend mechanic
With the pan off, I let the transmission drain overnight. A little more than 4liter drained out. I filled it back up with 3.6L of fluid. Transmission shifts smoother, 1st to 2nd shift is still rough, but much more tolerable. Car accelerates a lot smoother and quicker because of the new fluid and possibly because there's less drag on the tranny pump. I noticed that some of the slipping is gone. Shifting becomes much quicker as well. The most noticible difference is the shift between 2nd and 3rd. It's seamless.
the_invisible is offline
Old 05-08-07, 02:19 AM   #63 (permalink)
legend mechanic
For my car, the filter replacement has completely eliminated the rough shift my car had. I let my transmission drip over night with the filter and pan removed. No amount of flushing improved my transmission rough shift problem. But the filter replacement eliminated it. The car also accelerated much smoother now too because the transmission pump operates smoother. Idle is also smoother when it is in the D4 position. The car feels like new again.
Old 05-08-07, 07:22 PM   #64 (permalink)
Car 1: 1990 Legend Sedan L
Car 2: 95 Land Rover Disco
i kinda read fast, so pardon if i missed anything.
how long did this take you? and about how long would someone who has never done it take? (since you said you do it almost every oil change)
Tubabusters to the rescue!
tubadude is offline
Old 05-09-07, 08:40 PM   #65 (permalink)
legend mechanic
I could have done it in under an hour. But because I was given the wrong pan gasket, I took an extra day which I left the transmission to drip. The key is to remove the filter to drain the dirty fluid out.
Old 09-12-07, 11:10 AM   #66 (permalink)
Car 1: LS400
Car 2: Accord EX
Car 3: 91 Legend
Can you just use the liquid gasket?
1Alegend is offline
Old 09-26-07, 04:54 PM   #67 (permalink)
Car 1: legend 92 model 4 door
Car 2: BMW325i touring auto
Car 3: Aprillia 172cc tuned
OK all you good guys, i want to know just how to check the trans fluid levels.
On mine the stick shows high fluid when motor not run, but none on stick when engine has been run...help...which is correct way to check...
banger290 is offline
Old 04-05-08, 01:45 AM   #68 (permalink)
Bushido95Legend's Avatar
Car 1: 1995 Acura Legend LS
Originally Posted by mrkeith View Post
Crawl underneath your Legend and locate the transmisision pan.
It is directly in front of the y-pipe, behind the oil and differential pan.
Position a bucket on the ground to catch the flow.
Stick your ratchet into the drain plug (on the passenger's side)
and crank it loose. Allow the fluid to completely drain, then screw
the plug back in the pan after wiping any debris from it.
Now let's unscrew the pan. Fourteen (14) screws hold the pan in place.
You can safely unscrew all of them because the pan is fairly secured
in place by two snap pins. Be sure not to lose the snap pins!
say i dont want to replace the filter, and i just want drain and refill. will it still be a good idea to not replace the filter until my next tune up ? right now i am tight on budget, really tight. but i might have enough for the honda ATF.
Bushido95Legend is offline
Old 04-13-08, 11:51 AM   #69 (permalink)
1992IAMLEGEND's Avatar
Car 1: 1988 Nissan 300ZX
Car 2: 1992 Acura Legend LS
It's all 10MM except for the drain plug... 3/8 rachet will remove that...
Originally Posted by tofusensei View Post
its been a while, but i want to say the ones that hold the pan on are 12mm. and the ones holding the filter on are 10's. good luck
~t.s.
1992IAMLEGEND is offline
Old 05-09-08, 12:58 AM   #70 (permalink)
Originally Posted by Kenso View Post
The filter is around $38. It is item #1 in this link.
Trans filter
ah man, you mean i cant buy the filter at a local car store? like autozone? kragen? pep boys?
heres what i am doing this weekend, spark plugs, fuel filters, and tranny flush.
taking my car to the mechanic to change the timing belt and the alternator belt. this could cost over $500. but since i got my tax stimules check, its all going for my legend. got $900 from the IRS
Old 05-09-08, 04:25 PM   #71 (permalink)
TonyTheBullet's Avatar
Car 1: 1992 Legend LS Sedan
Car 2: 1993 Legend LS Coupe
Do a drain and refill. Do NOT perform a tranny power flush.
Toronto Sprint Meet Photos
http://www.acura-legend.com/vbulleti...6/#post1277655
PM me if you got 'em!
TonyTheBullet is offline
Old 05-14-08, 01:36 AM   #72 (permalink)
what about the tranny filter?
Projects completed =
may 12 ,08 - timing belt , altenator belt, steering belt, serpantine belt, Cam Gear. new radiator cap = $800
may 13 , 08 - . 4 Michelin tires = $300...may 18. 08 fuel filter = $18.34...may 23,08 new drive axel and steering boot = $220. 05-24-08 sparkplug, atf drain & fill.
next projects = , water pump, dent repair, paint job, new front bumper, new rims, new carpet, altenator.
Old 05-21-08, 10:48 AM   #73 (permalink)
I think the dealer is the best bet for the tranny filter/strainer. I haven't found one at the local part stores.
One dealer told me that the strainer is not replaceable unless you are rebuilding the tranny, so I walked out without arguing further.
You need P/N 25420-PY4-000 (strainer, #1 in pic) and 91308-PA9-003 (O-Ring, #21 in pic).
Old 05-24-08, 03:36 PM   #74 (permalink)
is chevron ATF MD-3. is that good for acura ??? thats what the guy at kragen recommend me when i cant find a honda ATF.
Old 05-24-08, 11:49 PM   #75 (permalink)
fuzzy2k3's Avatar
which way does the trans. plug (bolt) open? I tried anti-clockwise (looking right at it) and the thing would not budge, I even sprayed WD-40 and still nothing? While Im on the topic, Doing my own oil change for the first time, i couldnt get the oil pan bolt of either, looks like its smoothed out, does that open anti-clockwise as well?
Ive done oil change on my corolla and its always anti-clockwise
fuzzy2k3 is offline
OEM Cabin Air Filter Replacement with NON Oem Filter Mtnduey DIYs 23 12-17-07 10:41 AM
Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true dreno74 Second Generation Legend (1991-1995) 14 02-04-05 02:59 PM
6 Speed Fixer Upper hondaman23 Legend 7 12-28-04 01:56 PM
FS: K&N High-Flow Air filter and filter service kit TB4USpk OEM Parts 17 02-28-04 11:23 PM
Added larger filter and converted to diy CAI the Legend has responded very well..... 97SE Engine & Performance Modifications 4 05-13-03 01:43 AM
