dealer-opted track pack
I do not care about your 56k modem. If you drive a nice Legend, then you should be able to afford a modern internet connection. Many of you may encounter trouble understanding my English because I write clearly. That too is your problem, not mine. I cannot be held responsible for your negligence. If you screw up your transmission, do not blame me. Safety is key. Ensure that your Legend is properly lifted with the e-brake tight, weel wedges in place, etc. Crawl underneath your Legend and locate the transmisision pan. It is directly in front of the y-pipe, behind the oil and differential pan. Position a bucket on the ground to catch the flow. Stick your ratchet into the drain plug (on the passenger's side) and crank it loose. Allow the fluid to completely drain, then screw the plug back in the pan after wiping any debris from it. Now let's unscrew the pan. Fourteen (14) screws hold the pan in place. You can safely unscrew all of them because the pan is fairly secured in place by two snap pins. Be sure not to lose the snap pins! The fourteen screws: A transmission pan snap pin: The transmission pan is removed (the filter is visible on the right): The transmission filter is held in by an additional three (3) screws. Remove them and pull out the filter. Following is the used filter juxtaposed the new one: There were few metal shavings caught in mine: Following is the new filter: Before reinserting the new filter, make sure to affix the circular gasket on the filter's top! Remove the old gasket from your oil pan. You may have to shave off stubborn pieces with a sand block. The pan's surface to remount the new gasket should be perfectly flat. Clean out your oil pan with a cloth if necessary. I drain and fill my transmission almost every oil change, so my pan did not require scrubbing ![]() Your mileage may vary. Place the snap screws in the pan and fit your new gasket around them. (the snap screws are not depicted below) Snap the pan back onto the transmission and screw everything back together. Finally, you should be able to replace 3.5 quarts of Honda ATF. (trust me; use Honda) I drafted this write-up rather quickly. There may be mistakes. Please post any further questions that you may have. I will try my best to answer them. Good Luck, k.h.
(my Legend) ![]() If you've got coil-overs, corner-balance them. Please protect our environment: use a high-flow. Last edited by mrkeith : 02-04-06 at 04:19 PM. |
You photos of the filter appear to of a filter and not an OEM screen. What you need to add is that if you replace an OEM screen with a filter you shall have to replace that filter every 3 years or so depending upon mileage driven.
If a Legned owner wished to perform a screen replacement once just to inspect for any large shavings, this one time replacement of an OEM screen should suffice.
After reading your response a few times over,
I think you are claiming that my replacement filter is of a lesser quality than the OEM one. I doubt that is the case because both parts seemed to be exactly the same from visual inspection. If there is any difference, it would be within the internals of that flat region. Both parts are screens if you want to get technical. Neither part has a paper filter, like you might be thinking. k.h.
(my Legend) ![]() If you've got coil-overs, corner-balance them. Please protect our environment: use a high-flow. |
Nice writeup! I talked to you about changing fluids on my car awhile ago. After this DIY, I am aware that I should change the filter also. Its about time I change it since my tranny shifts pretty hard.
And if anyone has ever been in his car and wonders why there is no 1st to 2nd hard shift, the answer is above. He keeps his car clean (no pun intended )
1992 Acura Legend LS sedan |
#5 (permalink) | |
By removing the OEM screen and substituting an aftermarket trans filter, you are creating more maintenance for yourself. If the OEM screen has a larger mesh than the filter the filter will occlude faster and thus require fairly frequent (3/30k) replacement. I believe that there was some wisdom in Acura installing a screen and a magnetic drain bolt. Replacing the screen with the filter may limit easy inspection of amt of particulate (or shavings) due to normal or abnormal wear. What would be deposited upon the magnetic drain bolt is now trapped by the filter. I would only do this inspection/screen (not filter) replacement 1x on a vehicle having over 50k, and not knowing its history. Just to rule out shavings. If I remember correctly, didn't someone post cleaning a screen and just reinstalling??
Eyebrows KMS Strut Bar Enkei 16" J-Lips Wings West Spoiler w/LED Clear Corner Lens Clear Bumper Lens Clear Rear Side Markers Brembo X-Drilled/Slotted Stainless Braided Brake Hoses Focus 2500 Driving Lamps Gold Pkg Last edited by LPB : 05-07-05 at 02:23 PM. |
Thank you for the compliment GSteg
![]() In fact, my transmissions shifts hella smoother now that the filter was replaced. I am serious about the parts being exactly the same, though. The OEM screen look to-the-t of the aftermarket one. See for your self in the pictures. Both screens were thinish. I suppose one could clean off their OEM screen, but why? Just replace the entire screen and gaskets, too. I am beginning to think that this whole argument not to replace the screen stems from cheapness. k.h.
(my Legend) ![]() If you've got coil-overs, corner-balance them. Please protect our environment: use a high-flow. Last edited by mrkeith : 05-07-05 at 04:20 PM. |
GSteg--You may want to try Gill's 3x drain and fill before cleaning out the pan.
I tried that on my other coupe and it worked like a miracle. k.h.
There was not much sludge in my transmission
because I drain and fill it nearly every oil change. I don't recall where the filter was purchased. Search google.com. k.h.
#15 (permalink) |
Post or AIM me if you have any further questions.
After replacing the filter screen and performing the drain and fill a few times, you will have one of the happiest shifting Legends on Earth ![]() Thank you for the kind remarks, guys. Cheers, k.h.
| OEM Cabin Air Filter Replacement with NON Oem Filter | Mtnduey | DIYs | 23 | 12-17-07 10:41 AM |
| Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true | dreno74 | Second Generation Legend (1991-1995) | 14 | 02-04-05 02:59 PM |
| 6 Speed Fixer Upper | hondaman23 | Legend | 7 | 12-28-04 01:56 PM |
| FS: K&N High-Flow Air filter and filter service kit | Stu | OEM Parts | 17 | 02-28-04 11:23 PM |
| Added larger filter and converted to diy CAI the Legend has responded very well..... | 97SE | Engine & Performance Modifications | 4 | 05-13-03 01:43 AM |
