#31 (permalink) |
i did this tranny service a few weekends ago......its does wonders to the AT. it shifts so much smoother now.
tofusensei - yes that is just a magnet that collects the metal shavings....mine was COVERED, yes all that stuff that is in that filter is the stuff you dont want in there, so yest that is a sign of needing the new filter. Im not sure what you are refering to on the last picture, but everything seems to look right.
The Performance Handling Sedan Ksport Coilovers, MLS strut bar, Fut's rear tie bars, ADDCO rear sway bar MAY 10TH CHARLOTTE NC LEGEND MEET! CLICK HERE Winter NC meet picture and discussion thread! |
#32 (permalink) |
dealer-opted track pack
Awesome! I love to read that the DIY helped.
#33 (permalink) |
in that last pic its all gooey white junk, i guess thats wut ur referring to as sludge?newayz damnittttttt i ordered my parts for this on monday and entered wrong expiration date.re ordered now mite not get till next week.bummer.-keith, i wonder how many trani's u saved with this.from the replies it looks like this really helps it shift smoother.cant wait!!
~t.s.
legend parts fs: stock springs/shocks, jdm fenders and more!!... http://www.acura-legend.com/vbulleti...ad.php?t=79147 wireless g adapters -- http://www.acura-legend.com/vbulleti...066#post911066 |
#34 (permalink) |
I talked to my parts dealer and he said theres no need to replace your transmission filter unless your doing major repairs, He said Acura is the only one he knows that says the filters r good for the life of the car thats why they have A lot of detergents in there tranny fluid....
#35 (permalink) |
when i did mine there was a whole lot of little metal peices in the filter, so replacing it will no doubt make the filtration better. also when you take the pan off of the bottom of the tranny, the drain plug and another magnet in there will be COVERED in goo which is actually metal shavings. So by cleaning these two things off more metal will be pulled out of the fluid in the future(making your transmission last longer).
#36 (permalink) |
I just scored this 90 Legend L. It has 108k miles. I don't know anything about its maintenance history. I read some posts on this forum saying that I shouldn't change tranny fluid if it hasn't been routinely changed every 30k miles or something along those lines.
I'm not sure if I should do this DIY. I do notice that my car shifts hard, and it stays in gear a bit longer than it should. Well thanks, and nice informative DIY. |
#37 (permalink) |
any thoughts?
Should I do a change or not? Lately I noticed a few more things about the transmission. When I gun it sometimes, and it passes the redline, it kinda gets stuck at around 7000 rpm. It sounds like it wants to shift, or needs to shift, but it isn't shifting and so it stays there until I let off the pedal.
so cmon man? ne body gonna tell me if i should change it or not? any advice could be help full. |
#38 (permalink) |
OK!! so i finally got my parts today and wasted no time installing them. i even had the car jacked up waiting for the UPS guy to come. id say it took a good hour for the change including a thorough cleaning of the pan, and magnet. as far as results...SO FAR i am very pleased with the shifting but i can only hope itll stay this smooth and is not temporary.i say this because it seemed about this smooth on my last transmission after the one and only fluid change i performed on it. then after about 2 months a lot of good that did the trani was gone. SO FAR THOUGH YES IT IS WORTHWHILE!! heres some pics/part numbers...
O-ring gasket ![]() oil pan gasket ![]() and the infamous transmission filter ![]() --victor as for ur trani shifts.for one thing unless u have a manual (which u dont) it shudnt be shifting PASSED the redline like u mentioned.) this seems like a big problem to me.1)u could either check the color of the dipstick to see wut color the fluid is.(shud be pinkish/red)if its other than u at least need to change the fluid.2)if u havent noticed already this DIY is for 91-95 models so it mite not even have a filter(chances are it does).good luck tho if u so decide to do this filter change! AGEN SHOUTOUTS TO KEITH FOR MAKING THIS POSSIBLE FOR EVERYONE, YOURE THE BEST!! ~t.s.
legend parts fs: stock springs/shocks, jdm fenders and more!!... http://www.acura-legend.com/vbulleti...ad.php?t=79147 wireless g adapters -- http://www.acura-legend.com/vbulleti...066#post911066 Last edited by tofusensei : 04-25-06 at 09:06 PM. |
#39 (permalink) | |
Spiral descent
#41 (permalink) | |
#42 (permalink) |
$58.81 shipped. the only thing i wasnt happy with was it took 2 weeks + to receive it.
~t.s.
#43 (permalink) | |
#45 (permalink) | |
~t.s.
| OEM Cabin Air Filter Replacement with NON Oem Filter | Mtnduey | DIYs | 23 | 12-17-07 10:41 AM |
| Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true | dreno74 | Second Generation Legend (1991-1995) | 14 | 02-04-05 02:59 PM |
| 6 Speed Fixer Upper | hondaman23 | Legend | 7 | 12-28-04 01:56 PM |
| FS: K&N High-Flow Air filter and filter service kit | Stu | OEM Parts | 17 | 02-28-04 11:23 PM |
| Added larger filter and converted to diy CAI the Legend has responded very well..... | 97SE | Engine & Performance Modifications | 4 | 05-13-03 01:43 AM |
