Old 06-05-06, 01:34 AM   #46 (permalink)
Car 1: 1992 acura legend
i went to my local acura delership and they orderd a thermostat gasket for me, ordered friday and got it monday morning.
bicball is offline
Old 06-11-06, 07:26 PM   #47 (permalink)
Car 1: '96 RL
I purchased a tranny kit for my RL from rockauto.com for $25. That included the filter o-ring, gasket, and filter. Great DIY, this combined with the 4x tranny flush is like having a brand new transmission. Props!!
petthepeep is offline
Old 11-20-06, 11:02 AM   #48 (permalink)
Car 1: legend
Does 99 RL has filter too?
eric-wsc is offline
Old 11-20-06, 03:07 PM   #49 (permalink)
chad's Avatar
Car 1: 91' J Sedan
Car 2: 93' Hatch
All automatics have tranny filters ^^^
So cheep filters hold up good, and so iam guessing and there no big reason to buy an oem screen/filter
chad is offline
Old 12-14-06, 11:01 AM   #50 (permalink)
Car 1: 1992 Acura Legend
I just drain and filled mine, I think I'll go 5-10k then do the whole nine. The car seems to shift a little smoother with the fresh fluid.
I did noticed the drain plug caked up with metal shavings that makes me a little nervous...
92 Acura Legend LS BHG 1-19-06, JDM swap 2-06
Mcculloch 5000k HID kit
Alpine IVA w200 w/30gb video ipod H701 processor
JL audio 300/4 and 500/1 amps
boston SL60 comps front and rear
JL Audio 12W7 sub
monster cable wiring/Optima yellow top battery
60_cent is offline
Old 01-04-07, 09:20 PM   #51 (permalink)
Meet my twin brother!
Type2Killa's Avatar
Car 1: "92 Acura Legend L Grey/Black
Car 2: 91LS Sedan 3.5'd!
Send a message via AIM to Type2Killa Send a message via Yahoo to Type2Killa
Are these bolts 10mm?
Im a legend DR.
Type2Killa is offline
Old 01-05-07, 03:34 AM   #52 (permalink)
Car 1: 91 legend coupe
Car 2: 92 legend coupe
Car 3: 93 legend coupe
Send a message via AIM to tofusensei Send a message via MSN to tofusensei
its been a while, but i want to say the ones that hold the pan on are 12mm. and the ones holding the filter on are 10's. good luck
~t.s.
legend parts fs: stock springs/shocks, jdm fenders and more!!... http://www.acura-legend.com/vbulleti...ad.php?t=79147
wireless g adapters -- http://www.acura-legend.com/vbulleti...066#post911066
tofusensei is offline
Old 01-16-07, 12:49 AM   #53 (permalink)
skatemack's Avatar
Car 1: 1993 Acura legend coupe type II six speed
Car 2: 1994 L sedan
Thanks for this post. It's very informative. My tranny is kinda slipping when it shifts from 3rd to 4th. A friend with a totally different car said that his did the same thing and when he had it serviced it went away. Has anyone had this problem?
skatemack is offline
Old 03-26-07, 10:51 PM   #54 (permalink)
Car 1: 94 LS
anyone know what part # the oil pan gasket is?
so far i have 91308-pa9-003 for the o-ring gasket and 25420-py4-000 for the transmission filter.
Klue is offline
Old 03-26-07, 11:25 PM   #55 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
21813-P5H-000 (95)
21813-PY4-000 (91-94)
Might be wise to confirm your part # via VIN #, the number may have been changed sometime during 94.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 03-30-07, 10:01 AM   #56 (permalink)
Illegally Legal
Car 1: 1992 Acura Legend L Sedan
Originally Posted by Kenso View Post
21813-P5H-000
Not sure if it makes a difference but that part reads as a 95 Legend. Looking up a 92 I get a different part number
MidgetWarrior is offline
Old 03-31-07, 11:15 PM   #57 (permalink)
legend mechanic
I just ordered the parts listed above for my 1994 Legend. It netted a little over $100 Canadian before tax.
I am suspecting my filter is very dirty because my car had be fine until it sat for two weeks during a head gasket replacement (preventative maintenance). I assumed the particles sunk to the bottom. After the head gasket repair, smoke came out of the fluid, possibly cauesd by a pump over working. Flushing solved the fluid over heating problem. All this was more than two years ago, during which the transmission had been flushed twice with a few drains every now and then. Shift shock is acceptable, but annoying. I hope the transmission filter will solve the problem.
the_invisible is offline
Old 04-01-07, 12:28 PM   #58 (permalink)
Kenso's Avatar
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Yeah it looks like there are 2 listed now that you mention it. P5H and PY4. It would be wise for people to check for themselves via their VIN numbers but it appears that 91-94 uses PY4 and 95 uses P5H.
Kenso is offline
Old 04-08-07, 04:49 PM   #59 (permalink)
swift's Avatar
Car 1: 92' legend coupe 5spd
Car 2: 94' coupe auto
Car 3: 91' Smacura
there is a trick to flushing your trans fluid...
after you drop pan and put new filter in and put new fluid in.
take of the trans line from the radiator cooler that leads back to trans start vehicle in park and hold line to an empty gallon jug and it will fill with the leftover old fluid...when you start seeing fresh red fluid of air shut car off and repeat another time after you fill it up again with new fluid. AFter second time hook line back up...fill up trans at idle in park and make sure at proper level.
good luck
swift is offline
Old 04-19-07, 08:11 PM   #60 (permalink)
legend mechanic
I dropped the transmission oil pan today. There is not a speck of metal debris inside the transmission or on the drain plug. The transmission is immaculate inside and the transmission fluid is clean. I flush the transmission once a year and the last time I flushed it was 8 months ago. The filter seems a little dirty, but the fluid is clean. No debris whatsoever.
Now I am not sure if changing the filter will solve my 1st-2nd rough shifting problem considering my transmission is clean, with no sign of excessive wear. The filter itself is old, but not clogged to the point it will affect shifting.
The dealer has given me the wrong oil pan gasket, so I am leaving my transmission to drip from the valvebody for a couple of days. This should allow me to fill more new fluid into the transmission. I hope by changing the filter and draining the fluid, the rough shifting will be fixed somewhat.
OEM Cabin Air Filter Replacement with NON Oem Filter Mtnduey DIYs 23 12-17-07 10:41 AM
Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true dreno74 Second Generation Legend (1991-1995) 14 02-04-05 02:59 PM
6 Speed Fixer Upper hondaman23 Legend 7 12-28-04 01:56 PM
FS: K&N High-Flow Air filter and filter service kit TB4USpk OEM Parts 17 02-28-04 11:23 PM
Added larger filter and converted to diy CAI the Legend has responded very well..... 97SE Engine & Performance Modifications 4 05-13-03 01:43 AM
