DRL in JDM fog lights DIY
For some of you interested to have the fog lights in JDM 1 piece headlight to work as DRL. Now, I'm very glad to provide some of the basic steps by steps instruction how to make it happened. I knew that some of the other members on here have already done it, but I've tried my best to put this mod together and hope that you all can enjoy.
First, I would like to thank a member Quaraxkad for letting me borrow your pic for demonstration purpose only. 1. I truely suggest to disconnect your positive battery terminal for your own safety. 2. If you still have the OEM Bose head unit, please be sure to obtain the security code prior disconnecting the battery terminals. Parts and some hand tools need to have to complete this task: 1. One new 12VDC normally closed (N.C) contacts relay. 2. Approximately new 10 feet 20 gauge red wire. 3. Approximately new 8 feet 20 gauge black wire. 4. Electrical tape or heat shrink. 5. New splash guard fuse holder with amperage rating up to 30A (recommended using 7.5A fuse). 6. One new 7.5A fuse. 7. New (4) 16-14 gauge-cal. female .250" quick disconnect w/protective sleeves crimp lugs. 8. New (1) 12-15 gauge-cal ring terminals. 9. Twist-on wire connectors. 10.Approximately new or used 10 feet flame retardant wire conduit uses for covering up the new wires. 11.Black tie wraps. 12.Soldering iron if available. 13.Power drill if available. 14.DVM if available. 15.Heat gun if available. 16.Hand tools: wire cutter, crimper and stripper, etc ... Listed parts would be able to purchase at any local autopart stores. ![]() There were a couple of ways to run just one single red wire from the ignition switch through the engine bay and all the way up to the headlights: 1. Drill a small hole through the fire wall on the driver side. Make sure to add a piece of rubber grommet or electrical tape around that hole edge to prevent from electrical short. And also make sure to use the flame retardant wire conduit to protect the red wire from the engine heat. 2. Or feed it through a black large clump of wires that leads to the inside fuse box. Take the gasket/grommet off, unwrap the electrical tape, and stick your red wire through there. Require to take off the front driver side fender liner. You can see it in this picture. NOT the grommet the arrow is pointing at, use the one that's above it. ![]() There were a couple places inside the engine bay that I chose to mount the relay: 1. Near the cruise control unit right next to the black fuse box. (Hella DE fogs relay). ![]() 2. Or the upper mounting headlights frame on the driver side. (DRL fogs relay - I picked that white relay at the local junk yard from 91 Corolla - FTW). ![]() In the past experiences, for a clean installation: I'd like to remove the front bumper which made it more convenience to run wires to both fog lights and fed them inside the flame retardant wire conduit then tie wrap it along the lower condenser chassis frame. 1. Strip off approximately 1/4" black wire insulation and twist or solder to each of the fog lights wire then crimp the other ends together to the ring terminal for grounding it to the chassis frame or a negative battery terminal. 2. Strip off approximately 1/4" red wire insulation and twist or solder to each of the fog lights wire then crimp the other end together to the quick disconnect w/protective sleeves crimp lugs then insert it into # 30 relay terminal. 3. Assuming that the supplied +12VDC red wire has been fed through the fire wall, now strip off approximately 1/4" of its insulation and crimp it into the quick disconnect w/protective sleeves lug then insert it into # 87a relay terminal. 4. Strip off approximately .5" black and red wire insulations and tap or solder them to the driver side head light power (HLP) wires and crimp each of the other ends to the quick disconnect w/protective sleeves lugs and insert both of these lugs into the relay solenoid coil # 85 & # 86 terminals. ![]() ![]() Sorry for a paint brush drawing pic, I'm not really good at drawing but I hope that it's still readable and understandable. 5. The next thing need to do is to locate the ignition switch (ig.sw.) wiring harness and slice or solder the remaining red wire end which has been fed through the fire wall into 1 of the hot wire on the ignition switch wiring harness. 6. It would be much easier to work around the ignition switch (ig.sw.) wiring harness by just removing the lower driver side dash panel. ![]() 7. The solid yellow wire in the ignition switch wiring harness is the only one that need to be tapped, sliced or soldered the remaining red wire end to it. Wait, don't forget to add the fuse holder by twisting or soldering its wires in between these 2 connections. 8. Now grounds both black wires ring terminal lug into the chassis frame (must locate a very good ground spot) or nut it into the negative battery terminal if possible. 9. Finally, reconnect the positive battery terminal and insert a 7.5A fuse into the fuse holder then turn the ignition key on to level II position to test the fog lights functionality. Both of them will be on for sure then switch the parking lights on, both fog lights will still be on untill switch the head lights on then both fog lights will be shut off immediately due to 12VDC feed from the head lights power to energize the solenoid coil (#85 & #86) to open up the normally closed contacts (#30 & #87a) relay terminals. This is the end of steps by steps instruction how to make the fog lights in JDM 1 piece head lights to work as DRL (Daylight running light). Thank you, ![]() PIAA H3 Yellow Ion behinds the amber difuser = double amber light outputs. ![]() Disclaimer: I will not hold any responsibilities for any shortages or damages it may cause if you decided to leave the battery terminal connected live while performing this mod. In addition: Since the USDM head lights don't have the fog lights option just like the JDM ones, instead they have the high beams in place of the JDM fogs so this is not a highly recommended modification to the USDM head lights version to have the DRL due to the high beam lense's configuration because: 1. Will definitely blind the oncoming traffics with high beams on all the times during the day unless switching the head lights on to kill the high beams off. 2. Will permanently loose the high beams functionality when the head lights are on. Comments and questions are welcome.
MOD's done so far:
B anned (SIKE!!!)
Nice Car!!!!
Check out my new wheels..... http://www.acura-legend.com/vbulleti...9/#post1243334 |
Da True JDM KANG
nice diy may have to do this one it seems to be the best one on this yet!
Yes im back! Alpha/AlphaTouring! http://www.acura-legend.com/vbulleti...ang%2Fjdm-kangOriginally Posted by Blackend Good to meet you too Willie. I tell ya, when we were walking the Auto-X course and you guys started pulling in, I had no idea who it was until I saw the green machine and we're all like "ooohhhh, that's Willie and the Acuraholicks!" Glad you guys made out, and nice meeting all of you. |
The Great White North
Heh i dont envy you americans
this was much easier to do on my car... just wire the JDM fogs to your high-beams and voila ![]()
Installed: JDM Headlights with HID Retrofit, Weapon-R Secret Weapon, Remus Exhaust, Metal Substrate High Flow Cat, MLS Copy Bar, Addco Rear Sway Bar, Eibach Springs on Koni Reds, Blackend Engine Damper, 17" RSX A-spec Rims |
#8 (permalink) | |
Thanks for your comments, you should try it out quick and I'm sure you gonna like them. |
Yes, except they cant be on at full power without the headlights being on also
And DRLs are mandatory in canada. All cars must have them. Not sure what year that started but it was definitely before 1991
#11 (permalink) | |
Legend Lover
With this mod, do you fogs come on with the headlight at all? can you turn them on with the highbeam switch? The way i would like to do this is to have the fogs com on with the highbeam switch weather the headlight or parking lights are on or off.
94' Desert Mist Legend LS coupe 86,000mi and counting....... "Life moves pretty fast. If you don't stop and look around once in a while........you could miss it!" Ferris Buller Last edited by stella91legend : 04-30-08 at 04:42 AM. |
1. Just wire up a seperate switch for the JDM fogs through the ignition wire like in this mod but don't include a relay. That way you can turn them on or off at any time you like after crank up the car.
2. With this mod, no the JDM fogs won't come on after the headlights are on, (keep in mind that the fogs are still on while the parking lights are on as well). Without this mod, yes you can use the high beam power to turn the fogs on or off except the headlights must be on first. 3. Like I've mentioned above, headlights must be on the first thing before you can use high beam power constantly to light up the JDM fog lights. (OEM designed that way originally unless you know the other way around, please let me know). Hope that I answered all of your questions. Thanks. Last edited by ptan1968 : 04-30-08 at 01:05 PM. |
Legend Lover
So if i wire this up like your diy, and use a toggle switch in the cabin insted if the relay, and the toggle is in the on position, will they automaticly come on like driving lights when i turn on the car or will i have to turn them on and off manualy every time i turn off/on the car?
94' Desert Mist Legend LS coupe 86,000mi and counting....... "Life moves pretty fast. If you don't stop and look around once in a while........you could miss it!" Ferris Buller |
#14 (permalink) | |
#15 (permalink) | |
Legend Lover
So with the switch off, the highbeams would work as usual.
