» Sponsors
» Sponsors
Old 05-08-06, 03:13 AM   #46 (permalink)
Car 1: 1991 Acura Legend
Car 2: 1996 Jeep Cherokee
What exactly is the D4 light?
EDIT: Now that I went out to the car and looked at the Dash I see what the D4 light is, but now the crappy part is that my D4 light doesn't work. gggrrr.....now I have to figure this one out.
I'm pretty sure its my TPS thats not working right.
[tHe] Saint is offline
Old 06-25-06, 10:38 PM   #47 (permalink)
Metro Legends™
BubzBeats's Avatar
Car 1: 90L Colbolt Blue RIP
Car 2: 90LS Melbourne Blue
Car 3: Both are sedans^
Send a message via AIM to BubzBeats Send a message via Yahoo to BubzBeats
looks like i need a rear O2 sensor thnx FOR THIS POST!!!!
BubzBeats is offline
Old 08-07-06, 06:30 PM   #48 (permalink)
Car 1: 95 Acura Legend
ECU Codes
The codes posted for the 1995 Acura Legend are missing the number 8 code. Was that a mistake or there is no #8?
Toni is offline
Old 08-07-06, 06:33 PM   #49 (permalink)
1991-1995 ECU codes are missing #8. Is that a mistake or there is no #8 code?
Toni is offline
Old 02-17-08, 04:59 AM   #50 (permalink)
Koonlay's Avatar
Car 1: 1991 Honda Legend Sedan
Lightbulb
OK, I'm VERY new at this. Where is the check engine light situated? My '91 Legend (Honda) has been sitting around for some time now and I would like to know if it's burnt out. I also just went to look for the wires to jumper but could not find them. Please pix of these would be greatly appreciated. Props to all forum members, you guys are the best!
Koonlay is offline
Old 02-17-08, 05:05 AM   #51 (permalink)
Koonlay's Avatar
One more thing, my D4 light comes on at startup then goes off, I guess this is OK right?!
Koonlay is offline
Old 03-11-08, 08:11 AM   #52 (permalink)
Car 1: Honda Legend
Hi all, I don't see a D4 light on my dash board, or I See it but don't know is it, does anyone has a photo ? Or could you explain me where it's located ? Thanks
I feel stupid, It's just the light when your tranny is on position 4...
Another question, is this the same light which is used to diagnose ECU problems as well as tranny problems ?
THanks !
Nekkro-Kvlt is offline
Old 04-13-08, 08:24 PM   #53 (permalink)
Toronto Legends
fuzzy2k3's Avatar
Car 1: 1993 4dr Legend
Car 2: 2000 Corolla
Car 3: 1987 Pontiac Acadian
thats what i was looking for. had everything ripped open trying to find "two pins"
fuzzy2k3 is offline
Old 04-17-08, 03:46 PM   #54 (permalink)
Car 1: 1995 acura legend sedan L
i got my code and it is a 6 which is coolant temp sensor anyone have some insight on where to start and what to check or replace
thanks
rahar95 is offline
Old 04-21-08, 08:00 PM   #55 (permalink)
Legend
Car 1: Cobalt Blue Pearl
Send a message via ICQ to u2vex Send a message via AIM to u2vex
ok, I have the famous D4 blinking light. I jump the service connected (black/white) like told on here but I get a solid check engine light. what to do?
P.s. no jumpy or erractic speedo or rpms, just drove 400miles only stopping to put gas last night but nothing out of ordinary.
u2vex is offline
Old 07-22-08, 04:01 PM   #56 (permalink)
Car 1: 94 Acura Legend LS
alright, i like this information, but how do i tell if i need the front o2 or rear?
Originally Posted by 502 MotorSports View Post
Some useful info:
Getting that little Check Engine lights on your dash may seem a little discomforting. In reality it is really a miracle of engineering and computer technology. Instead of randomly pocking in vast amounts of wires, sensors, and mechanisms in such complex car as a Legend, this little light tells you that your computer knows exactly what is wrong with the car (most of the time).
That means the exact sensor or gate has been pin-pointed as being either partially disconnected or simply out of acceptable range.
Location of ECU on 1986-1990 Legends
The control unit is located under the passenger seat on sedans and under the passenger foot well carpet on the coupes.
The engine CPU is the form of an aluminum box with a little plexiglass window. All you have to observe is a little red LED.
Location of ECU on 1991-1995 Legends
On the 1991-1995 Acura/Honda Legends, you have to jump a service connector located on the passenger side right under the dashboard near the door. The connector has two pin inputs. Connecting them with something like a paper clip will force the check engine light on the dashboard to display the codes.
Extracting Codes
With the car either running or the key in the ON position, perform the necessary steps above and observe the blinking of the light. The light will blink displaying all the codes in sequence and then repeating them.
Reading Codes
The code numbers are read by counting the number of blinks between longer pauses. On 1986-1990 Legends, the code number is indicacted by a series of rapid LED blinks between longer pauses.
On 1991-1995 cars, codes 1-9 are indicated by a series of short flashes; two digit codes use a number of long flashes for the first digit followed by the number of short flashes for the second digit. So a code 43 will be represented by 4 long and 3 short flashes.
The position of codes in a sequence can be helpful in doing diagnostics. A display showing 1-1-1-pause-9-9-9 indicates two problems occurring at different times. A sequence showing 1-9-1-9-1-9 indicates two problems occurring at the same time.
Resetting ECU
Sometimes it may be useful to reset the ECU memory. Although that maybe done by removing the battery for around 20 minutes or so, this will also kill your clock and radio presets. A more elegant way is to:
on 86-90 Legends remove the alternator fuse for 20 seconds.
on 91-95 Legends remove the ACG fuse in the interior fuse panel for 20 seconds. (note that this will also clear the seat memory)
Below are trouble codes for 86-95 Acura/Honda Legends:
1986-1990 Legend (G1)
Code # Explanation
1 Front Oxygen Sensor
2 Rear Oxygen Sensor
3 Manifold Absolute Pressure Sensor
5 Manifold Absolute Pressure Sensor
4 Crank Angle Sensor
6 Coolant Temperature Sensor
7 Throttle Angle Sensor
8 Top-Dead-Center Position Sensor
9 Number 1 Cylinder Piston Position
10 Intake Temperature Sensor
12 E.G.R. System
13 Atmospheric Pressure Sensor
14 Electronic Idle Control Module
15 Ignition Output Signal
17 Vehicle Speed Sensor
18 Ignition Timing Adjustment
1991-1995 Legend (G2) (Click here for transmission trouble codes)
Code # Explanation
1 Left Oxygen Sensor
2 Right Oxygen Sensor
9 Number 1 Cylinder Position (No. 1 Sensor)
12 E.G.R. Sensor
16 Fuel Injector
23 Left Knock Sensor
41 Left Oxygen Sensor Heater
42 Right Oxygen Sensor Heater
43 Left Fuel Supply System
44 Right Fuel Supply System
45 Left Fuel Metering
46 Right Fuel Metering
53 Right Knock Sensor
54 Crank Angle 2 Sensor
59 Number 1 Cylinder Position (No. 2 Sensor)
vaporxx2006 is offline
Old 07-22-08, 07:21 PM   #57 (permalink)
NBP...
Car 1: 91 Legend LS Coupe 6MT, Black on Black
Car 2: 2008 Acura TL-S 6MT
Send a message via Yahoo to Russian
Code # Explanation
Legends dont have front and rear o2 sensors, they have left and right.
Russian is offline
Old 07-22-08, 07:39 PM   #58 (permalink)
Jrucch's Avatar
Car 1: 1995 Acura Legend
i took off the carpet, but didnt see black and white wires, I saw a bunch of other colored wires, but not two black and white. Not a big deal anyway, I'm bringing my car in tomorrow, just curious what I did wrong.
Top Acura Models Ever
1995 Acura Legend L Sedan Canterbury Green
Jrucch is offline
Old 07-22-08, 07:45 PM   #59 (permalink)
NBP...
There is connector that is not connected anywhere.
Russian is offline
Old 07-22-08, 09:47 PM   #60 (permalink)
Jrucch's Avatar
thanks but i didnt see it, I took off the small almost triangular piece of carpet closest to the door, is that the right section?
Jrucch is offline
