not so newbie
Is you speedometer randomly jumpy? How about works fine for a while then goes crazy? What about the D4 Light is it on flashing sometimes? What about the check engine light sometimes?
Search NO MORE. THIS IS THE FIX! What the problem is the vss (vehicle speed sensor) the electronic chip inside has went haywire and needs to be replaced. Making it a new speed sensor theroeticly. What you need. 1991 - 1995 ACURA LEGEND SPEED SENSOR REPAIR KIT NEW OE Acura Part Number 06560-PY3-000 Dealer Cost : 125$ avg cost Ebay Cost: 86$ shipped Where to buy? http://cgi.ebay.com/ebaymotors/1991-...spagenameZWDVW or http://stores.ebay.com/FLATIRONS-ACU...ftidZ2QQt Zkm The instructions are included inside the kit. All products are new in honda boxes packed very well. Super fast shipping to your door 2-4 days tops. Tips: Remove the one bolt holding the speed sensor on the differental or tranny. Have a towel handy to put inside the hole so you dont loose alot of fluid. Make sure to unplug the speed sensor and mark the placement of it and the gear placement with a permanet marker, SO it goes back in precisely the way it came out. Please do not get the electronics wet, use the new seals provided, and make sure they gasket seals right, its somewhat tricky. This neds to be a sticky now. I've seen too many people asking about this. Thanks. Hope this helps all the newbs, and the not so newbs. Remember Search is a very good friend.
Not Your Average Ebayer |
.The.Laos.Guy.
pretty good write up.. you should supply some pictures to help detail the DIY and it will be a great DIY fix
Legends of North Carolina 1993 Acura Legend L [SOLD] 2002 Lexus IS 300 [current driver] |
mods: yes PLEASE!!!!
oh you do suck my vss just died this and i haev the part at home ill be doing this this weekend and my plan was to make a DIY if you want to combine efforts ill still take pics and do a write up
BTW ACURA OF AGUSTA will cost you $94 shipped +- shipping charges depending on how far you live
My Mission: -To create the hottest OEM "looking" legend. http://www.legendaryphotos.net <-- Recently updated!!! ![]() A-L.com T-shits for sale! <-- Click |
just an FYI i had the exact symptoms. me and a mechanic friend instead jumped the ecu and found i needed a new coolant sensor. We replaced the sensor and now my D4 doesnt flash my rpms are fine and my engine light is off. It wasnt the VSS like people had said. It was my egine coolant temp sensor. I bought the VSS and now im not using it but im not going to get rid of in just incase.
#6 (permalink) | |
Rpms arnt the vss the speedo is .... then that you make sence anyway FOR ANYBODY DOING THIS DO NOT STRIP THE SENSOR SCREWS you will forever be up the creek and your car will be sitting on jacks till you get new screws and a way to get the old out BTW im currently taking pics as i go and ill prob make a DIY thread in the DIY section anyway unless you want my some pics
not so newbie
email me the pictures and I will put them in here and give you credits for the pictures.
mordezmoncou@yahoo.com
#8 (permalink) | |
EDIT there is already a DIY thread about this .....
not so newbie
This thread is here because the poor little newbies keep posting stuff about this and they dont search or look in the diy section first, so this cuts down on 30 threads a week started about this problem.
So It needs to be where the noobs post them so they will see the sticky right in there face and refraim from posting a new topic about there speed sensor issues. Its very very simple to change, so I dont think a DIY really is almost neccesary, instructions come in the box.
Yo pedo en su dirección.
1995 Acura Legend LS Coupe 6 speed NSX seats - JDM Headlights - OEM Fogs - MLS Copy strut bar - Legend specific Tie bars - Addco F&R Sways - KSport suspension - Sr5Guy Stage 2 Chip - RangerJoe Short shifter - Aluminum Pulleys - Injen intake - Stromung 2.5 inch cat-back - S2000 Battery Coming soon to a theater near you... 2005 RL BBK - Upgraded Final drive and LSD - Custom header - Cams - adjustable ball joints - adjustable end links |
#12 (permalink) | |
Oh my goodness.... you have TOTALLY helped push me in the right direction. My boyfriend gave me his 95 type II and this is what has been going on. I tried to get a diagnosic done, but the two places I went to said that they can not find the hook up for the machine. But my speedometer is not acting crazy.. it's my RPM gadge once in a while and my fuel and temp. gadges are not working.... Do you think that would be the same problem?
#14 (permalink) |
not so newbie
prob so, it might be a combo if a bad gauge cluster (instrument cluster)
and this speed sensor, id go fix the speed sensor first. if it doesent fix everything, then you know you need an instrument cluster too.
#15 (permalink) |
I ordered the VSS repair kit from ebay but I wanted to outline my symptoms and see if some other irregularities have been noticed by other members
I have all the regular symptoms: erractic speedo, sometimes check engine light, often D4 light is flashing. But sometimes (rarely) my tach will act a little erratic. I've had it where I've turned on my car and the tach wouldn't be working but the speedo would. I tried turning the car off and on a couple time and eventually the tach starting working....but then the speedo wasn't. Another thing I've noticed with the speedo is that if I have the cruise control switch on (the dash button, not the steering wheel button), and the speedo stops working, usually turning off the cruise control light will make the speedo work again. If that doesn't work, pressing the button to roll the drivers side window up (only the drivers side) will allow the speedo to work. As soon as I stop pressing the button though the speedo returns to it's not-working state. And once when that didn't work, I pressed the button to cycle the air in the cabin instead of drawing in fresh air and that allowed to speedo to work normally. I've tested these again and again and they are very consistent in making the speedo start working. It also seems that if you warm up the car really slowly, i.e. driving it around in 2nd and keeping it under 2k for 15 minutes, the speedo doesn't go erratic and the D4 light doesn't flash. Everytime I've had problems with the speedo and D4 light, I've found that when I park the car and stop it for 15 minutes or more (enough time to eat at taco bell) and return, as long as the car is still warm, I won't have any problems with the D4 or speedo until the car gets a chance to cool completely. Then my problems start up again. I just wanted to see if all of this is indeed caused by a malfunctioning VSS. Now to fix my overheating problem. The cooling fans keep blowing the fuse whenever they turn on. But only if the car is on. |
