» Sponsors
» Sponsors
Old 06-05-09, 06:30 PM   #241 (permalink)
reboticon's Avatar
Car 2: 91 civic, 90 Integra
Car 3: 71T-bird, 95Explorer
Oil is shot through the cam bearings into the cam journals. That lubricates the cam. The lifters themselves also shoot oil through them. If you run it and see lifters that aren't lubricating themselves with oil, something is wrong. Probably one of them had all the oil inside dry out and its got some gunk in it. Oil isnt going to shoot everywhere without the valve cover on but it will have droplets thrown off of the cam.
Now that I think about it, you may also have to ground the coil packs somehow, since the valve cover would be removed. This is the most common technique for setting valve lash on a domestic V8. Adjust the rockers down until they quit clacking, then one extra half turn.
My Low Buck Non-Legend Builds
90 DA Teg
89 Boosted CRX!
reboticon is offline
Old 06-29-09, 12:47 AM   #242 (permalink)
Car 1: 1991 Legend Coupe
Car 2: '93 Accord *wrecked*
Hey one question. When you guys have your heads machined, what do you have them milled to? I was thinking really small, like 5/1000 or 10/1000. Or do you just take off enough to make them flat again?
mtnbikkerkid33 is offline
Old 07-01-09, 03:45 PM   #243 (permalink)
Originally Posted by 1_Hot_Legend_LS View Post
One thing you forgot to mention. You should always use new head bolts when reinstalling the head. If you didn't then shame on you! These are stretch style bolts and should be replaced after being removed.
How much do those cost and where do I get them?
Old 07-25-09, 05:12 PM   #244 (permalink)
attitudereflectleadership
the gold version's Avatar
Car 1: 1995 acura legend
Car 2: 99 camaro SS 6 speed
question on page one step # 37 says to torque the 6mm bolt to 9pounds , but the book says 108 pounds. wich one is it? to me , 9 sounds like it would be ,but i want to make sure
the gold version is offline
Old 07-26-09, 01:33 AM   #245 (permalink)
Quaraxkad's Avatar
Car 1: 94 Legend LS sedan
Car 2: 92 Cutlass Supreme S
I answered on the other forum. Just for completion: They are both the same, 9ft-lbs is 108in-lbs.
Quaraxkad is offline
Old 08-05-09, 02:33 AM   #246 (permalink)
Car 1: Lancer
thanks for the advice man.. this is really helpful and educational. thank you
Nitroholickid is offline
Old 08-05-09, 11:42 AM   #247 (permalink)
blk87brd's Avatar
Car 1: 1991 Acura Legend,
Car 2: 1993 Acura Legend,
Car 3: 1987 T-bird Turbo Co
Quote from Icemans very complete and well presented DYI.
36. Coat the bolts with engine oil prior to installation. Using the tightening sequence described earlier, begin to tighten the head bolts. DO NOT TORQUE THEM TO SPEC JUST YET. Turn each bolt in sequence until they start to get a little tight. I stepped my torque wrench up a little at a time ie: 20 - 40 - 50 - 56 foot pounds. Do the same for both the left and right heads and the hard part is complete.
My question is one I have got two answers to and would like to find the correct answer.
Iceman does not suggest that head bolts are a one time use (torque to refusal), The Acura Legend Online Manual does not speak of replacing the head bolts, yet I am told by some that the head bolts on a 3.2 are never to be reused. Mine is a 1993 LS with 135,000 kilometres and a BHG. I have purchased the upper end gasket set am at the point of putting it back together but can not get a clear answer on whether the head bolts can be reused.
blk87brd is offline
Old 08-05-09, 12:52 PM   #248 (permalink)
i hope they can be reused cause i reused them
Old 08-05-09, 04:06 PM   #249 (permalink)
Quaraxkad's Avatar
I think *most* people reuse them, some people buy new ones. Nobody seems to know for sure what kind of bolts they are. I think the manual would tell you if they needed to be replaced, and it doesn't.
Old 08-13-09, 06:41 PM   #250 (permalink)
reboticon's Avatar
I reuse them always just run them through a m11x1.5 dye first to be safe.
90 DA Teg
89 Boosted CRX!
Old 08-26-09, 08:46 PM   #251 (permalink)
Haa Yu Ken
edcypha's Avatar
what happend to the pics??
edcypha is offline
Old 08-26-09, 09:38 PM   #252 (permalink)
Quaraxkad's Avatar
Seems to just be a problem with the server they're on, I'm sure they'll be back.
Old 09-02-09, 02:42 AM   #253 (permalink)
Haa Yu Ken
edcypha's Avatar
still no pics...damn babylon system
edcypha is offline
Old 12-29-09, 07:34 PM   #254 (permalink)
GS_Legend's Avatar
Car 1: 94 KA7
Car 2: 94 Integra GSR & GS
Car 3: 02 Si EPz3 (swapped)
Blown HG
To the OP,
Man that's a lot of Ballzzz doing the HG yourself! I read through the 17 pages of this thread and wow! I don't think that I can ever devote the time or patients to do something like that. Very useful info.!
Thanks!
If it wasn't for bad luck... I'd have no luck at all!
GS_Legend is offline
Old 01-08-10, 05:15 PM   #255 (permalink)
Car 1: 91 legend sedan
Car 2: TT300zx Z32...someda
hey guys i have a timing question.
I have my heads and cam sprockets off. I marked the cams and belt, but i just left the belt on and I am afraid it may have came off the crank pulley and moved over a tooth. When i go to start the car will it destroy the engine if the timing belt is off one tooth. (valves hitting pistons) I do not know much about timing. I am about to put it back together so any help is appreciated
acuralegend-z32 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
head gasket theory Vancouver_Legend Second Generation Legend (1991-1995) 30 08-25-06 10:57 AM
