Old 03-30-06, 08:44 PM   #76 (permalink)
Car 1: 1991 Acura Legend LS
Car 2: 2005 CLK 55
Car 3: 2005 Honda CBR 1000
Thumbs up
The 1/2 tooth tip worked perfect. Thanks alot for the tip.
SNSNNJ is offline
Old 04-02-06, 07:29 PM   #77 (permalink)
Car 1: 93" Acura Legend
Car 2: 93" Cadillac Deville
i just had this done myself, i payed 300 for the gasket kit, and my uncle did it for me. i got a 1993 Acura Legend, and it was 170k miles on it, i just replaced the head gaskets, its got a new timing belt, new water pump, and radiator. Think it still has some life to it?
Poizun is offline
Old 04-08-06, 09:25 PM   #78 (permalink)
DRDcustoms's Avatar
Car 1: 95 Legend LS coupe
Car 2: 07 Honda CBR600rr
Car 3: 92 Acura Vigor GS
Ay, very good post. Woulda helped me out on my first Legend!
Heroes get remembered, but Legends never die.
DRDcustoms is offline
Old 04-08-06, 09:30 PM   #79 (permalink)
DRDcustoms's Avatar
Dude my first 1991 Legend ran till 270k Just baby it
Old 04-15-06, 02:18 AM   #80 (permalink)
Car 1: 1991 legend sedan
blown piston rings
thanks for D.I.Y on that, I recently done my head gasket and spent 1200 , and it was fine, now after 7 months , blue smoke is coming oujt of my muffluer. i recently took back too da shop that did the job on my head gasket and they told me it now blown piston rings, someone please help
jchery74 is offline
Old 04-17-06, 12:55 PM   #81 (permalink)
Car 1: 1992 Coupe LS {sold}
Car 2: 1992 Lexus LS 400
Send a message via AIM to Pito11213
You didnt follow the cardinal rule with HG replacement. Since the engine was apart you should have changed the valve seals and other pertinent things. Blue smoke definatly means oil is burning. Not so sure on the blown rings thing though. How often does the smoke come out?
Pito11213 is offline
Old 05-08-06, 12:44 AM   #82 (permalink)
Car 1: 1995 Acura Legend
Cool Here we go...
Well I'm throwing my hat in the ring. I had a cracked Cranshaft pulley and one of the sections came right off of the hub!! The used replacement I got has the same stress cracks in it!! So I said screw it might as well address the intermittent rising of the temp gauge, and screwy high idle. Besides it looks cool and I want to drive this car for along time. I'm up to the ignition coils...
Let's hope for the best.
theworldisnotenough is offline
Old 05-10-06, 09:29 PM   #83 (permalink)
PearlWhiteLedge's Avatar
Car 1: 94 Acura Legend LS Sedan
if anyone has done this job before..umm i cant loosen the screws that the driver side pulley is connected too..the whole pulley seems to turn when i try to unscrew it..anyone has any tips on what to do?
"Some Say The Legend Is A Heavy Car But We All Know, It's Not The Car, It's The Driver"
PearlWhiteLedge is offline
Old 05-12-06, 04:07 PM   #84 (permalink)
KJLegend's Avatar
Car 1: 1995 Acura Legend LS Sdn. Blk on Blk
Send a message via AIM to KJLegend
Angry FU@K
Where were you when I needed you like a year ago man! I had to go through the same shit!
KJLegend is offline
Old 05-12-06, 04:31 PM   #85 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Car 2: 92' Acura Legend 4DR
Make sure the tensioner screw is going through the AC compressor pulley, that will prevent the pulley from rotating with the bolt. If its the Alternator then you need to loosen the bolt below the Alternator and then loosen the tensioner, you dont have to actually remove the pulley for it. Power Steering pump is the same procedure as the AC compressor.
Dethred is offline
Old 05-12-06, 04:34 PM   #86 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
I think he's talking about the camshaft pulley.
I used an impact gun to break those bolts loose, it gets it quick and easy. Otherwise you need to use a belt strap to hold it still
Mike Diaz is offline
Old 05-12-06, 06:22 PM   #87 (permalink)
Fast & Furry-ous
BlackIICoupe's Avatar
Car 1: 1993 Black Legend L 6spd Coupe
Lacking an impact wrench, the method I used was this, though it may be a little hard to visualize: I put a wrench on one bolt, and another wrench on the second bolt. Squeeze the two wrenches together until the first bolt breaks breaks loose, and remove. Do the same for the next bolt, but do not remove. Use it as leverage to break the third one loose, and remove it. Yes, as you freed the third bolt, you tightened the second, but not near as tight as it was. Wedge a piece of wood abut the width of the timing belt against the pulley and remove the third bolt.
Convoluted a bit, but it worked for me.
JD
http://home.comcast.net/~spastic_muse/cres_sig.jpg
Black '93 Legend L 6spd Coupe
Black '87 Toyota MR2 T-bar
BlackIICoupe is offline
Old 05-12-06, 10:41 PM   #88 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Whoops! I couldn't get mine off with an impact wrench, so I sent it off to the machine shop with them still on.
Dethred is offline
Old 05-13-06, 11:57 AM   #89 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
When I do head gaskets, I usually leave them on.
Old 05-13-06, 03:55 PM   #90 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
The machine shop made me take the pulleys and lifter assembly off of each head.
Dethred is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
head gasket theory Vancouver_Legend Second Generation Legend (1991-1995) 32 08-25-06 10:57 AM
