Old 06-12-06, 01:43 AM   #106 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Car 2: 92' Acura Legend SDN
Originally Posted by lgndkiller
I am in the process of getting a 95 Legend GS. Please can someone tell me what i should look for when i go to pick up the car. I was told to check the coolent level before i start the car take it for a high speed run and let it idal for a while when we get back and then look at the coolent level in the resoviore. Will a hard run of this nature catch a BHG. i will also look for the erratic idaling and keep an eye on the temp gauge. Does anyone have any other idea's on what else i should look at. Your help is highly appreciated.
To safely do that you better have a whole day. Always wait a few hours before opening the radiator filler cap to avoid serious injury. Just ask to take it out for 30 minutes. If he/she declines, ask if you can let it idle for 30 minutes after it reaches operating temps. If he/she declines they're hiding something. It can take as long as 20-25 minutes to manifest an air bubble even under normal driving.
-Check the fluid before starting it up, if the engine is cold
-Run engine for as long as possible.
-Check for fan activation
-Check for overheating, even if slight, at or past the 1/2 way mark
If you're still not sure, get a sample of the anti-freeze from the radiator after it ran for a while, and send it off to a shop or lab to be tested for hydrocarbons.
Dethred is offline
Old 06-13-06, 11:50 PM   #107 (permalink)
Car 1: 1992 acura legend
if they're really nice maybe you could open the air bleed valve. bleed it before, test drive it for a while, and open it after.
bicball is offline
Old 06-14-06, 02:46 AM   #108 (permalink)
Lost, but still @ it !!
Car 1: 1994 Acura Legend
Smile
...oooK, first off; new for here at this Forum [ and a GREAT one at that ], working with a 94' Acura Legend w/3.2L eng...... onset here & all apart now(torndown) for the D.I.Y Head Gasket_job......no worries for i AM mechanically inclined and all { tool's = MAC & SnapOn etc..} my question of concern is to deal with the new Head Gasket Set (FelPro @ that) = Why are the "holes for the water passages like on one end is of one size then towards the other end of the head, the "hole's" tend get smaller in size and noted they are NOT the same "oval_type" shape as per say the water passages from block to head???? am i to try and cut ea or all of the passages to equal the opening jacket's showing from the block to the head to make match??? OR, is this some sort of water "restriction" for which is required & i am not understanding whole-ly/correctly??? much appreciate your replies/comment's/suggestion's on this matter.......again, GREAT forum for help, here.....
.....mr. Charles
mr. Charles is offline
Old 06-14-06, 03:20 PM   #109 (permalink)
Mr. Hard to Find!
1_Hot_Legend_LS's Avatar
Car 1: 1991 LS Sedan Auto
Car 2: 1990 Chevy S10 SB V8
Hmmmm Mr Charles, I noticed this too and did nothing. I haven't had a problem yet. I think it may be for water restriction as you sai but I'm not sure.
DV8, wanna shed some light on this one as it is out of my Legend knowledge.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
_______________________
Forum Rules
1_Hot_Legend_LS is offline
Old 06-14-06, 07:30 PM   #110 (permalink)
Question
. . . thx for your reply back for this 1_Hot_Legend_L........ at least i can say that i am NOT seeing thing's........ .........but, does that ever look like to be some bit of water restriction's for the water passages and all..... ........hope someone else out there will know the REAL insight/fact for this........
mr. Charles
Old 06-14-06, 07:42 PM   #111 (permalink)
this might be kind of random here but i didn't think it was exactly thread worthy and i couldn't find another thread on it.
i've been driving around my legend with a BHG for a while now, though only a few miles, it doesnt even have time to overheat, though i think the heads are warped. is there any indication of the heads being warped that i can find? if they are warped and i need to have my heads straightened, how much would that cost?
bicball is offline
Old 06-19-06, 12:24 PM   #112 (permalink)
Car 1: 1995 Acura Legend
Originally Posted by Jetdoc
Most likely the timing belt is one notch off.
Here is a tip for timing the engine.
Remove the spark plugs! Set the drivers side cam pulley right on the timing mark, set the pass. side cam pulley on the timing mark then rotate the pully towards the engine about 1/2 of a tooth. Set the crankshaft right on the timing mark. Install the belt starting at the crankshaft then tensioner the pass. cam pulley ect.. Loosen the tensioner bolt to allow the tensioner to tighten the belt then tighten it back. Rotate the engine through 6 times and check the timing marks, they should be right on. Loosen the tensioner bolt again and retighten it.
I had trouble with this until I used the 1/2 tooth tip.
Here is a good thread for timing belt help
Timing Belt Help.....
I just finished a the head gasket job. I got my car started but it is running rough and backfiring slightly. So I'm guessing it is the timing. How far should I break it down to get the timing right? Removing the cam sprocket shields or removing the entire cover and putting the belt on from scratch? My passenger side cam sprocket does not have a timing mark so I made a best guess.
theworldisnotenough is offline
Old 06-19-06, 04:56 PM   #113 (permalink)
Mr. Hard to Find!
You should have marked it before taking it off. But it still should have a mark somewhere, just look closer.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 06-28-06, 09:05 PM   #114 (permalink)
Car 1: 2000 Impreza RS
Car 2: 1991 LS400
Car 3: 1992 sedan wrecked
one question, if i had a BHG, would the oil become white and pasty?
kohreeuh is offline
Old 06-28-06, 09:13 PM   #115 (permalink)
Car 1: 1991 Bowling Ball Gold Acura Legend LS Under Construction
yes if u have water in ur oil it will look milky... if milky is a word...
The best commercial ever made.
http://www.ebaumsworld.com/nutrigrainad.html
notice what the black guy is holding at his desk.
robbanks111 is offline
Old 06-29-06, 12:51 AM   #116 (permalink)
Hi! I'm Ryan.
Dethred's Avatar
Usually if it is really noticable, then you have a cracked head or block. I had a very tiny bit but I can spot it easily nowadays.
Dethred is offline
Old 07-02-06, 08:58 PM   #117 (permalink)
Car 1: 1992 acura Ls coupe
hey i got this question
hey guys... k im replacing my head gaskets and im taking off the intake manifold.. and i have all the screws and bolts off... and i can move it around, the front lifts totally off the bolts... but the back 2 dont.. but they still lift up a lil bit... are there any bolts or screws or anything that could be holding it down, in the back? i need a quick reply.. thanks!
salomonrider55 is offline
Old 07-02-06, 09:13 PM   #118 (permalink)
Mr. Hard to Find!
Did you unbolt the EGR metal tube? That would definitely hold you back from getting the intake off.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 07-02-06, 11:36 PM   #119 (permalink)
where is the egr pipe... i have a haynes manual.. and it doesnt show where it is... and ya... i prob shouldnt be doin this myself. but its too late now... so where would it be located? cause i took off a metal pipe from the air intake to the manifold... but thats the only one... it seems like sumthing is holding on in the back...
Old 07-03-06, 12:54 AM   #120 (permalink)
Mr. Hard to Find!
It should be directly on the backside of the intake manifold, somewhere under the EGR valve. You will need to shine a flashlight down there and you should be able to see it.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
head gasket theory Vancouver_Legend Second Generation Legend (1991-1995) 32 08-25-06 10:57 AM
