LinkBack | Thread Tools |
Rating:
Display Modes |
502MotorSports.com
Every 250 miles or weekly
Check engine oil Check engine coolant level Check windshield washer fluid Check brake fluid level Check tires and tire pressures Every 3,000 miles or 3 months Above listed items plus: Check power steering fluid level Check automatic and transmission/transaxle fluid level Change engine oil and filter Every 7,500 miles or 6 months All items listed above and: Inspect/replace wiper blades Check/Service Battery Check/Adjust (if necessary) engine drivebelts Inspect/Replace (if necessary) all underhood hoses Check cooling system Rotate Tires Check front disc brake pads Every 15,000 miles or 12 months All items listed above and: Inspect the brake system Check clutch pedal height and freeplay Inspect the seatbelts Replace the a/c air filter Adjust valve clearances Replace the air filter Inspect the fuel system Check m/t lubricant Check differential lubricant level Inspect suspension and steering components and driveaxle boots Inspect exhaust system Every 30,000 miles or 24 months All above listed items plus: Replace the spark plugs (conventional, non-platinum) Check and replace, if necessary, the PCV Valve Replace the fuel filter Service the cooling system (drain, flush, fill) Replace the brake fluid Change automatic transmission/transaxle fluid Change manual transmission/transaxle lubricant Change differential lubricant Check EGR system ( Exhaust Gas Recirculation) Check and adjust engine idle speed Check and adjust engine ignition timing Replace ABS high pressure hose Reset Maintenance Required Indicator Every 60,000 miles or 24 months All items listed above plus Replace the spark plugs (PLATINUM TIPPED SPARK PLUGS) Every 90,000 miles or 72 months Replace timing belt Replace water pump Book mark for your reference, ladies and gentlemen.
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | 502MS Project e39 | 502MotorSports MySpace |
502MotorSports.com
Most of them are DIY'ers.
I would think you could handle them all, at least with a little help.
Sr. Member
I believe the 120K service is the same as 60K....you wouldn't do the 90K @ 120 since that includes the timing belt (which should have been done only 30K miles ago).
I just hit 120K, changed the oil and trans fluid yesterday, still need to do some more inspections and change the plugs and fuel filter. Regards,
Sean in Norcal '05 Infiniti G35 Coupe '94 Mustang Cobra '94 Legend LS Sedan (SOLD) '97 Lex LS400 Coach Edition http://www.mustangmods.com/data/4358/legendsig2.jpg |
a legend meet on how to do all this stuff would be really sweet.
cuz all i have done to my car for the last 6 months is change the oil.... and i dont know what the previous owner has done.
http://img.photobucket.com/albums/v3...44/avatar2.jpg |
i got some questions i know how to do everything but :: Adjust valve clearances, Check and adjust engine ignition timing,Replace ABS high pressure hose.
-im thinking about doing an engine flush what do you think about that?
1995 Legend GS (sherwood Green) 144,000 My ride http://www.cardomain.com/memberpage/608014 |
Can someone make a DIY on how to clean the PCV valve or at least take some pics of it and how to take it out?
http://img167.exs.cx/img167/7114/sig3pt.gif |
#14 (permalink) | |
