Old 04-08-08, 12:18 PM   #76 (permalink)
91LSplendid's Avatar
Car 1: 1991 Legend LS Sedan
Car 2: 2006 Grand Caravan
Originally Posted by mktng View Post
question for you all.. when tilted. does your weather strip on your moonroof driver side front fit smoothly/flush ?
because my driver side weatherstrip is squished up a little bit, as if the weatherstrip isnt alligned or something.. wierd.. dont think it affects anything but in the long run it might ware out the weather strip..
I can say my weatherstrip does not get squished. I just so happen to have my camera with me today and went out and took a picture for you to compare.
'91 LS - Golden Glow Pearl Clearcoat (YR-502P) w/ Cream Ivory Leather (Type F)
92,000 miles
Modifications = Sunroof Tilt, Armrest w/ Cupholder swap, tint removed, Iggee Front Seat Covers with Visable Controls Mod (see DIY below), no other mods...
DIY's
1) How to Install Iggee Front Seat Covers http://www.acura-legend.com/vbulleti...8/#post1293770
91LSplendid is offline
Old 04-08-08, 12:33 PM   #77 (permalink)
Matthew is THE USER!
mktng's Avatar
Car 1: 91 KA7
Car 2: soon2b GIXXER 750!!!
hmmm mine does.. at least you know what i mean though right?...
hmmmmm... im just trying to figure out why it would do that.. unless.. my moonroof was put back on not properly alligned.. but thats impossible because of the way its mounted... i'll just go out and buy weather strip softner or something.. or maybe my wind deflector is doing something funny to it..
the weather strip just seems close to the frame of the car than the passenger side... hmmm
mktng is offline
Old 04-08-08, 12:51 PM   #78 (permalink)
You say it is only the driver side. To me it sounds like something is not aligned just right. Since now you know the process and it would go even quicker, I would loosen the Sunroof and see if there is any play at all and then retighten. A tiny shift could be all that's needed. I do not mean redo they whole process, just loosen the eight 10mm bolts that hold the roof to the brackets and try to shift. For the 10 minutes it would take it may be worth a try...either that or your Sunroof opening is not square. J/K. Good luck.
92,000 miles
DIY's
Old 04-08-08, 01:26 PM   #79 (permalink)
mktng's Avatar
Car 1: 91 KA7
yeeaa played around with it.. its definately something wack with the weather strip.. i'll figure something out.. its not even a big deal. but now i know its there... it just bugs the heck outta me..
mktng is offline
Old 04-08-08, 07:43 PM   #80 (permalink)
Hey Mktng, one other thing I thought of. I remember when I was re-installing the 4 10mm nuts (2 on each side for sedans) that I had removed in Step 7 of the FIY, I was able to see exactly where the nuts use to be on the Rail Holders (the nuts had rubbed off the paint). I remember one of mine was not quite lined up, so I adjusted it so I was putting everything (wind deflector and rail holders) back together exactly as it came off. If your driver side rail holder is slighly forward of its original position, it may be causing this "issue"...?
92,000 miles
DIY's
Old 04-09-08, 04:33 PM   #81 (permalink)
Cassis Red Pearl
EvilRed92Legend's Avatar
Car 1: '92 Acura Legend LS 5spd
Car 2: '90 Jeep Cherokee
Send a message via AIM to EvilRed92Legend
With Glass In
Just finished this modification with the glass left in (after taking it out gave me a bunch of grief and made me think I broke my sunroof). Took a little bit of effort to lift the slider rails up, and all I could get in there to turn the screw was needle nosed pliers. Other than that, super easy mod. with super cool results. Love it. I highly recommend doing it with the glass in, cuts out the first 5 steps of the DIY, literally took me about a half hour, and I cleaned up the wind deflector and other shit while I was at it.
1992 Acura Legend LS 5spd
  • A Legend Reborn.
  • JDM one-piece headlights.
  • Moonroof Tilt Mod.
ISO: OEM Floormats Type J Int. Color.
FS: 2200 radio, 2100 amp.
www.myspace.com/g3rgory
Ebay: eating420seeds
EvilRed92Legend is offline
Old 04-09-08, 05:41 PM   #82 (permalink)
mktng's Avatar
Car 1: 91 KA7
took you half an hour .. and the added 24 hrs of thinking ur moonroof was broken right hhehehehe..
to tell u teh truth. even taking off the sunroof, it should still only take about 30 minutes if everything goes smooth. the added bonus of taking the moonroof off is that u can clean more of the track, but honestly .. yea you dont really have to take it off.. after i removed mine... i didnt see a point to doing it..
but.. better safe than sorry.. the guide said to do it.. so i just did didnt hurt
mktng is offline
Old 04-25-08, 01:16 PM   #83 (permalink)
ymisoqt's Avatar
Car 1: 95 Acura Legend
Ok guys, I have finally grown enough balls to do my first mod. I've only replaced stuff so far. Does anyone have any advice on this? I'm planning on doing it tomorrow. I've searched all of the threads and read them along with printing off the instructions. But I'm still biting my nails, ha! At least be on here tomorrow in case I get stuck!!
www.myspace.com/jenstorace
ymisoqt is offline
Old 04-25-08, 02:56 PM   #84 (permalink)
For Step 8 have the correct tools. The little screws (one on each side) are upside down and there is not a lot of space between the car and the screw head. It was a little weird to get these off due to the postioning and would be easier with a 2nd person (your son?) holding up the rails for you, but can be done solo.
The DIY mentions using needle nose pliers, another member used a small vice grip, but I used and ratcheting offset screwdriver I purchased at Lowe's for under $5.
for some other small hints I found helpful when I did mine see Additional Benefit of the Sunroof Tilt Mod
Good luck.
92,000 miles
DIY's
Old 05-12-08, 03:43 AM   #85 (permalink)
Car 1: 1993 Acura Legend Coupe Type II 6sp
Car 2: 87 Prelude 2.0si 5sp
WOO! Just finished this mod! took quite a while for me, cuz I cleaned everything, but other than that it was a great tutorial:
I HAVE A QUESTION THOUGH! For all those that have done this...
I did this mod on my coupe, and now when I open the moonroof tilt the rubber seal on the back of the glass rubs against the roof of the car.... Whats worse is when I go to close the moonroof after it has been open (titlted) The rubber seal on the back of the glass rubs pretty damn hard against the roof, and almost gets stuck (it did get stuck completely, before I put some sewing machine oil on it)
I saw some other members have had this same issue and they used silicone.... I was wondering if this is supposed to happen? If not, what should I do to make it better?
If it is supposed to do this (cuz it keeps the water out when closed?), what do you recommend is the best lubricant to put on the rubber so the friction between the weatherstrip and roof doesn't cause wear/tear on the sunroof motor/cable?
filmshoot is online now
Old 05-12-08, 04:10 AM   #86 (permalink)
Car 1: 1994 Acura Legend GS Black/Black 6-speed
Car 2: 1997 Honda Prelude
Send a message via ICQ to mweber88 Send a message via AIM to mweber88 Send a message via Yahoo to mweber88
First word of caution: NEVER use oil on rubber seals. It makes them swell and ruins them. Use silicone-based products only. This goes for hoses and everything!
And, that seal around the edges of the glass is not to prevent the water from coming in. It HELPS, but it's not the only thing. We have a drain pan in our roof and four drain holes with hoses leading to drains so the water can drain out (and trust me, it does).
My 97 prelude seal needs a little silicone every so often as it pops up and out rather than going in. Same situation here.
Now just clean that oil off of that seal with some dish soap and water and then silicone spray it.
Good job and good luck!
Mike
Still hunting for the boost prevention routine in the ECU. PM me if you have any thoughts.
mweber88 is offline
Old 05-12-08, 04:52 AM   #87 (permalink)
Aye!!
ok thanks for the heads up......glad I posted...
I'll get some silicone spray tomorrow and do it right.
Old 07-06-08, 07:26 PM   #88 (permalink)
LegendMan
LegendLand92's Avatar
Car 1: 1991 Acura Legend LS Sedan Golden Glow Pearl
Car 2: 1992 Acura Legend L
Car 3: 2006 Honda Odyssey
Wow!!!!! That's all I can say! I did this mod today and it's the best thing I have ever seen. Thanks, LOVE IT!!!!
My baby- a '91 Acura Legend LS Golden-Glow-Pearl type F.
Modifications+Repairs: New paintjob, Iggee seat covers with seat control mod, sunroof tilt, new brakes, spoiler, pinstriping, calipers painted red, glow gauges, red needles, rear passenger window repaired, new speakers, armrest with cupholder mod, repaired headlight, new power antenna, new hood supports...
To Do: A/C repair, Acura-Legend.com decals, pass. mirror repair, steering wheel audio control repair, tires, chrome pillars...
LegendLand92 is offline
Old 07-06-08, 07:40 PM   #89 (permalink)
Stock Is Best
Mastervtec's Avatar
Car 1: Bastard People
Send a message via AIM to Mastervtec
If anyone has done this mod and still has the little "stoppers" they took out to make their sunroofs tilt, I would love to have them so that I can return my sunroof to stock. I don't care for this mod at all.
-BDE
"I like your cane." <<< >>> LMAO. You had to be there.
CLICK!!>>> Newbie FAQ...Read It!! <<< CLICK!!
My Coupe - Sold
My New Coupe
Mastervtec is offline
Old 07-07-08, 08:47 PM   #90 (permalink)
IvAn_120's Avatar
Car 1: legend
thanx alot man i just finished it
it was way to easy and looks crazyyyyyyyyyyy i love ittttttt lol
thanx alot to all
*^*^*^*^ go hart, or go home ^*^*^*^*^*
IVAN_120
1991 LeGeNd
black
*** 5 speed** loving it
with 7" tuch screen in dash tv
13 1/2" LCD over head tv
18" (215/35/18r)
and other small things
~~~ They all start hating cause you got a Legend but it doesn't matter cause they are just jealous~~~
IvAn_120 is offline
« Head Gasket D.I.Y. | - »
DIY: Remote start/ Tilt steering Roger DIYs 20 04-10-07 11:09 AM
those with moonroof tilt mod raky Second Generation Legend (1991-1995) 95 09-21-06 12:32 AM
Is there a DIY for the tilt sunroof mod? midwestlegend Second Generation Legend (1991-1995) 21 07-14-04 03:41 AM
Moonroof problems nupe07 Second Generation Legend (1991-1995) 4 11-12-03 05:28 AM
Moonroof tilt complete - where do I sent my $20? James92LS Second Generation Legend (1991-1995) 93 11-01-03 12:10 AM
