O2 Sensor Replacement
Just changed the two O2 sensors and thought someone else might need a reference.
Tools required: 1. O2 Sensor socket 2. 18" extension 3. 2-3" extension 4. big long breaker bar (I had to use pipe as extension) 5. 10 & 12mm sockets/wrenches to remove other stuff Drivers Side is pretty straight forward: 1. Unplug O2 sensor at front of valve cover 2. Put O2 sensor socket on sensor 3. Take 18" plus 2" extensions and "thread" from behind brake fluid reservoir and attach to O2 sensor socket. 4. Add the breaker bar and pipe extension and break the sensor loose (only break it loose with the socket). Use your hands to unscrew, you can also just turn the wire harness and it will come undone on its own. 5. Reverse the order to install. (I used NTK 24172 sensors from NGK, they are direct fit so no wires to play with.) Passenger side takes a bit more work: 1. Remove black box by EGR valve 2. Remove 3 wire harness connectors by black box (harness clipped to heat shield) 3. Remove main wire harness connector at rear of valve cover 4. Remove heat shield (3 10mm bolts, the top 2 are not bad the 3rd one is hard as it is at the bottom below the A/C line and hard to reach). The heat shield will come out toward the front of the engine. 5. Now attach the O2 sensor socket to the O2 sensor 6. "Thread" the long extensions through the vacuum lines and then carefully using the breaker bar with extension break the sensor loose. Again remove by hand twisting the O2 sensor wire harness will make it easier. 7. Reverse the order to install. |
i did this a few months back, i went from 11mpg to about 20-22, mixed driving with a/c on. car is a 92 auto. used the same sensors as well. with fuel prices at 3.65, i appreciate the extra mileage!
92 4DR LS, 145k Type II rotors/calipers, brembo/hawk hps Stainless steel lines, ATE blue 17" OZ rims Addco rear sway bar Ksport coilovers Telion Chip |
www.ngk.com has the NTK 24172 for $49.85 ea. Did you find a less expensive source?
VIP Well Wisher
how long are these supposed to last? My gas mileage seems fine, but I'm almost at 215k miles. I'd replace them if in theory my gas mileage would get even better...
'94 GS 6MT Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather |
Mine had about 180k and was failing AZ emissions due to high CO, no CELs or anything but changing the O2 sensor dropped CO by 45% and reduced NOx by 60%. I bought my O2 sensor from www.ngk.com (same as www.sparkplugs.com) for $49.95 each plus about $9 for shipping and handling.
#8 (permalink) | |
Eyebrows KMS Strut Bar Enkei 16" J-Lips Wings West Spoiler w/LED Clear Corner Lens Clear Bumper Lens Clear Rear Side Markers Brembo X-Drilled/Slotted Stainless Braided Brake Hoses Focus 2500 Driving Lamps Gold Pkg Last edited by LPB : 07-08-07 at 10:28 AM. |
Excellent turn-around time. As luck would have it, I go to use my K-D 1/2" drive O2 Socket and I find my neighbor (forgot the motto: never lend tools) has rounded it over. Any consensus of O2 socket vs O2 wrench? Looks as if I am ordering a Snap-On 02 Socket. One step forward, two back.
I was given a Chilton's today (for a Maxima) and it recommended changing the Oxygen Sensor every 30,000.
#13 (permalink) | |
#14 (permalink) |
My check engine would come on at about 80mph. But if I kept it below 70mph It wouldnt. It started about 2 weeks ago. my average was 26.1 on the expressway doing about 70mpg with the rear O2 bad (code 2). I just changed both of mine on Friday last week. I believe the 20th of July. I havent notice any change, but the engine light hasnt come back on. What changes am I suppose to notice. I have 212,??? on the dash.
OH! I did notice a change though. when I hit the gas, said go. she go ![]()
| o2 sensor replacement | red4re | Engine & Performance Modifications | 1 | 02-26-07 04:29 PM |
| DIY: O2 sensor replacement | jackdanielsman | Second Generation Legend (1991-1995) | 0 | 06-03-05 06:02 PM |
| o2 sensor replacement / timing belt | remickz | First Generation Legend (1986-1990) | 11 | 04-01-05 03:57 PM |
| Is the speed Sensor replacement a DIY? | LLegend | First Generation Legend (1986-1990) | 7 | 09-28-04 02:09 PM |
| Replacement Oxygen Sensor | LegendGS | Second Generation Legend (1991-1995) | 24 | 08-25-04 03:29 PM |
