#16 (permalink) |
"the Don"
UPDATE!!
Ok, I confirmed my theory in my previous post and it works perfect!
Bypass the HEADLIGHT relay (the BIG relay) by CUTTING the RED/WHITE wire and the BLUE/RED wire that go into this relay. JOIN these two wires together on the ends that are no longer atatched to the relay (therefore bypassing hte relay). As for accessory source, I just took out my centre consol wood piece and splice into the WHITE/BLACK wire that goes into my cigarette lighter. This works like a charm. I will try and get a diagram with the headlight relay bypassed. This should solve your problems Roger and I apologize for not addressing this problem earlier. G
#17 (permalink) | |
This Won't Work Right!!!!!!
Just want to let you all know that there is a problem with Godfather's wiring. He said that he has figured it out but I haven't heard of the solution from him yet. If you do this, your foglights will QUIT WORKING after some time. Read my thread >> OEM Foglights 94/95 Sedan
Thanks, Pasha95GS Quote:
#18 (permalink) |
Dee the upstate Don
does anyone know if this still works or is there a better way or different way
weapon r intake, 5 wire grounding kit, Telion chipped, Type II intake Manifold, obx headers, custom y pipe coming soon... spec clutch stage 2, drill slotted rotors/brakes, Stromung exhuast and b Pipe, web cam regrinds, Kenwood DNX7100, custom paint job |
#19 (permalink) | |
DRL in JDM fog lights DIY |
