STOKED!!! Power passanger seat in L model! (DIY for 150bucks)
AFter many hours at looking at the wires and harness' on the seat and car, I hate Acura/Honda even more. There are soo many extra wires that are POINTLESS. <-- my vent
DIY power passanger seat: Step 1: Buy a used power passanger seat. (junkyard or car-part.com) Get the cheapest one you can. All you need are the chairs electronics. Step 2: With your new power seat, switch out your cusions/leather and put them on your newly obtained power chair. (clean it and lube up the motor rails) Step 3. Place the power seat into your car. The ONE and only harness you will work with is this Brown one (circled in green): ![]() (YOU DONT NEED THE PURPLE ONE) Step 4: Unbolt your drivers passanger seat and look for the BROWN harness. You will be tapping off this one. ![]() Step 5. splice the BLACK one and White w/ red line. Then get 2 wires that are 4ft long each. Connect each one and crimp it. ![]() ![]() Step 6. Now that it is connected, run the 4ft of wire under your carpet, through the console and under your carpet to the passanger side. Step 7. You will connect the ends of these wires to the associated color. The BLACK drivers side connects to the BLACK passangers side The White w/ red drivers side connects to the White w/ red passanger side. In my illustration, I had the connector. You will have to Crimp the wires together. I recommend you buy a connector incase you ever have to remove the seat. ![]() ![]() Step 8. TRY IT OUT!!!! Power passanger seat a. drivers side does not control passanger side b. passanger seat does not have UP/DOWN feature |
That is nice, I'm saving that to my DIY's documents.
That would be sick. Gotta a question though. By any power seat? wut type of seat? a used power seat of any car? thanks! |
great. i done it too and i tap the power from cigarate lighter. also pleace keep on mid if you getting only power tracks for your L seat , the plastic trim on the side will not align with the new tracks. so batter off is get the whole seat.
http://home.comcast.net/~nosferatu2xlc/94LS.jpg Sarasota FL 91 Gold Sedan L sold 94 Green Sedan LS sold 94 Milano Red Coupe LS sold WTB G2 6spd LS coupe |
#7 (permalink) | |
Hi! I'm Ryan.
Car 1: 95 Legend GS (Main Baby in Garage) & 94 LS Cpe 6 Speed (Main Driver & Fun) Car 2: 93 Legend LS 2dr 6sp iTrader: (2)
Kudos to the man with the plan.....
This is what makes this foum the best. Guys like you thinking out of the box and then showing how to get it done. I can't thank you enough. And word to anyone else with tips and full explanations (pics are great too), lets get those great ideas together!
I'm the one with the Limited Slip Differentials (LSD). We can build what you need!Users of LSDs: Newest Customer - sr79labrat Third - Me!! Second Customer - Kenso First Customer - LEgEnD4LiFe 95 Legend GS w/Koni shocks, all else stock 94 Legend LS Cpe 6-Speed w/Konis, Race Brakes, braided lines, AND the 3rd LSD built by us but the first to be installed!!!!! *New* - 86 CRX w/D16A Conversion Now with TURBO!! |
#12 (permalink) | ||||||
Took me so long to figure that out. I traced ALL the wires. ended up only using 2. I'm kindof mad beacuse it was so simpleQuote:
Thanks for the comments guys ![]() |
#13 (permalink) | |
L E G E N D
#14 (permalink) | |
So instead, in the near future, ganna buy aftermarket heated seat and connect them to the OEM heater buttons. EDIT: the other harness was used for all those options. I could tap off the main power supply, connect them to the OE seat heater switches and my passanger side would have heat. But then I don't get to use it ![]() |
| Added a power seat to my base sedan | 90acura149k | First Generation Legend (1986-1990) | 0 | 12-12-02 06:51 PM |
| Who installed a power passenger seat in their L? | g-man | Second Generation Legend (1991-1995) | 6 | 12-08-02 06:43 PM |
| Power Seat Memory Not Working.....any suggestions? | simgarcha | Second Generation Legend (1991-1995) | 2 | 09-06-02 04:25 AM |
| Driver's Power Seat Switch | 91 Legend Coupe | Second Generation Legend (1991-1995) | 3 | 08-20-02 09:01 AM |
| Passanger seat!? | René | Second Generation Legend (1991-1995) | 0 | |
