Windows Not Working? DIY: Master Window Switch Fix!! - Page 3 - The Acura Legend & Acura RL Forum
Old 11-20-07, 02:04 PM   #31 (permalink)
dumplin101's Avatar
Car 1: 95 cpe Type II 6sp :)
Car 2: 94 Legend- SOLD
iTrader Score: 6 reviews
hey thanks for the advice. i actually purchase a master window switch and still, my two driver side window will not work. do i need to purchase a motor or the window regulator? and how much are they running?
dumplin101 is offline   Reply With Quote
Old 11-20-07, 03:42 PM   #32 (permalink)
NYCOWNSU's Avatar
Car 1: It's gold had one stripe and says metro on it!!
Check to see if power is going to the window motors first. Two ways
1. Turn on inside lights, engine off, press the button. You should see a slight flicker, dimming if you will. Its real quick. Test it out on all buttons. If you see teh flicker then the main switch is probably not the problem. Then press the button on the switch of the window in question. Use the same theory, see what happens. If you do this and nothing happens then you should try pumping juice directly to the motor itself. There maybe diagrams on this site somwhere, or you can use a test light. This is more advanced however as you will need to know which wire is ground and which is power.
If you're sensitive over the internet, consider suicide, because real life tends to be worse.
Opinons are like assholes, there's always one whereever you go!
A newly formed forum/car club that is open to any car enthusiast.
http://redlinesoldiers.forumotion.com/index.htm
NYCOWNSU is offline   Reply With Quote
Old 11-21-07, 10:16 AM   #33 (permalink)
brodank's Avatar
Car 1: 1994 Legend GS BLK/BLK
Car 2: 1988 Toyota 4Runner
Car 3: 1955 Bel Air 4 door
Originally Posted by Ben Hedrington View Post
Here is how you do it...
(1) Remove the on/off switch unless it already fell off like mine.
(2) Stuff tin foil in tightly where the below graphic shows.
(3) Dress up as appropriate, the foil needs to be tight in there and could come loose occasionaly so don't over do it too much.
ok, i did steps 1-3 last night and my windows still dont roll down.....what next??
brodank is offline   Reply With Quote
Old 12-11-07, 02:06 AM   #34 (permalink)
coupe80's Avatar
Car 1: 91Acura legend LS coupe
All my windows work normal except my back passenger side window won't go up from the main driver switch. What's the solution?
coupe80 is offline   Reply With Quote
Old 01-03-08, 09:18 AM   #35 (permalink)
Car 1: Toyota Camry
Car 2: Acura Legend
Car 3: Honda Accord
Originally Posted by vIJ-Unit View Post
im having trouble wid my 91 legend window driver side. It wont go up ( close ). i had to take it to the shop they said i need a new master switch. Will this tin foil stragedy thing work too or no? All the windows work, up and down. its just the driver side that wont go up now. let me know, thanks
My 1995 Acura Legend driver side window will not go up or down. All the other windows are okay. What could be the problem? The power master switch or the motor itself? Any help is appreciated. Thanks.
dio2 is offline   Reply With Quote
Old 01-03-08, 11:29 AM   #36 (permalink)
dumplin101's Avatar
buy a new motor. I had the same problem and replaced it with one i bought on ebay. i dont even need the window to work, just that they wont tint my windows without it working. but replacing it should fix your problem
Old 01-03-08, 07:39 PM   #37 (permalink)
Work In Progress
Gnome Whack Champion
TeamLR2's Avatar
Car 1: acura legend 94 GS
NONE OF THE WINDOWS WOK BESIDES THE DRIVERS ANDTHE SUNROOF. WHHOW COULD I FIX THT WITHOUT TAKING IT TO A MECHANIC IF POSSIBLE
TeamLR2 is offline   Reply With Quote
Old 01-04-08, 12:38 AM   #38 (permalink)
ON DAT WAVE
Team LR's Avatar
Car 1: 92 Acura Legend LuxuryPerformanceSedan
Car 2: 97 BMW 528I
Car 3: 99 Montero Sport
Did u check the fuses
Team LR is offline   Reply With Quote
Old 02-07-08, 01:50 AM   #39 (permalink)
Making Legends Rare.....
Car 1: 1995 Legend GS
Not enough common sense to read the begining of the thread and you think he can find the fuses?
1993 Acura Legend Coupe LS
Automatic
About to be a 3.5L.....
gsdreams is offline   Reply With Quote
Old 02-10-08, 03:44 PM   #40 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
yall harsh on some of these cats lol
Originally Posted by Blackend
Old 04-13-08, 01:14 AM   #41 (permalink)
94legendcpe's Avatar
iTrader Score: 18 reviews
Can someone rehost the pics for this DIY or create some new ones? Money is tight right now, and I can't afford to shell out for a new master switch.
Thanks!
94legendcpe is offline   Reply With Quote
Old 04-18-08, 09:17 AM   #42 (permalink)
Car 1: Honda Legend
Hi, where's the child safety switch ? My rear windows does not work but front ones do. I checked the fuse, so before unmouting door's panel to check motors, if there's a switch for children please tell me where it is
Nekkro-Kvlt is offline   Reply With Quote
Old 04-18-08, 11:22 AM   #43 (permalink)
Not your master window switch if your passenger side front goes down. The child safety lock is on the master window switch at the bottom (the toggle button that only says 'On').
Anyone able to host the pics that were originally up or show me what the crafted aluminum foil piece should look like?
Old 04-18-08, 02:53 PM   #44 (permalink)
lloydapalooza's Avatar
Car 1: '89 legend sedan
Send a message via AIM to lloydapalooza
Originally Posted by asianlegend View Post
I think what you are referring to is different than what the original thread speaks about.
The folks earlier in this thread had a problem with the auto-down feature on the master window switch. In plain English, it wasn't going down with one-touch, but going down like any other window (i.e. you hold it until it goes down to the determined location of your choice). So, determined members found a quick, easy, and temporary way to fix the overly expensive and hard-to-find in good shape option of replacing the entire switch module.
What you describe sounds like a general issue with the switches, not specifically the auto-down feature. Thanks for the advice anyways, I'm sure it'll help others that are suffering the same problems.
has anyone found a way to fix the auto-down on the switch? my switch broke off and i tried gluing it back on but now it won't go to the second stop where it goes down automatically.
lloydapalooza is offline   Reply With Quote
Old 04-18-08, 06:06 PM   #45 (permalink)
Car 1: Honda Legend
Isn't that the switch for the auto function that the topic is about ?
