Blk/BlkGS6
Car 1: '94 Black/Black Legend GS Sedan 6 Speed Car 2: '92 Silver LS Coupe Car 3: '94 Cashmere L Sedan iTrader: (1)
go get some silicone spray and spray it in underneath (pull it back with ur hands) the rubber insulation that covers the outside edge of the rear of the window.
dw-40 will also work.
Black/Black GS 6 speed FS $3800 OBO Lots of mods/parts FS To contact me, e-mail desijigga786@gmail.com |
I'm too sexy for my car
Thats a good one there Luvmylegend.
But like everyone who has had the same problem as you all you have to do is get some silicone spray from either a hardware store or home depot and spray it down the channel run that the windows run through. It'll take awhile to work because you have to let it sit for awhile so it can soak in. |
I will add something to the silicone idea....
Get a whole wack of Qtips, and spray the end of it, and dig right inside the channel with them... you will see a nasty amount of grease come out. And you will need alot of Qtips becuz if they are slooooowwww, then they are pretty gummed up. It worked alright for me... go for it.. its better than replacing the motor, until it gets really bad and then you dont really have any other choice.
http://img.photobucket.com/albums/v6.../DSCN45691.jpg |
LegendaryLegendz.kom
Yeah, I did the silicone thing and my windows worked an a$$load better. I also like the idea of using the q-tips to clean out the channel. Should only take a few minutes to finish this.
Thanks, James "pYmpdaddi" Douglas Legendary Legendz CC Regional Officer, NorCal Chapter (916) 974 - PIMP (7467) http://www.legendarylegendz.com/files/LLCCgifsig.gif 17" Enkei RF-1's,Nitto 450's (215/45), Eibach Prokit Suspension, Royal Blue Painted Calipers, Clear Corners, Clear Bumpers, Clear Side Markers, Halogen Fog Lights, Ice Blue Halogen Headlights, Body Tone Lower Trim, Body Tone Taillights, Tricked-Out Trunk Lid, Custom Mesh Front Grill, White Acura Emblems, Bulldog Remote Starter, Mugen Indiglo Gauges, Indiglo Pedals, Custom Trunk Enclosure, 12" Rockford Fosgate Subs, 160x4 Rockford Fosgate Amp., Kenwood KDC716S Deck, Kenwood 6976 6x9's, Kenwood 1377 - 5 1/4's, 1" Super Tweeters, Hardwired Bel Radar Detector, Fog Light Flap Custom Mesh, Cold Air Intake, Custom front and rear Speaker Grills, Brushed Aluminum dash kit, BREMBO Dimpled / Slotted Rotors, PBR Metal Master Brak Pads and an old skool Legend.org decal. |
Swollen Member
Could also be the window regulator. If you notice that your window has a unusual amount of play (moves around) in it, that could be the culprit. I replaced my driver's side window motor this weekend only to find that several nylon bushings in the regulator are worn out, causing the window glass to move around in the track. FYI, a new regulator is $91.98 from Acura of Augusta (got one on the way). Later----
LEGEND
Hey how much is a new motor (passenger side) from acura of augusta and is it sold without the regulator?
http://img47.photobucket.com/albums/...se_resized.jpg 1997 Mitsubishi Eclipse GS-T Spyder 5spd Apex-i FMIC, Apex-i Intercooler piping, Apex-i Twin Chamber BOV, full 3" turbo-back Exhaust, 5300k McCulloch HIDs... Want something for free? Choose a link! Free Ipod or Iriver? http://www.mp3players4free.com/default.aspx?r=6890 Free Digital Camera? http://www.cameras4free.com/default.aspx?r=45645 Free Personal Video Player? http://www.pvps4free.com/default.aspx?r=45648 |
Swollen Member
Yeah, you can buy them separately and a new window motor is about $185. In retrospect, my window motor was probably OK and i just needed to replace the regulator. You can have my old one for $25 if ya want it. PM me if interested----
The track is where the window slides up and down. The actual peices of rubber and foam that go around the window at BOTH sides.
#15 (permalink) |
Swollen Member
Unfortunately, there's no way to replace just the nylon bushings. Honda makes MUCH more money selling you a new regulator. Good news is that the driver's side is probably the only one you'll ever have to replace 'cause it gets the most use.
A word of caution here----if you do replace the old regulator, be careful in removing the window motor. The regulator is spring-loaded and the tension is removed when the motor is taken off. A real finger-eater.... ![]()
