90 Legend...Ticking - The Acura Legend & Acura RL Forum
Old 08-04-10, 08:34 PM   #1 (permalink)
mmc
Car 1: 1990 First Generation Legend
Question 90 Legend...Ticking
Learning as I go...love my Acura!! My 90 Legend has been ticking..sounds like it comes from pass. side. Almost seems to go away at 30mph. I dont even know where to start...any help would be great. I fixed my main relay and got back on the road in no time because of this site...thank you for any help you can give me!
mmc is offline   Reply With Quote
Old 08-04-10, 09:21 PM   #2 (permalink)
Super Moderator
C27A1Legend'88's Avatar
Car 1: 1988 Acura Legend Coupe L
Welcome to the site.
Well these 2.7 engines have a problem with the valve lifters ticking on cold starts. Describe the ticking better and I'll see if I can narrow it down for you.
1988 Acura Legend Coupe L 5-MT
Truly Legendary...
C27A1Legend'88 is offline   Reply With Quote
Old 08-04-10, 09:21 PM   #3 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
more than likely it's sticking lifters, try using lucas.
Old 08-05-10, 07:05 PM   #4 (permalink)
mmc
ticking seems to be coming from right side of engine...sound seems to change as it idles(or i have been listening to it for too long) and the ticking gets faster as i accelerate....sometimes as i drive i think the ticking goes away
Old 08-05-10, 08:41 PM   #5 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Ya, its your lifters. Try adding some Engine Restore. That made the tick in my G1 go away for awhile.
Old 09-18-10, 02:19 PM   #6 (permalink)
Car 1: 1988 Silver Coupe 5spd
Engine Restore is the best additive I've ever used. It even cleared up some slight smoking. It doesnt just thicken the oil like the other stuff. Read the can for their claims about filling scratches in the cyl walls. Sounds a little far fetched but the stuff is great. Helps the tick a little, especially when its warm, but the tick is nothin to worry about.
jmkelly45 is offline   Reply With Quote
Old 09-22-10, 01:44 AM   #7 (permalink)
Car 1: 1989 Acura Legend L
A buddy of mine told me about seafoam. You pour some into your oil, suck some through a vacuum line and pour some in the gas tank. Putting it in the oil is suppose to help with the lifter tick and after I put it in and ran the car a little i definitely make it quieter. Sucking it through a vacuum line clears up the carbon build up and that is seem by all the smoke that burns off after. Putting it in the gas tank will clean the fuel injectors and acts as an additive in the gas.
mxsloan is offline   Reply With Quote
Old 09-22-10, 03:34 AM   #8 (permalink)
GI Joe Scuba Sweep Champion
Ophidian's Avatar
Car 1: 90 LS Coupe 5speed
iTrader Score: 11 reviews
Yeah, nothing to worry about. Does it go away at all after the car warms up?
Mine annoyed me so much that I had mine all replaced. Pricey tho, but sounds new now.
Ophidian is offline   Reply With Quote
Old 09-28-10, 01:59 AM   #9 (permalink)
Car 1: 87 ACURA LEGEND COUPE (BASE)
how much did it cost you to replace the lifters in your ac ???
AC-N-UP is offline   Reply With Quote
Old 09-28-10, 04:36 AM   #10 (permalink)
Ophidian's Avatar
$2000 usd!
Old 09-28-10, 11:26 PM   #11 (permalink)
Car 1: 87 Acura Legend
May sound odd but I had to replace my valve cover gaskets while doing it I decided to clean off the carbon from the valve covers. Put it back together and the Lifters barely tick anymore. with the windows up I can't hear it. I guess it helped the oil circulation. Sounds odd I know but it worked for me.
rion88 is offline   Reply With Quote
Old 09-29-10, 02:59 AM   #12 (permalink)
RLS
Car 1: 1995 Legend GS
I had a similar problem with my '95. Found it was a vacuum valve inside a cover, that's attached to the firewall, next to the passenger side valve cover. A mechanic friend removed the cover and tapped/twisted the valve housing and the clicking went away. I assume there is some sort of a check valve that was hanging up.
RLS is offline   Reply With Quote
Old 11-13-10, 10:54 AM   #13 (permalink)
mmc
tick
tick..tick..tick..tick....tick...gonna drive me nuts...did the cleaner, put in lucas...sometimes it ticks, sometimes it doesn't.. as long as it isn't hurting anything...
thank you....
Old 11-16-10, 09:53 PM   #14 (permalink)
Super Moderator
Just keeping changing your oil often and using a good filter and it shouldn't get any worse. I would recommend 3K intervals.
If you do this the tick will probably go away after some time.
Truly Legendary...
Old 11-22-10, 03:25 AM   #15 (permalink)
Ophidian's Avatar
Yeah, I dealt with mine for the last couple years... it just got to the point it annoyed me so much I had to get it fixed.... glad I did tho.
