Old 01-22-04, 04:12 AM   #1 (permalink)
Car 1: 1990 Gold Sedan
Cooling Fan Always On
Hello. I am having a problem with my radiator cooling fan system. From the time i start up the car in the morning to the time i get home from work at night, the cooling fan is running. This happens regardless of whether or not i have the A/C on or regardless of the temperature of the cooling system. The temperature of the coolant (via the gauge in the dash) acts normal...starts at the bottom when cold and creeps to the middle and stays there.
I know that the fan is not hardwired to 12V because the problem jsut started a couple days ago, and I realize that this is not really an immediate problem, but it is annoying. I don't know if this has to do with the fan control unit or the sensor or what. ANy suggestions on what to try?
six03e is offline
Old 01-22-04, 04:58 AM   #2 (permalink)
Car 1: 89 White Coupe
Do a search on cooling fan, a lot has been written on this & the search will give you lots of info plus save time.
89 White Coupe, 95 White/Silver SE
Johnny2 is offline
Old 01-22-04, 05:01 AM   #3 (permalink)
I did search already, all I found were cases where the cooling fan didnt' turn on and where both were turning on, neither of which is happenning.
six03e is offline
Old 01-22-04, 05:55 AM   #4 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Car 1: 1987 Legend LS Coupe
Are you getting a Check Engine light? Codes on ECU or TCU?
KAHruzer is offline
Old 01-22-04, 06:02 AM   #5 (permalink)
No, the check engine light isn't on. I haven't checked for ECU TCU codes, but i will post any if i see them.
six03e is offline
Old 01-22-04, 09:24 AM   #6 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
I did look in my Service Manual.
In the diagnostic symptoms chart, a continuously running fan was not listed as a symptom.
BTW, is it both fans, or just one (which)?
There is a Fan Timer Control unit on the side of the ECU, and a Fan Control Unit at the top of your brake pedal. Then, there's at least one Fan Relay in the under hood fuse box.
If I were going for one stuck in the ON position, it'd be the brake pedal.
I bet, though, you're getting a TCU Code 12.
KAHruzer is offline
Old 01-22-04, 01:00 PM   #7 (permalink)
What would a transmission control unit have to do with a cooling fan problem.
six03e is offline
Old 01-22-04, 01:34 PM   #8 (permalink)
Oh and by the way, th cooling fan comes on only when i have the key in number 2 position.
six03e is offline
Old 01-22-04, 02:31 PM   #9 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
>>What would a transmission control unit have to do with a cooling fan problem.<<
Yeah, it doesn't make a lot of sense to me either, but see this:
http://www.legend-forum.com/vbulleti...threadid=42280
KAHruzer is offline
Old 01-23-04, 06:25 AM   #10 (permalink)
6-Speed Member
Car 1: 90 & 94 LS Coupes
I have the same problem and it too only started recently. It is the condensor fan that is located to the left if facing the front of the car, correct?
I have replaced the Rad fan control unit with a new Oem unit last year, so I'm going to rule that out. I'm gonna try replacing the relay behind the windshield wiper reservoir and see if that does the trick.
pecan2phat is offline
Old 01-23-04, 06:27 AM   #11 (permalink)
Hey man, how much was the rad. fan control unit you replaced?
six03e is offline
Old 01-23-04, 06:42 AM   #12 (permalink)
Car 1: '89 LS Coupe (5 speed)
I got one for $2.50 at a junk yard a few months back. I pulled it myself...
pacallen is offline
Old 01-27-04, 03:08 PM   #13 (permalink)
6-Speed Member
$140 + shipping from ahmotor.com
My mechanic wanted $280 to replace the unit when I had him diagnose my non functioning fan problems.
Old 01-27-04, 03:47 PM   #14 (permalink)
God damn, that's not even worth replacing
six03e is offline
Old 01-28-04, 01:49 AM   #15 (permalink)
If you're talking about the little thing attached to the ECU (fan control unit), it is a $2.50 part if you go to a junkyard and find it. Heck, if you send me money for shipping I can send you one. However, there is a much more expensive part called the fan control relay which is hidden up underneath the dash which is a ***** to get to and is also a fairly expensive part to buy/labor to replace it. I had mine done at the Honda dealer and I got charged something like $200 or $250 for parts/labor.
pacallen is offline
