Old 11-09-07, 11:33 PM   #1 (permalink)
kclegend77's Avatar
Car 1: 1990 Acura Legend L
Car 2: 1984 Jeep Cherokee
Car 3: 90 chevy 2500forsale
DIY: interior cold cathode lighting
do this at your own risk. i do not assume responsibility if you screw your shit up.
so i decided to do some cool interior lighting using a computer cold cathode kit.
start by removing the lower dash covering.
Photo Sharing and Video Hosting at Photobucket
then you will wanna find a place to hide the control box. i put mine behind the center council plastics.
then you will want to wire up your switch. i used a 3 prong toggle style switch.
you have a power (12v constant), acc., and a ground. the acc. tab you will want to wire to something such as the radio or anything else that only has power when the key is to the ass. spot on the ignition. the ground you can just bolt to the fram under the dash.
mount your switch, mount your lighting and put it all back together, and your done. test drive and enjoy.
my lights are only temperarily mounted for the moment until i can get different mounting tabs. i am glad they are too because the only problem i saw with the way i did them is that you get glare on the side windows. so when i remount them i am going to put them farther back under the dash. i think by doing this it will get rid of the glare. so tell me what you think.
ok i feel really retarded. i completely screwed up on the explaining how to wire the switch. ok so you want the power tab connected to a spot like your radio fuse. on the acc. tab of the switch you want the positive wire for the cathode box. then tie the switch and the negative of the cathode box to the frame. wow sorry about that. wasn't in the right state of mind. my bad
kclegend77 is offline
Old 11-09-07, 11:35 PM   #2 (permalink)
Legend in the Making
Jerzeyboi85's Avatar
Car 1: Acura Legend 2.7 L 2dr || Engine: C27A1 || Chassis: KA3
Send a message via AIM to Jerzeyboi85 Send a message via MSN to Jerzeyboi85
Where do you get these "computer cathode tubes"?
R.I.P. 89 Legend Coupe
Driving now: 2000 Chevy Blazer LS
Future Toy: 92 Legend Sedan w/ deep dish 20's
Jerzeyboi85 is offline
Old 11-09-07, 11:38 PM   #3 (permalink)
kclegend77's Avatar
oops. i forgot to tell you where to wire the power tab on the switch. you want that wired to anything with a constant 12v. i wired mine to the constant wire for the kick panel lighting. it was super easy to do.
Old 11-09-07, 11:39 PM   #4 (permalink)
kclegend77's Avatar
ebay. i bought mine from a store called all_city. the were really cheap and work great.
Old 11-09-07, 11:43 PM   #5 (permalink)
kclegend77's Avatar
they have several colors too. as you can see i went with the blue.
Old 11-10-07, 12:01 AM   #6 (permalink)
COOLNESSSSSSSS
Old 11-10-07, 12:34 AM   #7 (permalink)
kclegend77's Avatar
oops i had to edit it already. its the bold section at the bottom of the first post.
Old 11-10-07, 12:51 AM   #8 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1989 White Coupe (dead) my baby!
Car 2: 1987 Brown Coupe L
Car 3: 1994 Accord Sedan EX
eh, never been a fan of blue interior lighting, although it is one of the most popular...never knew why. personally, when i was in the "i want cool lights in my car" phase, i wanted to get some black light bulbs.
IkeRay is offline
Old 11-10-07, 09:29 AM   #10 (permalink)
kclegend77's Avatar
yeah thought about doing the black lights but you would have to keep the car spotless all time or any spec of dirt would show up.
i am putting the white ones in the trunk once i get them off ebay.
Old 11-10-07, 03:16 PM   #11 (permalink)
I want to put green ones in.
Old 11-10-07, 03:36 PM   #12 (permalink)
87 legend for sale
crazyboy's Avatar
Car 1: 1987 acura legend 2 dr.
Send a message via AIM to crazyboy
i have blue lights on my floor too but i have them hooked up to the illumination wire on my radio so they come on with the lights
crazyboy is offline
Old 11-10-07, 03:41 PM   #13 (permalink)
^ cool. Gonna give that a try. Is there a particular reason why you use computer cathodes? Why not mini neons, or L.E.Ds?
Old 11-10-07, 10:44 PM   #14 (permalink)
kclegend77's Avatar
thats what was used in the trunk like mod so i thought they would work good for the interior too.
Old 11-10-07, 10:50 PM   #15 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Someone could also wire them up to the interior lights so that they come on with the domes when you get into the car...the brightness and visibility would be very nice I think...
Only problem I can see is that I dont think they were made to go on and off, on and off all the time, but rather stay on for extended periods at a time...it will most likely shorten their lifespan...also probably can't wire them up for the dimmer mod either ...
But hey they still look great in my opinion...of course I am also in the white light > blue light camp...
sam o nela is offline
interior lighting issues.. Katy253 First Generation Legend (1986-1990) 9 05-31-06 02:14 AM
Interior lighting fade-out z00m First Generation Legend (1986-1990) 4 04-19-05 08:12 AM
Interior Lighting shawn 3 time owner First Generation Legend (1986-1990) 1 02-21-05 02:37 AM
Interior Lighting 89Legend89 First Generation Legend (1986-1990) 18 07-15-03 05:33 PM
Interior lighting ChippsAChoi Second Generation Legend (1991-1995) 6 09-11-02 09:52 PM
