Engine not turning over... dash lights flashing with clicking... - The Acura Legend & Acura RL Forum
Old 04-03-04, 04:20 AM   #1 (permalink)
Car 1: 1988 Legend LS Sedan
(SOLVED) - Engine not turning over... dash lights flashing with clicking...
I posted the following link the other day and it still has not been solved I think... The car will not start now...
Strange elec. issue... SRS, door lock...
The car simply will not turn over now...
When I turn the key the dash lights come on bright but when I try to start the car it doesn't turn over. There seems to be a clicking coming from the dash and the dash lights flicker in accordance to the clicking.
The battery is fairly new (12 months) but I still put it on a charger for an hour to see if that helped. Same problem. Connections are good.
I have read through the forum and see that it could be the starter or maybe a relay. I am thinking that it is not the starter because of the previous strange electrical thing I am having.
I will have the battery tested this weekend.
Any ideas dudes...? The main relay...?
Thanks...
'88 LS Sedan, 129k
basil116 is offline   Reply With Quote
Old 04-03-04, 04:38 AM   #2 (permalink)
Car 1: 1989 Legend LS, A/T, Geneva Green, 15.9mpg!Runs like a champ, looks like a chump.
Send a message via AIM to WhenHeartsRunDry
Basil, check your private messages.
Maybe check the connections to everything. If you had your car worked on recently, maybe something came loose. My engine was really rough one day because of a loose spark plug wire.
http://www.imagestation.com/picture/...4/f9929fa2.jpg
Sig by Cole Austin
WhenHeartsRunDry is offline   Reply With Quote
Old 04-03-04, 04:48 AM   #3 (permalink)
Car 1: 1989 Legend Sedan White
With the clicking and all it sounds like a dead battery, but if you charged it for an hour I imagine the car would at least start. I'd almost wanna say alternator, but if the lights are nice and bright i dunno. Check yer ignition coil plug (it's the one right in the middle of the distributor and make sure you didn't knock it loose.
legendarywhite is offline   Reply With Quote
Old 04-03-04, 05:16 AM   #4 (permalink)
GS Hog
Golden Arrow Champion
LegendGS's Avatar
Car 1: 1994 Legend GS-Auto
Car 2: 1994 Legend GS-6 spd
Car 3: 1993 NSX-6 spd
Possible main relay, but it also sounds like your battery is dead. Charge it fully and try again.
LegendGS is offline   Reply With Quote
Old 04-03-04, 06:05 AM   #5 (permalink)
Victory is fleeting...
duck's Avatar
Car 1: 2007 Honda Ridgeline
Was it hot outside when you had this issue (80 degrees +)? If so, I'd start with the main relay. Try it when it's cool outside, in the shade, etc.
Rythmic, systemic and world control Magnetic, genetic, dement your sou...
duck is offline   Reply With Quote
Old 04-03-04, 06:59 AM   #6 (permalink)
Not hot...
I was not hot outsite... it has been sitting in my garage for 3 days now...
I will have the battery tested tonight...
Old 04-03-04, 11:10 AM   #7 (permalink)
per Haynes...and I'll skip the items you've mentioned : leaking fuel injector(s) fuel pump pressure regulator etc., fuel not reaching the fuel rail, Ignition components damp or damaged, worn faulty or incorrectly gapped spark plugs, broken loose or disconnected wiring in the starting circuit, loose distributor is changing ignition timing, broken loose or disconnected wires at the ignition coil or faulty coil.
ND1980LS is offline   Reply With Quote
Old 04-03-04, 11:45 AM   #8 (permalink)
S*preme Legend
Car 1: 1987 Blue Acura Legend 2 door 5 spd
Send a message via AIM to LEGENDCanadian
i had a similar problem and it was the main relay. I cleaned it out and never had problems again.
<img src="http://www3.sympatico.ca/buchler/signature.jpg">
http://groups.msn.com/Orenandfriends
Performance mods:
custom 2.25 cat back exhaust with vibrant muffler
weapon r intake
KVR cross drilled rotors
custom ceramic clutch and tranny (San Diego transmission)
custom strut bars (front and rear)
Bayou/Dinan stage 2 chip
17 inch rims
Interior mods:
momo shift knob
custom real leather seats brown tan 2 tone
Stereo mods:
Alpine head unit
Alpine in dash screen
2 12" pioneer subs
Rockford fosgate bd 500.1
Rockford fosgate 400.4
2 ferad capacitor
alpine 6.5" dddrive japanese rear speakers
AVI component 6.5" front speakers
12 disk alpine changer
Exterior mods:
JDM clear corners
90 tail lights
road boy fog lights
bmw side markers
LEGENDCanadian is offline   Reply With Quote
Old 04-03-04, 01:39 PM   #9 (permalink)
Car 1: 1988 Grey Legend L
My 88 Legend was doing this some times. I found out one of the distributer cables was frayed and it was arc'ing. Replaced my cables and it doesn't happen anymore. The cable that was freyed was the one to the coil.
Runestar
Runestar-88Legend is offline   Reply With Quote
Old 04-03-04, 09:14 PM   #10 (permalink)
Car 1: 95 SE, 89 Coupe, Lexus 430 Conv.
I'd say, battery, starter or solenoid, ign. switch, in that order.
White 89 Coupe & White/Silver 95 SE
johnny3 is offline   Reply With Quote
Old 04-05-04, 04:30 PM   #11 (permalink)
Car 1: 1990 Legend L sedan Grey
Like ND1980LS said in his post....battery cables. And I'll elaborate. Check both. Make sure connections are good at both battery terminals AND solenoid and ground side. Clean grounded connection AND connection at starter solenoid. Also make sure you check the cables themselves.
The quick way to test them is to use a set of jumper cables. Connect one end to the battery ground and another to a ground point... if car starts with no clicking...bad ground cable. Do the same with the red side using jumper cable from pos side of battery to starter solenoid. If it starts no prob you have a bad positive battery cable.
Legend1990L is offline   Reply With Quote
Old 04-05-04, 05:00 PM   #12 (permalink)
Basil, im from torrance, hit me up!
Sig by Cole Austin
Old 04-05-04, 06:48 PM   #13 (permalink)
Car 1: 1989 legend LS sedan
this happened to me while working on my sound, the power cable to the starter came loose, it would click and dash lights work too, i found the cable and plugged it back in and works fine.
lilvietguy69 is offline   Reply With Quote
Old 04-10-04, 05:55 AM   #14 (permalink)
The problem was a bad battery terminal... replaced and it is good to go... all that for that...
Old 04-10-04, 06:20 AM   #15 (permalink)
congrats !!!!!!!!!!
