faulty coolant temp sensor? - The Acura Legend & Acura RL Forum
Old 06-14-06, 10:52 AM   #1 (permalink)
acuralegend_racer's Avatar
Car 1: 87 Lgd 2Dr AT (RIP)
Car 2: 89 Lgd 2Dr MT (WIP)
I just recently had an engine light came up and it says code 6 meaning temp coolant sensor and I failed the DEQ test. Could this sensor cause me to fail the test? How can you tell if the coolant temp is faulty or not? Where is this coolant temp located? I think its located right by the coolant bleeder but tell me if Im wrong. Any help is appreciated.
OBX headers, HF cat, 2.5 exhaust, 2" dual muffler, weapon R CAI, groundkit wires, reduced weight, 5 spoke 17" Black w/polish lip rims, S/D rotors, glow guages, GT steering wheel, AEM pedals, kaminari kit, clear corners, jdm fog lights.
http://www.cardomain.com/ride/2943300
acuralegend_racer is offline   Reply With Quote
Old 06-14-06, 02:48 PM   #2 (permalink)
Qualified Driver
90Legendman(LS)'s Avatar
Car 1: 90LS Sedan
Car 2: 07 Suzuki GSXR 600
Yeah its right near the bleeder with a black wire connected to it..
90 LS Sedan
90Legendman(LS) is offline   Reply With Quote
Old 06-14-06, 03:59 PM   #3 (permalink)
24 Hours Rally Champion, Boat Rider Champion
1990Legend_LS_5spd's Avatar
Car 1: 99 Subaru Legacy
Car 2: 95 Ford Explorer
Car 3: 03 Ford Crown Vic
Send a message via AIM to 1990Legend_LS_5spd Send a message via MSN to 1990Legend_LS_5spd Send a message via Yahoo to 1990Legend_LS_5spd
it is below the bleeder and is a 2 wire sensor, the 1 wire sensor is for the gauge.
Originally Posted by Jrod@Buschur@ evowned.com
DSM's..... turning the everyday Joe into a tool throwing, foul mouthed, alcoholic since 1989.
1990 Legend LS Sedan 5 spd
1989 Legend LS Sedan Auto(For Parts, Bad Trans)
G1 FAQ
If Your Legend Stalls or Doesnt Start, CLICK HERE
1990Legend_LS_5spd is offline   Reply With Quote
Old 06-15-06, 09:57 PM   #4 (permalink)
Is this the cause to fail DEQ?
Old 06-15-06, 10:00 PM   #5 (permalink)
most likely, also how old are your O2 sensors? if you dont know when they were last replaced or if they are the orginals you should have them changed as well. Faulty CTS and slow O2 sensors will cause emissions to be high.
G1 FAQ
Old 06-18-06, 11:12 AM   #6 (permalink)
thanks for the reply. Yes Ive already replaced my o2 sensors and catalytic convert but Im still not passing DEQ. what does CTS stand for?
Old 06-18-06, 04:18 PM   #7 (permalink)
CTS stands for coolant temp sensor. It is the sensor that provides the temperature to the ECU to know if the engine needs to warm up.
For instance if the sensor has an open in the wiring or the sensor itself the ECU will see that the engine is -60 degrees farenheit and will richen the mixture way too much.
Mikey851 is offline   Reply With Quote
Old 06-20-06, 01:25 AM   #8 (permalink)
yea, who ever came up with TW ... i just dont know, i have never heard that term used before, its either ECT or CTS ( Engine Coolant Temp or Coolant Temp Sensor )
G1 FAQ
Old 08-10-06, 02:14 PM   #9 (permalink)
Coolant Temperature Sensor
Hello:
I pulled the ECU code and found that I have 6 flashes (which indicates Coolant Temperature Sensor) but one symptom I also have is after the car warms up say after driving 15 minutes or more if I turn the car off the car will turn but will not start until the car cools down and this is the problem for several weeks. I just replaced the main relay and i pulled the ACG fuse, I here the 2 relay clicks but have the same problem car will not start until car cools down. Once the car is started it will run forever with no stalls but don't turn it off! Based on the forum experience does this sound like a Coolant Temperature Sensor or something else?
theezy is offline   Reply With Quote
DTC Codes for Acura RL petthepeep First Generation RL (1996-2004) 13 04-17-14 03:05 AM
Why you should use Honda Brand Antifreeze Avarice DIYs 9 11-24-08 08:14 PM
Where Is The Coolant Temp Sensor?? spoonsivtecs Second Generation Legend (1991-1995) 1 02-09-05 10:51 AM
Coolant Importance Danny Second Generation Legend (1991-1995) 0 12-24-03 02:36 PM
Honda Coolant!!!! Phireant Second Generation Legend (1991-1995) 3 09-30-03 02:48 PM
