I started having this turning over but no start problem.
I checked the distributor and rotor. recent check and replace. I checked the Plugs & Wires. I checked the Distributor. ( I removed the wire from the distributor and turned the key to see If I got any fire). I got alittle fire sparks.I then checked my fuel Pump by disconnecting the line in from the filter then turning the key. Thats the only way I know. I dont hear any humming from the pump (then again I've never heard any from this car) and I didnt see any fuel coming from the lines.Does anyone have an Idea before I get another fuel pump.???
My smarts only reach so far. Unfortunately. Im un sure were the main relay is and were I should be listening for the click to come from.
Ive read were people spoke on it. Is it the small black box under the steering colum. inside the panel??
It's under the dash to the left of the steering column, probably right about knee level. I'm sure that if you did a forum search under "main relay", you'd find threads that are complete with pictures. It seems that there are slight variations in how they're mounted, but all that I've seen are held by a bracket with a single 10mm bolt. Sometimes that bolt is a bear to get to, and other times it isn't bad. Hopefully yours will be one of the latter. Good luck....
I think they can be had for around 40 or 50 bucks at parts houses - not sure what the dealer charges. You might try fixing yours - often it's just a matter of the solder joints going bad over time. BTW, here's a thread that shows some pictures:
who needs to know main relay location And here's a site that explains the repair: http://techauto.awardspace.com/mainrelay.html Catch you later... |
#7 (permalink) | |
489,000 km's stil going
Our pump is very quiet. Although a rolled up newspaper or a tube stuck in the filler hole will help you hear it and fiter out some of the surrounding noises. (Like buses and planes and passing cars) |
Ok, well I removed the main relay. checked it out. didnt look bad (from what I can see) But that doesnt make since because how do I look to see if its bad. Didnt look to have any damages welds (solderings) so I re-enstalled it. rechecked the fuel pump for noise and fuel coming from filter. still none. Im thinking to go to a junk yard tomorrow for Pump. I dont have 130.00 that Autozone wants.
That's not a bad idea - the pumps are pretty robust and don't fail often.
BTW, did you hear the main relay click when you turned the ignition to the "on" position? If it clicked and you're getting no fuel and no noise from your pump, then you can be pretty sure it is the pump. |
FRISCO LEGEND BABY!!!!
r u sure u have gas in the tank? just wondering lol
______________ 18" Limited 341 Chrome Rims/\Matador Red Paint/\Weapon R - Secret Weapon Intake/\LED Bright White Dash Lights/Floor/\Kenwood KDC-X590 Excelon Mp3 Deck/\Ford Taurus Coin/Cup Holder/\2 12" Kickers/\1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp/\2 Rockford Fosgate Capacitors/\Power Acoustic Capacitor/\Clear Rear Turn Signal/\Reverse Glow Gauges/\Swapped 88' Headlights to 89'-90'/\JDM Rear Chrome Trim/\Stromung Muffler/ Soon To Come: Rebuild Motor and 5-MT Swap
303 Customs
You can use a funnel and stick it down the filler neck while someone is turning the key to the on position to see if you can hear the pump turning on or not. Next get a rubber mallet and gently tap on the bottom of the fuel tank, if you can get the pump to turn on for a second its most likely your fuel pump. If those don't work find your self a digital multi meter and get access to your fuel pump main relay, first test voltage positive wire from the DMM on the battery + wire(Yellow with a blue or black tracer) before the relay and negative on a good ground (chassis or battery Neg termal best) with the key in the on position then test voltage after the relay both of those should be 12volts or more. Next check your current draw (Amperage) of the fuel pump circuit, get your DMM and attach it in series with your fuel pump curcuit positive on your battery + side(Yellow with a blue or black tracer) of the main relay and negative on the wire going to your fuel pump(Black or blue with a yellow tracer) with key in on position, should be anywhere from 4 to 8 amps. If higher check fuel filter first, if too low check the ground to the pump for excessive resistance should be no more than .3 ohms of resistance remember to do this with a dead circuit(No power running threw the circuit.
Give me an update with your results
#14 (permalink) |
The Funny thing is. I drove the car to get the emissions test. Afterwards drove to the gas station filled it up. drove home and parked it in the garage. then drove the Cadillac. I then desided to part the Cadillac, but when I got ready to move the Acura. All it did was turn over. the next morning. I went out and it started. I let it run for about 15 minutes then shut it off. (had to head to school, didnt want to chance it, so the Cadillac it is) Then a few days after that. (around 9-15-2007) I figured Id Drive the Acura. and it just turns over. thats leads us to were we are now.
| fuel pump.... | 89legend1 | First Generation Legend (1986-1990) | 4 | 06-23-07 12:21 AM |
| Most likely fuel pump eh? | theGodfather | Second Generation Legend (1991-1995) | 7 | 05-25-07 09:04 AM |
| fuel cap/fuel pump???? | dr_love2112 | First Generation Legend (1986-1990) | 7 | 07-20-05 03:55 AM |
| Need help. Fuel Pump. | 15.2_StockLegend | First Generation Legend (1986-1990) | 1 | 09-18-03 07:21 PM |
| Fuel pump | 90acura149k | First Generation Legend (1986-1990) | 2 | 04-13-03 02:29 AM |
