Old 12-26-02, 08:25 AM   #1 (permalink)
Car 1: 88 legend coupe L - JDM eng
starting problem fix it guide
heres a DIY for a bad fuel pump or anything involveing nothing happening when you turn the key. I thought this might get some more attention then in the DIY section this way you will all know when it happens.
Find the problem, (check all fuses first)
if you turn the key and nothing happens listen for 2 clicks, 1 following the other in about 1 sec. they should come from the panel below your steering wheel. near the back above the brake pedal. thats your Main relay it supplies a direct 12v line to the fuel pump. Also listen for the buzz of the fuel pump, there very quiet in the legend so go into the trunk and put your head right in the middle at the back on the ground. no matter what you will hear something if its working. now you only have to the key 2 turns to start up the fuel pump and it only does it for 2 seconds
- IF NOTHING HAPPENS at all or any dash lights dim or anything electricaly different happens. move the key around and give the steering colum a good whack. if that fix's your problem the ignition switch is going something common on legends. i havent had it happen yet though. for that just take apart the steering colum and give it a cleaning and fix whatever broke. or replace contacts, solder in some metal.
- NO CLICKS, check for a 12v signal on the yellow wire, it might have a black stripe or any color stripe depending on where your from. jsut check them all for a 12v signal for 2 seconds when the ignition switch is turned to the second pos. only one has a 12v for 2 secs. the white wire is the switch from the key ignition. so if its not working then its the ign switchs (where the key goes in) . the Light green wire is the power supply so it should have 12 v all time. so if you have 12v somewhere and no clicks when you turn on the car replace the main relay. its located right above the brake petal. just take out the 2 screw for the dash panel (bottom one) then reach around and unclip the panel. the Relay is the one with 8 wires its black or white and up top, very easy to see.
- HAVE CLICKS, and a 12v signal leaving on the yellow wire( the one that goes on for 2 secs when you switch the igntion to pos 2) go into the trunk remove everything take off the floor cover and the sq hard piece. you will see the grey fuel pump cover its got 4 10mm bolts on top. in there you have the fuel pump on the left and the gas level sens on the right. pull apart the connecters the right way and check for 12v at the 2 prongs. If you have no power the line is broken somewhere. if you do have power your fuel pump is dying or dead. give the car a good couple hits with a open hand around the fuel pump cover hole. if it starts makeing noise then you have a dead spot in the motor. you burnt it out from running to low on gas too often.
- REPLACING IT make sure you relieve the fuel pressure with a rag over the 12mm banjo bolt.either the one in the trunk or on the fuel filter. the fuel pump banjo bolt is a 14mm. ( a banjo is the one with the bolt on top and fuel line coming out of the side ). remove all the bolts, pull off the other hose line. Lift it out, might need some wiggiling. go get a new one or aftermarket. i reccomend honda for anything you change on a car if not get a japanese company like denso or ngk. they will work the best. use the kit and cut the wires from the leads on the pump to the terminals on the housing. Cut somewhere in the middel, splice in the new wires with the provided crimps.
DON't forget the fuel pump only makes noises when you turn the key to pos 2, and it only does it for 2 seconds,
No power to the main relay check the fuse box. Im sure this will help sometime.
88 Legend coupe L Auto
c27a1 JDM Engine non-cat version 9.4 c/r
currently :dead auto
86 Legend 4d auto
c25a1
currently:stock and running, soon to recieve my 88s JDM motor and manual tranny
pyros88legendcoupe is offline
Old 12-26-02, 02:17 PM   #2 (permalink)
Legendary Dai Lo
C25A1guy's Avatar
Car 1: 2002 Acura RSX
Car 2: 2006 Honda Ridgeline
Good post!!! Oh, and DON'T SMOKE WHEN WORKING ON THIS SYSTEM!!!!!!!!!
Thanks To my sponsors and affaliets: M1 Autobody, ICB Motorsports, Honsport, Sierra Acura of Alhambra, Import Parts, Hondata, E Auto Parts, New Century Auto, APR Performance, Toyo Tires, Buddy Club, Torco Oils
C25A1guy is offline
Old 12-30-02, 05:19 PM   #3 (permalink)
someone want to move this the DIY so it could be useful.
86 Legend 4d auto
c25a1
Old 09-06-05, 01:48 PM   #4 (permalink)
Car 1: '92 ls sedan forest green
Oh, You have no sense of ADVENTURE
logic is offline
Old 11-24-06, 08:08 PM   #5 (permalink)
Car 1: 1990 Acura Integra LS
I have a intermittant problem, It wants to run fine in Idle but a couple of times a day it won't let you press the gas, it spits and sputters and you have to baby it out of traffic. I checked the connection to the Fuel pump and it is secure. It starts fine and Idles ok. We drained the tank when we installed a new "japan 60, 000 mile motor. The fuel gauge doesn't work either. Any clues.
major_kool_dad is offline
Old 11-09-07, 03:53 PM   #6 (permalink)
L E G E N D
Mikeo's Avatar
Car 1: 1989 Acura Legend (Coupe) Ls
my car clicks 2 times in only the morning.
Mikeo is offline
Old 11-10-07, 02:41 AM   #7 (permalink)
489,000 km's stil going
TO90LEGEND's Avatar
Car 1: 90 Legend V6L
Car 2: 93 Indy P/C Camaro
Car 3: 83 Trans AM
I'm guessing you are talking about a "teg" not a legend?
Fuel filter, check your fuel pressure & flow?, Could be old wires, cracked or worn distributor cap affected by condensation as it warms up. A sensor that sometimes thinks the engine is cold when its warm, so it may have a rich mixture? An intermittent vacuum problem of some sort - EGR comes to mind? Any engine codes?
TO90LEGEND is offline
Old 11-11-07, 01:52 AM   #8 (permalink)
Legend Lover
89redcoupe's Avatar
Car 1: 1988 Acura Legend Coupe Auto
Car 2: 1996 Cavalier R.I.P
Send a message via AIM to 89redcoupe Send a message via MSN to 89redcoupe Send a message via Yahoo to 89redcoupe
Hey TO90LEGEND check post dates!
89redcoupe is offline
Old 11-11-07, 10:43 AM   #9 (permalink)
TO90LEGEND's Avatar
Car 3: 83 Trans AM
crap, zombie thread got me.
