Old 08-22-07, 02:22 AM   #1 (permalink)
Car 1: 1990 Acura Legend V6 L
G1 EGR Cleaning DIY?
I was wondering if anyone had a DIY EGR cleaning for a G1 Sedan.
1990legend_V6L is offline
Old 08-22-07, 03:00 AM   #2 (permalink)
RedCoupe89's Avatar
Car 1: 89 Acura Legend Coupe
Send a message via AIM to RedCoupe89
A idle air control valve diy too my car dosnt idle 100 percent perfect.
Custom Intake
12" Subs, Crossfire amps for subs and deck, cap.
APC strut bar
17 inch rims (soon intrax/tokickos)
Hi flow cat (soon custom exhaust)
Hi amp altenator, optima battery
Slotted/drilled rotors, hawk hps brake pads, dot 4 fluid
22% Window tint all the way around
RedCoupe89 is offline
Old 08-22-07, 03:57 AM   #3 (permalink)
Car 1: Legend 89 Coupe
i dnt kno much about cars, but from what iv read, could it be the temp sensor? and damn...your car is so clean!! envy. how many k's it done
leadfoot_legend is offline
Old 08-22-07, 08:36 AM   #4 (permalink)
Untactfully Ghetto
mrtouchedme's Avatar
Car 1: 06 Nissan Altima SE-R
Car 2: 08 Sentra SE-R SpecV
Car 3: 02 Isuzu Rodeo 4x4
Send a message via Yahoo to mrtouchedme
found this in the DIY section
EGR operation and vacuum diagnostics:
Need a big favor....
EGR pipe cleaning info:
Best Way to Keep EGR Clean?
More EGR pipe cleaning info:
More EGR pipe cleaning questions
EGR removal DIY (for G2, but helpful anyway)
DIY - EGR Removal Pics
mrtouchedme is offline
Old 08-22-07, 08:50 AM   #5 (permalink)
Untactfully Ghetto
quoted this from another thread....
Originally Posted by pnoye2 View Post
EACV/IAC valve is a stealership part only and it'll cost you about $250.00 + tax, brand new... I'd suggest you try the cheap route 1st, check and see if your vacuum system is airtight, here is how you'd go about doing this, you'll need a can of brake cleaner; start by running the engine to normal temp., then hit ALL vacuum hoses and connectors with the brake cleaner, if the idle surges then you've found your vacuum leak.
Also, try cleaning the EACV/IAC valve and the fast idle valve, most likely, you've got some good amount of carbon build up in there, you can use a carburator cleaner for this one, spray inside EACV/IAC valve until you can clearly see the white plastic belows, same cleaning procedure for the fast idle valve and don't forget to replace them o-rings (stealership item), 1 figure8 for the fast idle valve and 2 regular o-rings for the EACV/IAC valve, hopefully this will address your problem, good luck!
Old 08-22-07, 03:19 PM   #6 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1997 BMW 528i
Car 2: 1994 Accord Sedan EX
Car 3: 1987 Legend Coupe
http://acura-legend.com/vbulletin/sh...ad.php?t=68912
try those, i edited all the links so they are complete, and yes they all work
IkeRay is offline
Old 08-22-07, 05:42 PM   #7 (permalink)
(my old red 88L r.i.p.)=(
89LSCOUPE's Avatar
Car 1: 1989 Legend LS coupe
Car 2: 2006 TL supercharged
Send a message via AIM to 89LSCOUPE
man i gotta send you a pic of my old 88L coupe slammed on 17's....
(you gotta lower that thing man, get the intrax springs, if they still make them...this was back in '99)
1989 Green LS Coupe
218k/5speed/new everything/needs leather!restoring back to perfection...
2006 Blk.Blk. 6speed TL
Comptech supercharged/thermoblok gaskets/shortshift
Type S wheels/21k
89LSCOUPE is offline
Old 08-22-07, 05:44 PM   #8 (permalink)
Untactfully Ghetto
sorry...I just copy and pasted from the DIY thread...don't know why they didn't work
Old 08-22-07, 06:59 PM   #9 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
because you copied the text and the text includes "..." in the middle of the link so as to save some space. for future reference, if you want to copy and paste from a different thread, hit quote and then copy from the post reply page, that way you will have complete links.
and nobody was yelling at you, great job at digging that up for us.
IkeRay is offline
Old 08-22-07, 08:20 PM   #10 (permalink)
Untactfully Ghetto
wasn't accusing you of yelling...just apologizing for posting incorrectly...
Old 08-24-07, 02:48 AM   #12 (permalink)
take that; take that
pnoye2's Avatar
Hmmm no G1 EGR stuff huh? Well I guess I have a project for the weekend huh!?
^^^ I wouldn't recommend performing this task just because Gabe... unless, your car is in need of a coolant flush (among other things) them EGR and air suction pipes would be impossible to remove with the water passage (plenum) STILL attached to the intake manifold.
I know it has to come off, that's how I did mine last time my EGR system got serviced.
pnoye2 is offline
Old 08-24-07, 02:51 AM   #13 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
I was actually thinking about doing it on my parts car because the hood, Radiator, condenser, intake plumbing, and headlights have all been removed...therefore it'd be pretty easy for everyone to see what I'm doing...
Only problem is that once I finish the job and put it back together, I cant start the car to feel the difference
sam o nela is offline
Old 08-24-07, 03:11 AM   #14 (permalink)
pnoye2's Avatar
Oh, I forgot about your parts car ... In that case, carry on
pnoye2 is offline
DIY: Intake Manifold Removal and EGR Cleaning petthepeep First Generation RL (1996-2004) 15 04-17-08 12:29 AM
More EGR pipe cleaning questions DallasLedge89 First Generation Legend (1986-1990) 4 05-08-06 07:35 PM
EGR valve cleaning DIY? Coderb64 Second Generation Legend (1991-1995) 3 06-12-05 05:38 AM
cleaning EGR system Goofball First Generation Legend (1986-1990) 0 12-14-03 04:21 AM
cleaning EGR system Goofball First Generation Legend (1986-1990) 5 11-24-03 11:40 PM
