Old 07-13-06, 03:42 AM   #1 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
G1 Online Manual Table of Contents
This is an initial attempt at making a table of contents for Maytag's PDF Coupe Manual. I will be updating this original post with any additions we come upon later.
THANKS AGAIN MAYTAG AND ESSEX FOR HOSTING THE MANUAL FOR US!!
SECTION.......................................PAGE #
GENERAL
~VIN Number Breakdown.....................2
~General Info...................................3-17
~Abbreviations Used..........................18
~Special Tools..................................19
~Specs...........................................2 4-35
~Maintenance Schedule.....................36
~Tune Up........................................37-45
ENGINE SECTION
~Timing Belt.....................................46
~Cylinder Heads................................53
~Engine Removal/Installation...............64-71
~Intake Manifold...............................72
~Exhaust System..............................72-76
~Cooling System...............................77
~Enigne Block (all internal components).83-101
~Oil (Lubrication) System...................102
~Component Locations......................110
~Vacuum System and Diagrams...........114
~Electrical Components Diagrams.........125
PGM-FI (Check Engine) SYSTEM
~Symptoms to Systems Chart..............128
~ECU Codes/Testing Procedure............130
~O2 Senors......................................136
~Mixture Compensation (Non USDM)......138
~MAP Sensor....................................140
~Crank/CYL Sensor............................144
~TW Sensor.....................................148
~Throttle Angle Sensor.......................150
~TDC Sensor....................................152
~TA Sensor......................................155
~IMA Sensor.....................................157
~PA Sensor.......................................159
~Ignition Output Signal........................161
~Vehicle Speed Pulser.........................163
~Ignition Timing Adjuster.....................165
IDLE CONTROL SYSTEM
~System to Sub-System chart.............167
~EACV............................................. 168
~Starter Signal..................................171
~Alternator FR Signal..........................172
~A/T Shift Poisition Signal....................174
~P/S Oil Pressure Signal.......................176
~M/T Neutral Switch Signal..................177
~Clutch Switch Signal.........................178
~Fast Idle Control...............................180
~Idle Speed.......................................181
FUEL SYSTEM
~Symptom to Subsystem Chart............182
~Fuel Pressure (Inspection/Relieving)....183
~Fuel Injectors.................................185
~Injector Resistor..............................186
~Pressure Regulator...........................186
~Fuel Filter.......................................192
~Fuel Pump.......................................193
~Main Relay......................................194
~Fuel Tank.......................................197
AIR INTAKE SYSTEM
~Symptom to Subsystem Chart............198
~Throttle Cable.................................199
~Throttle Body..................................200
~Dashpot System..............................202
~Bypass Control System......................203
EMISSIONS CONTROL SYSTEM
~Symptom to subsystem chart...............208
~Tail Pipe Emmison...............................209
~Catalytic Converter............................209
~Air Injection System...........................210
~EGR System......................................212
~PCV System......................................216
~Evaporative Emissions Control..............217
~Resonator Control System...................219
CLUTCH
~Clutch and Manual Transmission.........221-244
AUTOMATIC TRANSMISSION
~Auto Tranny and flow charts..............245-302
POWER STEERING
~Power Steering System......................303-355
SUSPENSION
~Suspension System...........................356-380
BRAKES (including ABS)
~Braking System.................................381-452
BODY
~Doors/Windows.................................453
~Sunroof (Removal/Installation).............488
~Seats............................................ ..496
~Console.......................................... .504
~Carpet........................................... .505
~Dash............................................. .506-509
~Bumpers.......................................... 510-512
~Hood/Trunk......................................512-518
CLIMATE CONTROL SYSTEM
~Heater........................................... ..519
~Auto Climate Control...........................547
~A/C Compressor.................................590
~Evaporator/Condensor.........................598
ELECTRICAL SYSTEM
~Overview......................................... .612-641
~Ignition Switch...................................642
~Starting System.................................644
~Ignition System..................................656
~Charging System (alternator)................666
~Cooling Fan Control System..................670
~Gauge Assembly.................................678
~Lighting System.................................721
~Stereo Sound System.........................750
~Clock/Horn/Trunk Pop/Cig Lighter..........755-762
~Power Door Locks...............................763
~Power Seat.......................................770
~Sunroof.......................................... ..780
~Power Door Locks...............................785
~Power Windows/Mirrors........................794
~Wipers/Washer...................................802
~Cruise Control....................................818
I'll be updating the middle sections in more detail as time goes on....
sam o nela is offline
Old 07-13-06, 12:24 PM   #2 (permalink)
putting the ass in class
bandoni™'s Avatar
Car 1: 90 honda accord ex5speed
Car 2: 89 legend sedan auto
Send a message via MSN to bandoni™
oh man this is awesome, no more opening 20 pages just to find 1.
sig by doubleglow the sigwhisperer
ƃuıʇsod ǝɹoɟǝq ɥɔɹɐǝs plnoɥs sɹǝsn ʍǝu
join the acura legend flickr group
visit my flickr page
bandoni™ is offline
Old 04-17-08, 09:28 AM   #5 (permalink)
Ophidian's Avatar
Car 1: 90 LS Coupe 5speed
Where can I buy one of these Helm manuals for the G1? A service manual...helminc.com didnt have any for G1...
35% Tint
New Paint
MA 6.5" front
Cold Air Intake
H.O. Alternator
Eclipse AVN6610
JL Audio A4300 amp
Focal Access 6x9's rear
Stromung muffler from GB
Clifford Matrix 50.5x alarm
Waiting to be installed:
Front strut tower bar
2 Orion HCCA 2100 amps
2 12" Cadence Daytona competition subs
Ophidian is offline
Old 04-17-08, 01:32 PM   #6 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
This is referring to the factory service manual....I'd try to find one of those from a member on here or ebay....otherwise the dealership but they arent cheap....
Old 06-04-08, 07:03 AM   #7 (permalink)
Heavy Metal Maniac
krieger's Avatar
Car 1: Honda Legend V6 2.7i
Send a message via MSN to krieger
Hmm, anyone seen a G1 sedan (KA4) manual around?
The location for the ABS controller mentioned in this manual differs from
the location its in my car.
krieger is offline
Old 07-21-08, 06:28 PM   #8 (permalink)
Car 1: 88 Legend Coupe
Update to service manual?
The last 500 or so pages are corrupted and blank when you scroll to them but parts are readable. Any chance there is a file of this PDF that is without errors?
Thanks!
88' Legend Coupe, purchased 9/07
Florence Blue Metallic
In restoration process:
1)fixed surging problem - new plugs and ignition wires
2)fixed oil leaks - replaced all 4 engine cover gaskets
3)replaced front 02 sensor
4)replaced instrument cluster circuit board
To do:
1) fix cruise control
2) polish paint, detail trim
happygomez is offline
Old 07-25-08, 11:59 PM   #10 (permalink)
Car 1: 88 Acura Legend
I just bought a digital copy of the 88-90 Legend service manual and a hard copy of the '87. If anybody is interested or needs something from these, let me know.
stevezone is offline
Old 09-11-08, 06:46 AM   #11 (permalink)
Car 1: 1989 ACura legend sedan
Send a message via AIM to 2coo1
stevezone is that manual also for the sedan?
2coo1 is offline
Cool Site - Online Workshop Manual G1 ZAV First Generation Legend (1986-1990) 48 08-28-06 01:15 PM
Online service manual question DT98 First Generation Legend (1986-1990) 2 04-29-06 02:09 PM
weird online manual Jay P First Generation Legend (1986-1990) 1 01-26-05 02:31 AM
UK online manual digger89L First Generation Legend (1986-1990) 3 09-27-04 04:04 PM
