CAP CAP M* F*R!
G1 Online Manual Table of Contents
This is an initial attempt at making a table of contents for Maytag's PDF Coupe Manual. I will be updating this original post with any additions we come upon later.
THANKS AGAIN MAYTAG AND ESSEX FOR HOSTING THE MANUAL FOR US!! ![]() SECTION.......................................PAGE # GENERAL ~VIN Number Breakdown.....................2 ~General Info...................................3-17 ~Abbreviations Used..........................18 ~Special Tools..................................19 ~Specs...........................................2 4-35 ~Maintenance Schedule.....................36 ~Tune Up........................................37-45 ENGINE SECTION ~Timing Belt.....................................46 ~Cylinder Heads................................53 ~Engine Removal/Installation...............64-71 ~Intake Manifold...............................72 ~Exhaust System..............................72-76 ~Cooling System...............................77 ~Enigne Block (all internal components).83-101 ~Oil (Lubrication) System...................102 ~Component Locations......................110 ~Vacuum System and Diagrams...........114 ~Electrical Components Diagrams.........125 PGM-FI (Check Engine) SYSTEM ~Symptoms to Systems Chart..............128 ~ECU Codes/Testing Procedure............130 ~O2 Senors......................................136 ~Mixture Compensation (Non USDM)......138 ~MAP Sensor....................................140 ~Crank/CYL Sensor............................144 ~TW Sensor.....................................148 ~Throttle Angle Sensor.......................150 ~TDC Sensor....................................152 ~TA Sensor......................................155 ~IMA Sensor.....................................157 ~PA Sensor.......................................159 ~Ignition Output Signal........................161 ~Vehicle Speed Pulser.........................163 ~Ignition Timing Adjuster.....................165 IDLE CONTROL SYSTEM ~System to Sub-System chart.............167 ~EACV............................................. 168 ~Starter Signal..................................171 ~Alternator FR Signal..........................172 ~A/T Shift Poisition Signal....................174 ~P/S Oil Pressure Signal.......................176 ~M/T Neutral Switch Signal..................177 ~Clutch Switch Signal.........................178 ~Fast Idle Control...............................180 ~Idle Speed.......................................181 FUEL SYSTEM ~Symptom to Subsystem Chart............182 ~Fuel Pressure (Inspection/Relieving)....183 ~Fuel Injectors.................................185 ~Injector Resistor..............................186 ~Pressure Regulator...........................186 ~Fuel Filter.......................................192 ~Fuel Pump.......................................193 ~Main Relay......................................194 ~Fuel Tank.......................................197 AIR INTAKE SYSTEM ~Symptom to Subsystem Chart............198 ~Throttle Cable.................................199 ~Throttle Body..................................200 ~Dashpot System..............................202 ~Bypass Control System......................203 EMISSIONS CONTROL SYSTEM ~Symptom to subsystem chart...............208 ~Tail Pipe Emmison...............................209 ~Catalytic Converter............................209 ~Air Injection System...........................210 ~EGR System......................................212 ~PCV System......................................216 ~Evaporative Emissions Control..............217 ~Resonator Control System...................219 CLUTCH ~Clutch and Manual Transmission.........221-244 AUTOMATIC TRANSMISSION ~Auto Tranny and flow charts..............245-302 POWER STEERING ~Power Steering System......................303-355 SUSPENSION ~Suspension System...........................356-380 BRAKES (including ABS) ~Braking System.................................381-452 BODY ~Doors/Windows.................................453 ~Sunroof (Removal/Installation).............488 ~Seats............................................ ..496 ~Console.......................................... .504 ~Carpet........................................... .505 ~Dash............................................. .506-509 ~Bumpers.......................................... 510-512 ~Hood/Trunk......................................512-518 CLIMATE CONTROL SYSTEM ~Heater........................................... ..519 ~Auto Climate Control...........................547 ~A/C Compressor.................................590 ~Evaporator/Condensor.........................598 ELECTRICAL SYSTEM ~Overview......................................... .612-641 ~Ignition Switch...................................642 ~Starting System.................................644 ~Ignition System..................................656 ~Charging System (alternator)................666 ~Cooling Fan Control System..................670 ~Gauge Assembly.................................678 ~Lighting System.................................721 ~Stereo Sound System.........................750 ~Clock/Horn/Trunk Pop/Cig Lighter..........755-762 ~Power Door Locks...............................763 ~Power Seat.......................................770 ~Sunroof.......................................... ..780 ~Power Door Locks...............................785 ~Power Windows/Mirrors........................794 ~Wipers/Washer...................................802 ~Cruise Control....................................818 I'll be updating the middle sections in more detail as time goes on.... Last edited by sam o nela : 03-03-07 at 12:53 PM. |
putting the ass in class
oh man this is awesome, no more opening 20 pages just to find 1.
sig by doubleglow the sigwhisperer ƃuıʇsod ǝɹoɟǝq ɥɔɹɐǝs plnoɥs sɹǝsn ʍǝu join the acura legend flickr group visit my flickr page |
Where can I buy one of these Helm manuals for the G1? A service manual...helminc.com didnt have any for G1...
35% Tint New Paint MA 6.5" front Cold Air Intake H.O. Alternator Eclipse AVN6610 JL Audio A4300 amp Focal Access 6x9's rear Stromung muffler from GB Clifford Matrix 50.5x alarm Waiting to be installed: Front strut tower bar 2 Orion HCCA 2100 amps 2 12" Cadence Daytona competition subs |
Update to service manual?
The last 500 or so pages are corrupted and blank when you scroll to them but parts are readable. Any chance there is a file of this PDF that is without errors?
Thanks!
88' Legend Coupe, purchased 9/07 Florence Blue Metallic In restoration process: 1)fixed surging problem - new plugs and ignition wires 2)fixed oil leaks - replaced all 4 engine cover gaskets 3)replaced front 02 sensor 4)replaced instrument cluster circuit board To do: 1) fix cruise control 2) polish paint, detail trim |
| Cool Site - Online Workshop Manual G1 | ZAV | First Generation Legend (1986-1990) | 48 | 08-28-06 01:15 PM |
| Online service manual question | DT98 | First Generation Legend (1986-1990) | 2 | 04-29-06 02:09 PM |
| weird online manual | Jay P | First Generation Legend (1986-1990) | 1 | 01-26-05 02:31 AM |
| UK online manual | digger89L | First Generation Legend (1986-1990) | 3 | 09-27-04 04:04 PM |
