Old 07-23-04, 02:05 PM   #1 (permalink)
A Nut
z00m's Avatar
Send a message via Skype™ to z00m
G1's with systems - read
Ok, I just got home and I was thinking to myself I wish I could just figure out what was causing the last main rattles w/ my system. Then I thought I'm sure many people on the forums have systems and could help me out, so what rattles have you had and how did you fix them?
Lets see, my whole trunk lid rattled and I fixed that by spraying the whole underside of it with rubberized undercoating (including the middle section.. hey.. it keeps the sound in, its the poor man's dynamat ). That really helped out my situation because I figured out that that was the main rattle that i was hearing from the inside of my car.
There are no sharp rattling noises anymore, I've got my car very de-rattled And its not bad at all when standing outside of the car (not embarassing like some people's systems)
Anyways, my final rattle is more of a vibration, sounds like the rear deck's carpet is making the sound.. but even if I hold it down I still hear the noise. My friend said it could be the vents, but I can hold them down and I still hear it too. What else could it be? It's something big, like the whole rear deck itself that is causing it. But I wanted to see if anyone had found out the exact rattle and fixed it.
What is it?
old school
z00m is offline
Old 07-23-04, 02:07 PM   #2 (permalink)
Steveman09's Avatar
Car 1: 94 Legend LS Coupe Type-II
Car 2: 87 Subaru GL10 Turbo
Car 3: 91 Eagle Talon TSI
Send a message via AIM to Steveman09
It's prolly the high volume air movment thats escaping in the little holes in the rear seats and rear deck. Only real solution is to completly seal the trunk from the cabin, but you will most likly loose lots of sound ouput.
Steveman09 is offline
Old 07-23-04, 02:11 PM   #3 (permalink)
A Nut
z00m's Avatar
well shoot that stinks. Its not so bad on some songs, but on the songs that have long drawn out bass that goes in and out its pretty bad. If I listen to eminem's rap game it is very noticeable at any volume
grrr, well I ordered my 15" eD sub, hopefully the better sound quality will make up for that vibration or whatever it is
old school
z00m is offline
Old 07-23-04, 07:41 PM   #4 (permalink)
Master Of Legends
Legend_master's Avatar
Car 1: 1988 4dr gold legend (SOLD :( )
Car 2: 86 Accord Hatch LS/v
Send a message via ICQ to Legend_master Send a message via AIM to Legend_master
there is a little black bar that runs across the underside of the rear deck, you could check that out and just put a little piece of cotten or matting between the bar and the rear deck.
Legend_master is offline
Old 07-24-04, 02:07 PM   #5 (permalink)
A Nut
z00m's Avatar
bump
no one else has any advice? i know you people have systems. don't tell me u just left the rattles or have a weak system that doesn't make the car rattle :p
btw legend master, i'm gonna check that tomorrow, i've looked at all of those bars before, but they seemed pretty stable and sturdy.
old school
z00m is offline
Old 07-24-04, 04:24 PM   #6 (permalink)
check your power antenna, abs unit and even your spare tire to make sure it's bolted down tight.......
ND1980LS is offline
Old 07-25-04, 06:03 PM   #7 (permalink)
Steveman09's Avatar
abs unit??????
what the hell?
Old 07-25-04, 10:42 PM   #8 (permalink)
InksBeMe
GREYLEGEND's Avatar
Car 1: 89 Sedan L, 270,000 km
OK Zoomer, you want to look a resonance. At a particular frequency something vibrates like hell. How the heck do you do it?
What you need to do is to play different frequencies and find when the vibration starts and when it is loudest. When you find it, keep the frequency there and then look for it by ear and touch what you think is causing it. The minute you touch it, the vibe will go away.
What we need now is a frequency generator. If you have one, well you wouldn't probably need to ask this question so you need to know how to get one. Easy. You got a PC. Download a frequency generator. It's a program that generates frequencies through your sound card. I suspect you have a sub amp. get a mini to rca adapter to do this. If you or your buddy has a laptop, this is even easier.
Now starting at a high frequency e.g. 200Hz and at a "LOW" volume, start going down in frequency like every 5 or 10 Hz or so until you get the vibe where it is loudest now you can easily go find it.
Some warnings.
Do this at the volume where you just get the vibe and not much louder. Constant tones can be hard on your system compared to music.
IF you start at a low frequency and have a ported system, you will "unload" the sub. The sub can easily run out of travel and be damaged if it is of poor design.
Try these sites.
http://www.dazyweblabs.com/val/
Using the sweep generator and mic you'll see your in car frequency response.
A cheap mic is not to be totally trusted at the bottom and top end, but it could be interesting. Cheap sound cards are also not reliable for flat frequency response.
Recommended one for newbies
http://www.marchandelec.com/programs.html
download fg_lite.exe
This is simple to use and use a sine wave.
GREYLEGEND is offline
Old 07-26-04, 02:04 AM   #9 (permalink)
A Nut
z00m's Avatar
Some warnings.
Try these sites.
great idea grey! i didn't think of that. i can d/l a competition hz cd and it'll have tracks that have solid bass at diff frequencies. i got my old system mic'ed at a car audio pro's house (that i met on caraudio.com) and he had one of those cds.
Only problem is that if the vibration is in the trunk, it might not keep doing it if the trunk is open when i'm looking for it. hmmmm i'll figure it out somehow
thanks once again grey! btw, i'm changin my o2 sensors in a little while, i'm bout to go get them now
old school
z00m is offline
Old 07-26-04, 03:43 AM   #10 (permalink)
abs unit??????
what the hell?
...yeah....the ABS control unit in the trunk.......
ND1980LS is offline
Old 07-26-04, 06:36 AM   #11 (permalink)
A Nut
z00m's Avatar
no need in worrying over the abs unit.. seein as i don't even have it :p
<-- base model w00t
old school
z00m is offline
Old 07-26-04, 08:49 AM   #12 (permalink)
Car 1: G1 L Sedan
I got dynomat in spts near the license plate, around each speaker, and everywhere i coud not see some rust proff, but I got a 90 and my system is 2 10's so bass is clear not too booomy, maybe I'm bias but no boom not ratttle, clear bass is clear bass. I got dyno under the deck and that seams to be the isssue, and each pillor behind the pass. seat.
LLegend is offline
Old 07-26-04, 12:57 PM   #13 (permalink)
Legend
Car 1: 1989 Honda Legend Coupe
Send a message via MSN to remickz
i need to hurry up and do sumthin about my rattles. its gotten to the point where there is rattles comin from parts of the parcel shelf, the roof 9less rattles when the sunrof cover thingo is closed) and there is a clicking sound i now get in the dash, like behind the tacho and spedo, just a clicking noise like something is ticking over when i move.
mike.
Cyclops Paralyser 385 Alarm System
Clarion Headunit
DvD player
7" passenger side dash mounted screen.
1 x Cadence A7+HC mono Amplifier
1 x Cadence A2 4 channel Amplifier
2 x Rockford Fosgagte T112D4 Subs
Hertz 6 1/2" Components in front
Lightning Audio 6" Co-Ax in rear shelf
2 x 1.5 farad caps.
http://www.deakin.edu.au/~mpod/legend.JPG
remickz is offline
Old 07-26-04, 03:54 PM   #14 (permalink)
mike.
well....the ticking in the dash is your speedo cablethat needs to be cleaned/adjusted.....
ND1980LS is offline
Old 07-26-04, 04:17 PM   #15 (permalink)
Legend
thanks, i will have a look into that later on, i know i have seen lots of posts about this issue, so later tonite i will have a look back in the forums.
Mike.
Clarion Headunit
DvD player
2 x 1.5 farad caps.
remickz is offline
Anyone ever read the count of monte cristo? Smokinfastlegend The Lounge 11 07-11-04 03:33 AM
California G1's, Socal meet apr. 24th WhenHeartsRunDry First Generation Legend (1986-1990) 0 03-23-04 11:54 AM
Omfg This Is Crazy Read! fLoRiDiAnLeGeNd The Lounge 11 08-29-03 06:53 PM
The daily thought- Something to reflect on (please read) ThaAcStangSwerver The Lounge 10 10-15-02 06:40 AM
Genius ----- MUST READ --- MUST READ!! 502 MotorSports The Lounge 13 09-27-02 11:32 PM
