Old 10-07-04, 10:15 AM   #1 (permalink)
Car 1: 1989 Acura Legend
Got A Serious Brain Teaser For U Acura Gurus..Help Needed!!
I'll try to make this quick and simple. My girl gave me a 1988 Acura Legend LS: 5 SPd..V6..All power & Leather etc.
It has been sitting for 2 yrs.
The car wasn't getting fire to the starter. So i replaced all the underhood & under dash relays. Then i had power to the starter. Then i replaced the inoperative fuel pump. The engine will not start..but sounds like its trying hard. Ive even substituted with another ECU. The car has fire..fuel..and air. All plugs are firing and the timing is spot on, i also did a resistance test on the dist. pickup..it was fine. The only way it will start is of i spray throttle body cleaner inside the intake hose. It will run till out of cleaner and vaguely rev a little (im revving it) while its running on carb cleaner..when out of cleaner it dies. I pumped all of the old fuel out with the new pump.(with fuel lines unhooked of course.) All of my injectors are pulsing too. Lastly..my ECU is blinking(red LED blinks 1 quick then 7 in succession) thats a code 17(speed sensor). I cant see that stopping it from running. The only thing i can think of is that theres still water in the fuel. I plan toput 5 more gallons of 93' in it and some Dry GAs treatment to get the water out. Could water in the fuel be stopping it from running?
89legenddead is offline
Old 10-07-04, 10:32 AM   #2 (permalink)
Car 1: 96 RL, 03 MDX (NAV/RES), 05 TL(NAV/AT) 02 VW Jet 1.8T
Did you replace the fuel filter?
AIM: craigerd2
craigerd2 is offline
Old 10-07-04, 10:37 AM   #3 (permalink)
I haven't replaced the fuel filter yet...im planning on it....
ANyhow..its getting good fuel pressure..but i will replace it soon.
Old 10-07-04, 06:38 PM   #4 (permalink)
Car 1: 88 acura legend l
i wanna replace the fuel filter in mine...where is it located? thanks
catman25 is offline
Old 10-07-04, 08:47 PM   #5 (permalink)
Car 1: 95 SE, 89 Coupe, Lexus 430 Conv.
If you're positive you have fuel PRESSURE to the system then you must have an injector system problem, could be one of several fairly simple things.
White 89 Coupe & White/Silver 95 SE
johnny3 is offline
Old 10-07-04, 09:03 PM   #6 (permalink)
Legendary Dai Lo
C25A1guy's Avatar
Car 1: 2002 Acura RSX
Car 2: 2006 Honda Ridgeline
If it's been sitting for 2 years w/o running, I can think of a few things.
1. Gas is bad. You need to drain the gas tank and fill it up w/ fresh fuel. Also, there's probably a lot of gunk all over your fuel system from all the old gas that will need to be cleaned out
2. Possible light rust around cylender walls. I don't think I really need to explain more.
There's other stuff too, and more then likely, probably a combination thereof. Anyways, good luck on getting it running and having everything restored to running condition.
Thanks To my sponsors and affaliets: M1 Autobody, ICB Motorsports, Honsport, Sierra Acura of Alhambra, Import Parts, Hondata, E Auto Parts, New Century Auto, APR Performance, Toyo Tires, Buddy Club, Torco Oils
C25A1guy is offline
Old 10-08-04, 04:41 PM   #7 (permalink)
Car 1: Acura Legend 90 L Cpe
Valvoline Fuel SYSTEM Cleaner
Well my legend has been sitting for some time now, and it has about 1/5 a tank of gas. So before I put new gas in, I am thinking of putting some "Valvoline Fuel SYSTEM Cleaner". Would that be a good idea, and has anyone used this before?????
What about Chevron Fuel INJECTOR Cleaner"???
aminus21 is offline
Old 10-08-04, 05:03 PM   #8 (permalink)
Legendary Dai Lo
C25A1guy's Avatar
How old is that gas? If it's older then 1 year old, I really recomend you drain the old nasty gas out of your gas tank and put fresh fuel in. If not, you'll be looking at costly repairs.
C25A1guy is offline
Old 10-08-04, 05:33 PM   #9 (permalink)
Sales Guido
SuperCoupe93's Avatar
Car 1: 1993 Frost White Legend Coupe L
Car 2: 2008 Land Rover LR2
Are you sure about that new fuel pump you put in? Sounds to me like its a problem with fuel getting to the chamber
The value of life can be measured by how many times your soul has been deeply stirred. - Soichiro Honda
UNDER CONSTRUCTION 8/20/06
THE UNVEILING: 2007 Tri-State Meet
SuperCoupe93 is offline
Old 10-11-04, 11:04 AM   #10 (permalink)
Car 1: 2000 gold 3.5RL and 2001 silver MDX with navi.
it'a a bad main relay.
jno2968326 is offline
Googlism !~! dvp The Lounge 4 12-04-02 12:42 PM
Googlism for: acura legend MC® The Lounge 7 12-04-02 05:38 AM
Acura Legend mods info needed Hasbro Engine & Performance Modifications 1 08-06-02 02:17 AM
