How to bleed brakes when replacing hose - The Acura Legend & Acura RL Forum
Old 04-13-06, 12:02 AM   #1 (permalink)
Car 1: 89, Acura Legend l
I am going to replace my front brake hoses at the end of this week. I just read the Haynes manual which stated that with ALB on the car, I cannot bleed the car in traditional way. I mean, with the DIY kit(bottle and hoses) and a helper sitting in the car pumping the brake padel. I saw quite some ppl replaced brake hoses on the board and none mentioned the ALB issue. I am just wondering if I can still follow traditional way to bleed it when I only replace the front brake hoses, or it's a job which only can be done by dealer. Thanks.
will_b is offline   Reply With Quote
Old 04-13-06, 01:01 AM   #2 (permalink)
Car 1: 1990 Legend LS Coupe
they may be refering to bleeding of the ALB system which is something that is "supposed" to be performed by a dealer. As for the regular brake system...the one attached to the brake booster...bleed as you normaly would. Sequence is 1) driverside front 2) passenger rear 3)passenger front 4)driver rear
have fun
1990 LS coupe - 5 speed - 160,000 miles
ram CAI - grounding wires - B&M FPR and gauge
D/S rotors - ceramic pads - SS brake lines - driving lights
alpine HU - infinity components - profile 4ch amp
"My other love is a Ford Bronco"
body9599 is offline   Reply With Quote
Old 04-13-06, 09:00 AM   #3 (permalink)
Thanks for the reply. I will give a try this weekend.
Old 04-13-06, 10:49 AM   #4 (permalink)
Alperovich's Avatar
iTrader Score: 24 reviews
have fun
hang on... aren't you suppost to first do the farthesst away from the booster. pass rear, driver rear, pass front, driver front. else you don't get all the air out.
Old 04-13-06, 11:57 AM   #5 (permalink)
just quoting the repair manual
Old 04-13-06, 02:47 PM   #6 (permalink)
Mabuhay...
pnoye2's Avatar
maybe this will help; same as mentioned by body9599
http://www.autozone.com/servlet/UiBr...3d801aa47a.jsp
Bleeding, standard hydraulic system; 1986-93 Coupes and Sedans.
Judge Judy to prostitute: So when did you realize you were raped?!?
Prostitute wiping away tears: When the cheque bounced!?!
Tony (BDAZZGI) auto repair shop!
Old 04-13-06, 06:04 PM   #7 (permalink)
If I replace both of the front hoses, do I need to bleed all four corner according to the order? By the way, how to release the pressure as discribed on the autozone.com. Thanks!
Anyway, I will consider to bleed all four corner, just have a chance to look at rear hoses.
Is replacing the ABS High Pressure Hose every 30K really necessary? S4gunn Second Generation Legend (1991-1995) 12 09-08-07 11:11 AM
Thermovalve Removal and Replacement Klen_Motorsports First Generation Legend (1986-1990) 6 03-16-06 02:07 AM
Evil evil brakes - they won't bleed Black_Panther First Generation Legend (1986-1990) 10 08-03-05 05:37 PM
Hose For Bleeding Brakes 91boz Second Generation Legend (1991-1995) 8 02-08-04 06:06 AM
Need your help replacing a critical hose... Moloukhya Second Generation Legend (1991-1995) 11 08-28-02 12:23 AM
