Old 08-07-05, 11:43 PM   #1 (permalink)
What you crave.
WhtCastle's Avatar
Car 1: 1990 Acura Legend LS Coupe 5-Speed, 2001 Jeep Grand Cherokee Limited
Arrow G1: DIY Install amp for sub in trunk with 4ga wiring.
Ok, there was another walkthrough about this from 03, but the pics have since stopped working and I wasn't sure how to follow it on words alone, so I did another one. I didn't think to do a How-To and take pics until I had already gotten some of it done, but I will do the best I can to describe everything. This was done on an 88 Std. coupe, I assume it will be pretty much the same for all first gen.
This walkthrough is written assuming you already have a head unit and remote/RCA cables connected to the head unit. Also to note: My car has had I don't know what done to it, so your rear seats might not be as easy to pull up as mine are, I do not know. I can only write this based on my experiences with my car. I hope/assume everything will be about the same for others though.
Tools you will need:
1. Standard phillips screwdriver. (Door sills, 3 interior screws, ground and possibly needed for your amp.)
2: 1/2in wrench (Battery terminal.)
3: 11 metric wrench (Footrest pedal and screw for power wire to battery terminal.)
4: (1) 14x1 screw + 1/4" washer (For ground.)
5: Any tools for adjusting/mounting you amp.
First thing to do is pop the hood, open the doors and trunk. Go ahead and take the driver and pass. door sills off. (4 screws each.) Remove floor mats as well.
If you are going to check your ECU, leave the battery connected, if not, disconnect the battery now. Go ahead and pull up the passenger carpet, you should only need to pull it back about as far as you would to check ECU. Go ahead and see if you got any odd blinks going since you have the carpet pulled up. If you have not already disconnected battery, do so now. Go back to where you have pulled up the carpet, and you should see this piece screwed in under the glovebox.
(Of course yours will be mounted in the car, not on the ground :p )
There will be just 3 screws holding this part in, unscrew them and remove the piece, and set and the screws off to the side. You should now see a large white plastic piece. At the back of this piece near the firewall, you should be able to find a small tube that connects to it and runs through the firewall. Just pull this off.
Get under the hood, and pull this hose completely out. You should be left with this.
You can do 2 things with this now: Make the gromet larger to accompany the wire AND the hose, or just throw away the gromet. If you are going to cut it larger, go ahead and do so now, and leave it on the power cable when you feed it through. Just set the hose aside for now.
Go ahead and run your power cable now from the engine compartment into this hole. You should be able to run it through no problems.
Go ahead and pull as much power cable through as you need. Start hiding it under the carpet and panels on the pass side as much as you can. Wherever you are running this power cord, run your remote cable as well. Where the door sills were taken off, you can pull the carpet back and tuck both cables down in there, under the plastic box item that runs the length of the door.
Run your cables behind the seatbelt(s) and continue to just tuck them under the interior panels. Once you get to the rear seats, just pull it up and tuck the wiring down under. Pull up the bottom corner of the seat backs, you should be able to feed the cable through there then.
It was hard to get a pic, but if you just feel around in there you can feel for a small opening, try to feed both wires through it. You will just need to feed a few inches in. Once you have done that, go to the trunk and just look/feel in the corner until you can find the wires and pull them through as much as you need.
This is on the bottom corner in the trunk, just search for the wires, they will be there.
Now that those are run through, get down to where the pedals are on the driver side. Pull up the rubber foot rest pedal. Now get the 11 wrench and remove the 2 bolts holding the plate there, and set it off to the side. Pull the driver side carpet up.
Run this wiring just how we did the remote and power cable; everything will be done the same. Once you have fed them through enough, get in the trunk and pull back the side carpeting on the driver side. Pull your RCA cables through. While this is pulled back, you should see 2 holes near the wheel well. The one that is closest to the rear of the car is where we will put our 14x1 screw and the 1/4 washer for the ground. I lightly sanded mine down.
We should now have all wires running to the trunk as needed. Go ahead and hook up your amp, then reconnect the battery and make sure it comes on and that everything works. I would suggest hooking up your sub and such and making sure it works as it should.
Assuming everything comes on as it should, turn off the car and disconnect the battery again. Reconfigure the wires in your trunk for how you want them, mount the amp and then wire everything back up and put the sub in, etc. until everything in the trunk is set how you want it to look. Put the carpet on driver side back to how it should be, put the metal plate for foot rest back on then put the rubber part back on. Put driver door sill back on.
Go ahead and get the hose that we pulled of earlier. I found it easier to now feed it from the cab into the engine compartment, and then pull it back to reconnect it to the white plastic housing. Fit it into the gromet with the power cable if this is what you chose to do from earlier. Once that is done, get back into the engine compartment and angle it back down to how it was previously.
Go ahead and screw the black plastic piece back to where it was on the pass. side. Put the carpet back to how it was, and then put the pass. door sill back on. Check fluids since you have the hood open, then reconnect the battery. Check it out one more time to make sure it works (No reason it wouldn't, right?) and have enjoy!
I think this is my first in detail how-to, I might have missed something or worded something wrong. If any problems just ask!
WhtCastle is offline
Old 08-08-05, 02:12 AM   #2 (permalink)
Car 1: 89 Acura Legend 2dr coupe
Awsome, nice job
djlouie is offline
Old 08-11-05, 01:24 AM   #3 (permalink)
What you crave.
WhtCastle's Avatar
Haha.....Remember to break in your subs people! I got too greedy too quickly and blew my sub....R.I.P. SBR-122CR! Lasted a good 2 years.
Old 08-20-05, 02:54 PM   #4 (permalink)
Car 1: 1987 LS Coupe
Send a message via AIM to HotLegend87
Copying to DIY section...
Charles
JVC KD-SX990 MP3 CD Player
Rally Xtreme FX Halogen Driving Lights (Fogs)
CrimeStopper SuperRage IV Car Alarm w/Keyless Entry and Remote Start
Custom Dash Mat w/Arizona State University Logo
Fuzzy Dice
HotLegend87 is offline
Whats this amp looking thing in my trunk? D0NNY First Generation Legend (1986-1990) 6 11-22-02 10:58 PM
Amp install problems Duncan Audio, Video, & Electronics 3 11-13-02 05:12 AM
Questions from a new proud owner of 95 LS Coupe 6-speed yellow2black Second Generation Legend (1991-1995) 13 09-04-02 03:08 PM
Hooking up amp to Bose wiring simgarcha Audio, Video, & Electronics 1 08-09-02 05:47 PM
Wiring to amp simgarcha Audio, Video, & Electronics 4 05-15-02 04:34 PM
