How to Replace Headlight Bulb? - The Acura Legend & Acura RL Forum
Old 01-10-07, 06:36 PM   #1 (permalink)
Car 1: 1988 Acura Legend
Hey guys I know this sounds stupid, but my front right headlight went out. The high beams still work fine, but the low does not on that side. I can't tell if I need to replace the bulb, or the the whole headlamp. At stores I see bulbs for that car, yet, when I look at the lamp, the cover and the lamp are sealed together. Any help guys? Thanks.
Hassman is offline   Reply With Quote
Old 01-10-07, 07:00 PM   #2 (permalink)
Mr. X (aka #5)
Monster Memory Champion, Border 2 Champion, Daphnes Fight For Fashion Champion, Fireman :: Incoming Storm Champion, Gas Attack! Champion, Mini Putt 2 Champion, Heineken! Champion, Odd World Champion, The Independent Compact Catch Champion, James Bomb Champion, Jet Pakker Champion, Juego Champion, Klumpy Champion, Lego Basketball Challenge Champion, Lego Snowboard Challenge Champion, Lizzie McGuire Turbo Racer Champion
IkeRay's Avatar
Car 1: 1997 BMW 528i
Car 2: 1994 Accord Sedan EX
Car 3: 1987 Legend Coupe
you get at it from under the hood. grab the plastic ring that holds in the headlight and give it a turn (righty tighty, lefty loosey). the headlight will come out with the adapter ring. unplug, swap out for a new one, and replace. mine used to go out every so often, and would require me to open the ring and air would escape and the light would work again, but i doubt that is a common problem so probably just go get a replacement. and might i suggest the cool blues over the silverstars since they have an extended life and perform well.
IkeRay is offline   Reply With Quote
Old 01-10-07, 07:25 PM   #3 (permalink)
Hey thanks man, your a life saver!
Old 01-11-07, 12:20 AM   #4 (permalink)
Spiral descent
telafonic's Avatar
Car 1: 1994 GS 6-speed
Car 2: 1996 A6
iTrader Score: 11 reviews
What he said.
Oh, and don't touch the bulbs with your fingers.
EDIT: I see you're in Provo. Welcome to another Utah member.
telafonic is offline   Reply With Quote
Old 01-11-07, 02:50 AM   #5 (permalink)
And make sure you align the bulb correctly when trying to reinsert it. The snap part of the plug that holds the light in should be on top. Then gently push the ring in and try to turn until you feel it grab and it secures itself. You may need to twist the ring until you feel it grab onto the headlight housing. Then give it not even a quarter twist to secure tightly.
ND1980LS is offline   Reply With Quote
Helpful hints on JDM Headlight wiring by Train Mike Diaz DIYs 7 10-01-09 11:38 PM
which one is the best bulb? Refuge. First Generation Legend (1986-1990) 18 02-26-06 03:39 PM
How Do I replace a headlight and readjust my wipers (96' 3.5)? flyman254 First Generation RL (1996-2004) 1 04-01-05 03:38 AM
how do i get to the bulb in the headlite to replace it? turnupthetreble Second Generation Legend (1991-1995) 3 12-20-04 02:56 PM
Need help on changing the headlight mocca Second Generation Legend (1991-1995) 8 10-12-02 07:18 AM
