Old 08-21-08, 06:44 PM   #1 (permalink)
Car 1: 1990 Sedan LS
Send a message via ICQ to spy alelo Send a message via AIM to spy alelo Send a message via MSN to spy alelo
I am back!!
Well hello guys, so far I still have my Legend, but I have a little problem here that I hope someone can help me with. Recently, the tranny stopped shifting from 1st gear to 2nd gear. Before anyone suggests cleaning the solenoids for the tranny, I need to mention that I replaced those with a brand new set from Acura when I originally had an issue like this, which fixed it. Anyway, I had to remove the seats and the carpet so I can wash it, since a nasty water leak from the sunroof drain ruined it. And I found that the Timer Rad Fan wires in the connector are completely corroded. So badly, they were not even in the harness, they broke off. Also, the TRF board is in a similar way (ECU is fine). Since the tranny relies so closely on engine cooling, is it possible that this is related to this issue? Several trouble shooting steps for the tranny points to engine coolant sensor, or faulty cooling fan control unit. Any ideas? Suggestions?
spy alelo is offline
Old 08-21-08, 09:30 PM   #2 (permalink)
LS= Luxury Sport
LegendLand's Avatar
Car 1: 1991 Acura Legend LS Sedan Golden Glow Pearl
Car 2: 1992 Acura Legend L
Car 3: 2006 Honda Odyssey
Send a message via Skype™ to LegendLand
welcome back to the forum... unfortunately, what you said is WAY over my head. Sorry
"Goldie"- A 1991 Legend LS Golden Glow Pearl Type F interior- 141k miles
Recent Mods: New paint and bodywork, speakers, Iggee seatcovers, moonroof, fogs, clear corner/bumper lights, Nokian WR G2 tires, 7 spoke coupe rims.
Projects for 2009: Repair A/C, steering wheel audio control repair, fog switch, new heated seats, Reded out tails, new speaker mesh, timing belt, CAI, various interior parts, Type II cluster, new floor mats, interior LED swap.
Progress Thread: The Legend Reunveiled
LegendLand is offline
Old 08-21-08, 09:36 PM   #3 (permalink)
Ac N Up
95AcLegendOwner's Avatar
Car 1: 1995 Acura Legend Sedan
Car 2: MARC Train
How does your trans fluid look and smell? Is it brown and smells burnt or is it still bright red? If its any color other than red I would do a flush, (not a drain and fill). Start there and see what happens. Btw, welcome back.
This is not my KA9. Just had to take this picture.
95AcLegendOwner is offline
Old 08-22-08, 02:23 AM   #4 (permalink)
Car 1: 1989 legend coupe L
I checked the schematic once, when I had a trans solenoid lock-up problem, and the command path (voltage) goes like this: TW sensor > ECU > Fan Control Unit > TCU (in my instance, solenoid lockup command) > trans lockup solenoid).
I had overheating due to no cooling fan operation; a bad FCU was the problem, but replacing it also fixed my trans lock-up failure problem.
So, firstly, all bad, broken, or corroded connections in this electrical path must be properly repaired for the trans to shift normally.
DallasLedge89 is offline
Old 08-22-08, 02:26 AM   #5 (permalink)
Sounds like I am on the right path!! Thanks, that gives me hope. And 95AcLegendOwner, the fluid is nice and bright red. I replace the fluid quite regularly, after 30,000 miles.
Old 08-23-08, 03:22 AM   #6 (permalink)
take that; take that
pnoye2's Avatar
Originally Posted by DallasLedge89 View Post
Corroded connections in the electrical path must be properly repaired for the trans to shift normally.
You're might be on to something here ...OP, please keep up posted on your progress?!? and welcome back!
pnoye2 is offline
Old 10-26-08, 11:01 PM   #7 (permalink)
I forgot to update. Reworked the TRF unit by reflowing the solder joints and cleaned everything. I had to rebuild an electrical path in the board due to corrosion, but is all good now. Washed it with a special chemical, reinstalled everything, and replaced the defective harness. All good, now shifting from 1st gear. But of course, I have a new issue now, but it may be another problem. So I created a new thread.
