Old 05-29-06, 11:42 PM   #1 (permalink)
Car 1: 1990 Acura Legend L Coupe
interior lighting issues..
I noticed the other day that the lights under the dashboard and the light around the ignition were lit up all day long. does anyone know why this is happening? I yanked out the fuse for it so that it wouldn't drain my battery. and my antenna won't come up either. it doesn't even make a sound like it's trying to come up or go down. tsk tsk. I tell ya.. I've got issues with the car and I don't even know what the heck I'm doing. Thanks for any suggestions you may or may not have!
Katy253 is offline
Old 05-29-06, 11:52 PM   #2 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1997 BMW 528i
Car 2: 1994 Accord Sedan EX
Car 3: 1987 Legend Coupe
sounds like you switch to turn on the headlights is broken. mine is broken in the way that when the headlamps are on, the dash lights are not, but you could be experiencing a constant on. solution, get a new switch (look on ebay, i have seen a couple lately).
for the antenna, have you checked the fuses and the plug into the antenna in the trunk. open the trunk and pull the carpet next to the antenna away and then see if it is plugged in. i unplugged mine because it was making a grinding and the antenna on the backwindow was giving me plenty good reception.
IkeRay is offline
Old 05-30-06, 01:37 AM   #3 (permalink)
Mr. Hard to Find!
1_Hot_Legend_LS's Avatar
Car 1: 1991 LS Sedan Auto
Car 2: 1990 Chevy S10 SB V8
Ok, Ikeray didn't read your post very well or he is in his Mr. X mode!
The courtesy lights and key cylinder lights are probably staying on because you may have a bad switch in the driver's side door handle. Those light should only come on when you lift the door handle and shut off momentarily after starting the car. So I would check the switch on your driver's side outside door handle.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
_______________________
Forum Rules
1_Hot_Legend_LS is offline
Old 05-30-06, 03:09 AM   #4 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
didnt read very well at all....after 3 glasses of wine, kinda makes things read differently...
yeah what hot legend dude said (i dont even know your name....). do the dome lights stay on as well? or are the wired through different circuits?
IkeRay is offline
Old 05-30-06, 03:48 AM   #5 (permalink)
I'm not sure if the dome light stays on or not due to the fact that I'm almost completely sure it's burnt out.. or that I'm blind. One or the other. How would I go about checking the switch on the outside door handle? Ahh, it would probably help if I mentioned that the lock is broke on the driver's side door.. so I have to unlock the passenger's side door and unlock it all from there. Gosh, I love having white trash problems with my car. No offense to those of you out there that consider yourself white trash. ;] I just got my transmission rebuilt so I'm kind of anxious to get every other broken thing on it fixed.
Katy253 is offline
Old 05-30-06, 03:54 AM   #6 (permalink)
Spiral descent
telafonic's Avatar
Car 2: KA7_8 SWP 6-speed
Car 3: 1996 A6
To check your dome lights, you just need to put both your dome lights in the center position, this is where they are at so that they go on when the door opens. There are two (one at the front of the car, by windshield, and the other behind the front passengers in the center), so the chances of both of them being out is less. But I'm guessing they won't be on when your other interior lights are on, unless you move them to the always on position.
telafonic is offline
Old 05-30-06, 01:25 PM   #7 (permalink)
Mr. Hard to Find!
He/She may only have one dome light if it's a coupe. But the dome lights are on a seperate circuit.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-30-06, 09:20 PM   #8 (permalink)
5 Speed Operator
1990Legend_LS_5spd's Avatar
Car 1: 1990 White LS 5spd Sedan
Send a message via AIM to 1990Legend_LS_5spd Send a message via MSN to 1990Legend_LS_5spd Send a message via Yahoo to 1990Legend_LS_5spd
well, i cant unlock my passenger side door with the key without setting the alarm off, lol. it does sound like your door switch is bad or the intergrated control unit that controls the lighting.
Originally Posted by Jrod@Buschur@ evowned.com
DSM's..... turning the everyday Joe into a tool throwing, foul mouthed, alcoholic since 1989.
1990 Legend LS Sedan 5 spd
1989 Legend LS Sedan Auto(For Parts, Bad Trans)
G1 FAQ
If Your Legend Stalls or Doesnt Start, CLICK HERE
1990Legend_LS_5spd is offline
Old 05-30-06, 09:33 PM   #9 (permalink)
Mr. Hard to Find!
Do 1990's have ICUs? I know my 87 didn't, it just had a relay block.
Thank You,
L. Downes
O-Town Legends C.C.
Winter Haven, FL
Forum Rules
Old 05-31-06, 03:14 AM   #10 (permalink)
Spiral descent
telafonic's Avatar
Car 3: 1996 A6
Right. Thanks.
My '87 has one, it is right above the relays. It controls the windows, beeper, and idk what else.
Diagnosing Power Window Issues The Legend of the King Second Generation Legend (1991-1995) 1 03-29-06 11:32 PM
Cruise Control Issues LegendaryASH First Generation Legend (1986-1990) 11 12-27-05 05:32 PM
Type S wheel issues?? fooman Second Generation Legend (1991-1995) 5 10-26-05 09:24 PM
Engine issues 92l2dauto Second Generation Legend (1991-1995) 6 07-31-04 11:31 AM
