LIVING LEGEND
Key warning chime
This site is the best!!
One other issue I have with my "86" ,when you shut the car off and remove the key,opening the driver's door sets off the warning chime that the key is still in the ignition. This appears to happen when ever you open the driver's side door, even upon reentering the car ovenight the door opening sets chime off. Opening any of the other doors does not set off the chime. Any suggestions would be appraciated. THANXX !!!!!!!
BE CAREFUL WHAT YOU WISH FOR....... YOU MAY GET IT!!!!!!!!!!!!!!!!! |
(my old red 88L r.i.p.)=(
yeah man mine does the same thing. I have to take the key out of the ignition in a tricky way, and it wont do it.....old cars have many gremlins you just work around them, unless you want to replace the entire ignition
1989 Green LS Coupe 218k/5speed/new everything/needs leather!restoring back to perfection... 2006 Blk.Blk. 6speed TL Comptech supercharged/thermoblok gaskets/shortshift Type S wheels/21k |
I think its normal. Press your door switch to stop it.
2006 Nissan Xterra SE 4x4 2006 Jeep Wrangler Sport 1990 Acura Legend L Coupe (For Sale in Cali) LastHumansGarage |
aka desired_speeds
mine does that sometimes, the little piece doesnt pop back out when I remove the key, so i stick my finger in there and give it a poke and it pops back out.
CAP CAP M* F*R!
Not to get too far off topic, but when you guys start your car, does your seat belt reminder beep?
Mine still does OCCASIONALLY...the times are so few and far between that when it DOES beep I almost always say "WOW I forgot that my car does that!" ![]() |
yeah i noticed the same thing!
good to know!
1990 Acura Legend
Mine is doing beeping like this now. Only its when i remove the key. (as if something is still on) The lights on chime is different. This is a beep. The only problem is that this is not an every day car so now i come back a few days later and the battery is dead. Something must be on here some where, or a short or something.
Anything guys??????? B |
Got Legend!
My chime just started working lol out of the blue. my switch is wierd. If i tap on it my lights will go on and off... but never herd the seat belt beep...
to you dead battery thing I don't know maybe a door switch bad or trunk lid switch, your radio, condencer fan motor, and the list goes on and on.....
MY GAS HOG |
#11 (permalink) | |
Spiral descent
Your sunroof is closed all the way right? Try fiddling with the switch. Does this happen every time? It's possible the beeping and the dead battery are separate problems. But, check your door switches because if your driver's switch is bad it will beep but also leave your interior lights on (even if you switch them off, there is still the door lights), which would drain the battery. |
| FS: JDM Laser-Cut Key Ignition Assembly Complete w/ Honda Clio Key & Extra | Blingting | OEM Parts | 11 | 08-22-07 06:42 PM |
| Where is the key code location to get a new key punched out? | PoodleHead | Second Generation Legend (1991-1995) | 9 | 08-11-05 02:33 AM |
| Anyone have problem with the ignition key warning sound | mocca | Second Generation Legend (1991-1995) | 6 | 01-21-03 03:21 PM |
| Frustrated! Ignition Key Warning | alandkm | Second Generation Legend (1991-1995) | 0 | 07-30-02 01:06 PM |
