leaking coolant around radiator drain plug
I changed my coolant yesterday. After bleeding everything, I put it all back together and since then, have noticed that there is a small leak coming from the coolant drain plug area. I pulled off the plastic cover and noticed small amounts of coolant is leak from this clear 6 inch discharge tube attached just below the drain plug housing. Can anyone tell me why/what is this tube for and why the coolant is discharging there?
Before the radiator cap / coolant change, I never had this discharge problem. Thanks for any help.
Sam |
Prestone antifreeze. Not sure if it is silica free...I'll have to check. If it is not, I'll redrain and refill. Only cost $10 bucks.
By the way, I looked at the leak today and it stopped by itself so whatever it was, it isn't doing it anymore.
Sam |
InksBeMe
regular prestone is supposed to be not good. their long life is silicate free. be careful about dexcool.
me? used prestone in 95, 98, and last year. till i saw honda bulletin saying to use silicate free. my pump is still running. questioned prestone in email - they say it's ok. next change - why take the chance? i think zerex is silicate free, double check. honda is recommnded but pricey |
