Old 08-08-08, 04:51 AM   #16 (permalink)
bkbkbk420's Avatar
Car 1: 89 L Coupe (5-Speed)
Car 2: 89 Coupe (5-Speed)
Car 3: 79 F-100 Ranger
Send a message via AIM to bkbkbk420 Send a message via MSN to bkbkbk420
hate to let all you legend owners down, but im sure its a fact
-5-speed (of course)
-jdm c27a motor 50k
-blue ngk 8mm wires, +4 plugs
-venom 400 chip, k&n filter
-always synthetic oil + 92 octane fuel
-mp3 player w/3 10' subs
-tinted windows
-punched out cat, minor weight mods
-http://www.cardomain.com/ride/2364057
http://www.cardomain.com/member_page...057_1_full.jpg
bkbkbk420 is offline
Old 08-08-08, 12:46 PM   #17 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Um....every 3000km = about 1800 miles?
Also, there was somebody on here that completely rebuilt all of his lifters with new parts....ticking solved
I think being proactive is the only true way....keeping the lash in check per the maintenance schedule, and using Auto-Rx on a regular maintenance basis when the engine is still young.
sam o nela is offline
Old 08-08-08, 03:07 PM   #18 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Car 1: 1987 Legend LS Coupe
I'd tend to disagree that it can't be fixed. Especially since we now know there's tappets involved. (well, at least I just learned that). Those are known to freeze up with gunk and not function properly. Clean or new tappets would surely solve most problems there. If a rocker is causing tap, it should be replaced, and I doubt a cam could ever tap like that, it's a constant contact device.
KAHruzer is offline
Old 08-08-08, 03:11 PM   #19 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Originally Posted by FutureX 2001 View Post
Some pictures would be really nice
LOL, sure they would.
I doubt anyone's going to re-do the job just to take photos, however.
Maybe the next will think ahead and take photos as they work.
KAHruzer is offline
Old 08-08-08, 03:33 PM   #20 (permalink)
Car 1: 1993 Acura Legend Coupe Type II 6sp
Car 2: 87 Prelude 2.0si 5sp
anyone know if the g2 type II motor has tappets?
filmshoot is offline
Old 08-08-08, 03:49 PM   #21 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Don't know, but would tend to think they might since the G1 does.
You'd probably get a better reply in the G2 section, however.
KAHruzer is offline
Old 08-08-08, 10:30 PM   #22 (permalink)
car2n's Avatar
Car 1: 1988 acura legend
i am not an expert on posting instructions but i hope this will help some one like it did for me:
1.Need to have these items to start this project.
A)Tappets removed from your engine heads
B)Mineral spirits solvent
C)Container
D)Clean rag
E)Latex or some type of gloves (optional)
2.Drain any oil from tappets don't forget to use gloves
3.In the container pour some mineral spirits about a quart for 12 tappets (one head) i only show 5 for the pic then just let them soak for some time i overnight the soak on mine.
4.After soaking the tappets clean each tappet in the container by pressing in and out and at the same time observe for spring action when you press down the "ball" shape part the tappet should go in very easy then realese it and the tappet should come back to it's normal position in a spring motion if you find any problem with this function need to re-soak the tappets with these problems, if after the second cleaning the tappets still not operating properly the you need to replaced them.
5.Last just clean and dry tappets then recharge with oil (see manual on how to recharge with oil).
Hope this helps...
http://www.acura-legend.com/vbulleti...end-sx-124851/
In memory of my son Isai "car2n"
car2n is offline
Old 08-09-08, 02:37 PM   #23 (permalink)
Wink
I will test the theory of 3k mile oil changes.
I have 33k miles on my 1990 with no ticking. I change my oil ~3k miles and will do so in the future. We'll see if the lifter noise never appears.
On the cleaning issue, there is a guy that I know in Switzerland who owns a collection of very rare old cars such as GTB4 Daytona, 300 SL gullwing, and the like. He does all of the work himself on all of his cars.
I talked to him about lifter ticking issues. His advice was to drain the oil, put ~2 quarts of diesel gas into the crank case and run the engine for no more than 30 seconds. Then drain the case and replace the filter and oil.
legendvr is offline
Old 08-09-08, 09:41 PM   #24 (permalink)
89HondaLegend's Avatar
Car 2: 1989 Honda Legend
Car 3: 1989 Turbo Legend
Diesel in the crankcase I am convinced would cure sticky lifters, though, I wouldn't run just straight diesel, more like a 60/40 mix of diesel and oil repsectively. I have wanted to test this theory for a while but I am not keen to do it on my Legend as I need it to get to work
My only concern is that although diesel is very slippery it could cause some damage to the cam and crankshaft by not having that thick oil coating on them. (Metal to metal contact )
Regards,
Steve
Love to Love the Legend
Pictures of My Legend
89HondaLegend is offline
Old 08-15-08, 03:11 AM   #25 (permalink)
car2n's Avatar
Thumbs down
i do not think that will be good idea better to use engine detergent or some type of engine treatment...
car2n is offline
Old 08-16-08, 08:05 PM   #26 (permalink)
Mo*or Mo**h
KAHruzer's Avatar
Here's a diagram in the manual (1987 Coupe, page 6-20) of a Section through the valve train. It's not as I was imagining, but clearly shows how this becomes a problem of tick noise.
The Tappets are situated as the backup bearing point of the cam motion, such that each press of a rocker arm by the cam lobe distributes that load as a span between the valve stem/push rod (on exhaust valves) and the Tappet. Not only does this ease the loading of the mechanism to half the span, but the Tappet plugger motion dampens the load to smooth it out considerably. When the Tappet plunger doesn't move, TICK!
Clear as mud, right?
IAC, clean, well functioning Tappets will very likely eliminate any ticking.
The hard part is clogged Tappet plungers are hard to clean with simple additives. So, Car2n's external cleaning solution is the way to go here.
To do so, however, requires removal of the cam and both intake rocker arms and upper exhaust rocker arms to gain access to the Tappets below.
KAHruzer is offline
Old 08-20-08, 03:52 PM   #27 (permalink)
Car 1: 1989 legend coupe L
Just wanted to say thanks for the illustarative and informative pics and story on the ticking hydraulic lifter (tappet) issue. This has been discussed at length for a long time, but this really laid it all out well. As they say, a picture is worth a 1000 words.
I have 2 questions...
The lifters that were clogged and sticky, were they the exhaust or intake tappets only, or a mix of both?
And, can you tell by looking at the hydraulic lifter once it has been removed, that it is probably a sticky one, like varnish deposits, gummed up externally, or an obviously clogged oil port?
DallasLedge89 is offline
Old 08-20-08, 04:08 PM   #28 (permalink)
Mr. X (aka #5)
IkeRay's Avatar
Car 1: 1997 BMW 528i
Car 2: 1994 Accord Sedan EX
Car 3: 1987 Legend Coupe
does anyone know if the tappets could be purchased from a dealer, or would you have to get them from another engine?
IkeRay is offline
Old 08-20-08, 04:24 PM   #29 (permalink)
The hydraulic lifters (tappets in the diagram) are available from dealers (part #14540-PL2-000 ). Delray Acura sells them for $37 each (you'll need 12).
Interestingly enough, Majestic Honda has the same part listed for a 96 Accord V-6 ...using the exact same diagram as for the Acura engine (it is the same, after all) ...but they want $53 each for the lifters!!
Don't know of any after-market sources for something like this, but there likely is one.
My 90LS has "the tick" ...I tried the transmission fluid trick before my last oil change (drained off a litre of dirty oil, and added a litre of DEXRON II then went for a 20 minute highway drive). It has quieten down a bit, but not a whole lot.
digger89L is offline
Old 08-20-08, 08:23 PM   #30 (permalink)
legend89chopped's Avatar
Car 1: 89 Legend Convertible
Car 2: 93 Legend LS 6-Speed
Car 3: 89 Parts Coupe
The answer is YES.
Dang Bro!! Looks SICK!! I wish I had the guts to cut my junk like that..
...foreskin?
legend89chopped is offline
We operate more than 100
