Location of fuel pump?
The online manuals appear to down today, can anyone with expertise on the topic talk about changing a fuel pump on a 1987 Legend?
location? troubleshooting the pump? tools needed? simple/difficult procedure? cost? OEM vs aftermarket? Is Wallbro good? which fuel pump are you using? Thanks
1987 Legend L Auto 4DR Sedan 156,000 miles Extremely ugly exterior, badly in need of paint. When we have a martian in the White House, I might get around to it. |
#2 (permalink) | |
When you turn on the ignition switch the check engine light should be on for about 2 seconds and during that time there should be voltage to the fuel pump. If the pump is working you should hear it run. If you don't hear it then either the pump is bad or it's not getting voltage. The pump is located on top of the fuel tank and there is an access panel that you can remove in the trunk. If you disconnect the wiring connector you can check for voltage. If there is voltage and no sound from the pump the fuel pump is probably bad. Remove the screws and remove the pump/gauge assembly. The replacement pump needs to be wired in and connected via fuel hoses, which come with the pump. I got my replacement from Carquest, which I believe is Airtech, and is OK. |
#4 (permalink) | |
Alas, I do not have a hard drive.....
However, I am in the process of printing the entire manual, all 1200+ pages of it; 200 down, 1000 to go. Zeno's Paradox: the tortoise will always win the race. THanks, as always
#5 (permalink) | |
Thanks so much
#6 (permalink) | |
| Tech: Legend Fuel Pump Relay location | matt davis | First Generation Legend (1986-1990) | 4 | 09-06-06 02:28 AM |
| water pump location | amosby | Second Generation Legend (1991-1995) | 6 | 02-25-06 01:09 AM |
| fuel filter location | Stu | Second Generation Legend (1991-1995) | 11 | 07-09-05 11:58 PM |
| Fuel Pump Location? | BiggyB73 | Second Generation Legend (1991-1995) | 3 | 02-29-04 07:42 AM |
| Fuel filter location | LegendJr. | Second Generation Legend (1991-1995) | 6 | 02-02-03 08:38 PM |
