loose rear view mirror
Wow - with all this heat my rear view mirror is so loose it flops down after hitting even the smallest bump in the road. Anytips on a fix for this? I don't want a new one just want to fix the old one - any help appreciated!
Flops down ?? Did you loose the piece that holds it against the windshield to keep it from shaking/vibrating ??
#3 (permalink) | |
You can replace a Legend rear-view mirror with any Honda mirrors of the same vintage (ie: 1980's to late 1990's) ...the Accord mirrors are about the same size ...and the Civic / Integra mirrors are a bit smaller. But any of them will fit: just remove the plastic cover, then remove the 3 philips-head screws. Take the old mirror with you to ensure the replacement has the same base. My original Acura mirror lasted until about 2 years ago, then the tension mechanism broke inside the mirror (floppy mirror syndrome). I got a replacement Honda mirror from a salvage yard for $15. When looking for a replacement, I noted the wrecks mostly had "floppy mirror" as well, so this must have been a common problem. Wonder if there was a re-call?
1990 Cobalt Blue Pearl Sedan LS w/JSP-92104 spoiler, Bose Stereo w/single cd player, plus FM Honda 6-disc changer in glove box. Automatic, 268,000 kms, original drivetrain, stock size tires. 1989 Ebony Black Metallic Sedan L Auto. Integra AM-FM cassette head unit, and Honda 6-disc changer in glove box. Stock size tires. Original engine threw a connecting rod mid-Feb, 2007 at 380,000 kms. JDM swap-out July 1, 2008. Car still off the road pending serious body work on rear quarter panels. |
Five- O
I had the same problem. I just put some crazy glue into the socket and set it to the right position.
i just have to remember not to move it. Esti
88 Coupe L 5- speed Weapon R Intake 17 inch Borbet type S [Summer months] Stromung exhuast Cat-Back DEC Hi-Flow Cat 90 tail Lights Cross drilled rotors Eibach Springs/KYB Shocks APC Sway Bar |
Legend Freak
I got a nice condition working rear view mirror at a junk yard out of an Acura for $3.00. Mine would do the same thing...especially when my stereo was on
http://img79.imageshack.us/img79/898...raside18ip.jpg Silver & Grey 88 [/IMG]Legend Coupe LS 24V
17" Momo Corse Wheels/Rev - Silver Clear Corners Short Ram Air Intake 2.5 " Magnaflow Exhaust System Magnaflow High Flow CAT Painted Trim Custom Sound System Brushed Stainless Gauge Bezel Reverse Indiglo Gauges Momo Carbon Fiber Door Sills |
I'm not sure about the first generation mirrors, but the G2 mirrros have adjustment screws on the bottom of the mirror. If you look at either the top or bottom, look for two holes. If you have those put in a small phillips screw driver and tighen the screws. This will then tighten the holder so you will get your mirror to stay still and still be able to adjust it. --=Keith
Some of the most beautiful things in nature have been shaped by the wind - The Acura Legend Coupe |
#10 (permalink) | |
Legend Owner for 20+ yrs
'87 Legend Sedan - Original owner - 198K miles No mods except for stereo unit and speakers '04 GMC Yukon XL SLT (wife's) '00 Nissan Maxima SE (son's) |
Sticky this fix:
Ended up using a tube of construction adhesive caulking. Well not the whole tube - just a smidge in the socket of the mirror ball joint. Forgot the name of the stuff - its like liquid nails or OSI something. Applied it in the cool evening when the mirror would stay oriented correctly. The next day it looks great and holds position. As it warms up in the day I can flex the stuff enough to make minor adjustments. |
| Technical Service Bulletins | jmm67 | First Generation Legend (1986-1990) | 103 | 12-25-06 05:45 PM |
| Estimated cost for changing rear Calipers | mocca | Second Generation Legend (1991-1995) | 7 | 02-17-04 01:00 AM |
| Rear view cameras | ThaAcStangSwerver | Audio, Video, & Electronics | 5 | 08-16-02 06:39 AM |
| Crack side view mirror | goldylege | Engine & Performance Modifications | 2 | 04-06-02 12:50 AM |
| Side view mirror heater | James92LS | Second Generation Legend (1991-1995) | 4 | 01-30-02 01:40 PM |
