» Sponsors
» Sponsors
Old 07-13-08, 03:28 PM   #1 (permalink)
Car 1: '89 LS Coupe (5 speed)
Main Relay Repair DIY
The main relay is a common weak point for all late 80s/early 90s Honda vehicles, and the Legend is no exception. The symptoms are presented on http://techauto.tripod.com/ and the solutions are http://techauto.te.funpic.org/solutions.php. This is a DIY tailored specifically to Legend G1s.
When the main relay was originally assembled, too little solder was used on the circuit board, and after years of hot and cold cycles, the solder developed tiny cracks, resulting in a no-start situation because the fuel pump does not receive a signal turn on. The problem typically presents itself on very hot days, especially after the car has been recently run. This DIY shows how to repair the main relay in as little as 30 minutes. Even if your car has yet to show the symptoms, it is so easy to do, I would recommend it as a preventative measure.
Tools:
Phillips Screwdriver
Soldering Iron
Solder
1. First, remove the two lower panel screws and disconnect all four electrical connectors.
2. Remove the two vent screws. The main relay can now be seen by looking straight up around the location of the clutch pedal (this is even easier if you have an auto).
3. This is the main relay. Remove the electrical connector. Next is the hardest part because of the location of the relay but is so much easier thanks to KAHRuzer's suggestion to remove the innards instead of the entire main relay itself. The innards are held in to the outer black case by two tabs. Press back the unseen tab and pull down on the brown part of the main relay. Now do the same with the other tab and pull the brown innards out of the case. This takes a little patience but is so much easier than finding a way to get to the screw that's on top of the main relay's black case.
4. These are the "innards" of the relay and the solder tools you'll need. If you look very closely, you'll see some minuscule cracks in the solder, especially around the connections that have very little solder to begin with (http://techauto.te.funpic.org/images...ydryjoint.jpg). I have very little soldering experience (I just bought my first solder iron for this task... $13.99 at Home Depot) but this board was very easy to solder with a little patience. Simply add solder to all the connections that appear to need it (I added to 10-15 of the connections)
5. Here is the repaired relay. Installation is very simple and is the reverse of removal.
Let me know if you have any questions!
pacallen is offline
Old 07-13-08, 06:46 PM   #2 (permalink)
Legend V6's Avatar
Car 1: 1988 Acura Legend V6L
Smile
nice! i did the same but i removed all the old solder
Only mod was engine swap with a JDM engine
Legend V6 is offline
Old 07-13-08, 07:12 PM   #3 (permalink)
Yeah, I suppose that would be the proper way to do it but I didn't have a solder remover tool. However, the old solder melted and combined with the new solder to seal up any cracks.
pacallen is offline
Old 07-29-08, 06:04 PM   #4 (permalink)
Car 1: 03 Mini Cooper
Car 2: 04 Chevy Suburban
Car 3: 87 Acura Legend 2.5L
Excellent Thread. It should be in the G1 DIY section. Nice pics. Thanks
xbritt is offline
Old 07-29-08, 10:14 PM   #5 (permalink)
acuralegend<period>org
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Car 3: '03 Infiniti I35
Actually it already is
The PEOPLE make the community...NOT the URL!
sam o nela is offline
Old 07-30-08, 03:25 PM   #6 (permalink)
I'm clicking on the DIY link on the top and it says there are no DIYs. Is there another DIY section?
xbritt is offline
Old 07-30-08, 05:46 PM   #7 (permalink)
G1 FAQ
Old 09-05-08, 08:52 PM   #8 (permalink)
acura-legend.commie
tubadude's Avatar
Car 1: 1990 Legend Sedan L totaled :(
Car 2: 1987 Legend Sedan
Car 3: 95 Land Rover Disco
is this from the legend? mine has an air duct going right over/under it.
tubadude is offline
Old 09-05-08, 11:43 PM   #9 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Look at pic #2.
18" Limited 341 Chrome Rims/\Matador Red Paint/\Weapon R - Secret Weapon Intake/\LED Bright White Dash Lights/\Kenwood KDC-X590 Excelon Mp3 Deck/\Ford Taurus Coin/Cup Holder/\2 12" Kickers/\1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp/\2 Rockford Fosgate Capacitors/\Power Acoustic Capacitor/\Clear Rear Turn Signal/\Reverse Glow Gauges/\Swapped 88' Headlights to 89'-90'/\Swapped 88' seats to 89'/\JDM Rear Chrome Trim/\JDM Clear Corner/\JDM Power Folding-Heated Mirrors/\Stromung Muffler
l4zy415 is offline
Old 09-06-08, 12:22 AM   #10 (permalink)
acura-legend.commie
tubadude's Avatar
^toshay. i didnt remove mine. not really needed for access. just made it a tad harder to find.
tubadude is offline
Old 01-17-09, 08:54 PM   #11 (permalink)
Car 1: 2000 Hyundai Accent
Car 2: 1989 Honda Legend
I dont suppose any one has a clear picture of the writing on the black plastic relay cover?
The legend at the wreckers near me is missing its main relay, and i want to see if i can find a replacement one form another honda of similar vintage (maybe a prelude).
scythe is offline
Old 01-17-09, 09:31 PM   #12 (permalink)
Legend driver
90Legend L's Avatar
Car 1: 1990 Legend L Sedan
Car 2: 2000 Accord
Car 3: 2005 Odyssey
I think the part you need is a 7-pin Mitsuba RZ-0063 main relay.
1990 Legend L Sedan
Auto trans; 186k miles; Bone stock
Bahama Gold Metallic paint
Factory trunk spoiler and sunroof air dam
Optional factory wheels
Daily driver (60 mi/day); Restoration in progress
90Legend L is offline
Old 01-17-09, 09:39 PM   #13 (permalink)
l4zy415's Avatar
I think all Honda and Acura use the same Main Relay.
l4zy415 is offline
Old 01-17-09, 10:52 PM   #14 (permalink)
when i was at the wrecker i pulled a main relay from an 88-89 honda prelude (just in case).
Not sure if it will work now tho.
Its a:
"MITSUBA
RELAY ASS'Y MAIN
RZ-0081 12V
japan"
scythe is offline
Old 01-18-09, 02:57 PM   #15 (permalink)
Mabuhay...
pnoye2's Avatar
Its a:
"MITSUBA
RELAY ASS'Y MAIN
RZ-0081 12V
japan"
These main relays Honda utilize have different RZ #'s... it should work just fine!
Judge Judy to prostitute: So when did you realize you were raped?!?
Prostitute wiping away tears: When the cheque bounced!?!
Tony (BDAZZGI) auto repair shop!
pnoye2 is offline
Powered by vBulletin®. Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
