negative battery terminal gets hot - The Acura Legend & Acura RL Forum
Old 07-10-11, 02:31 PM   #1 (permalink)
Car 1: Acura legend
hi i have an acura legend 89... my negative battery cable gets hot.. it cranks but it wont start.. i changed the plugs and wires with new ones. but still nothing.. help,please.
outlaws is offline   Reply With Quote
Old 07-10-11, 04:07 PM   #2 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
Welcome to the forum, I'd say your main relay is bad. The draw put on the starting system from trying to crank for longer than 5-10 seconds will cause the wires to get hot from the amp draw required to turn over the engine.
The battery will also die if you continue to constantly turn it over.
Old 07-11-11, 01:29 PM   #3 (permalink)
Car 1: Acura legend
thanks for the help.. i already took the main relay off but i got to go to junkyard to get a used 1..
Old 07-11-11, 02:08 PM   #4 (permalink)
OrangeGen1's Avatar
Car 1: 1987 legend
Car 2: 1976 AMC Gremlin
Car 3: 1991 legend ls
mine did that cause the terminals wasnt tight.
OrangeGen1 is offline   Reply With Quote
Old 07-11-11, 02:19 PM   #5 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Ya either your terminals aren't clean or tighten enough. For the main relay, just have it re-soldered, you'll save money on doing that.
Old 07-11-11, 11:41 PM   #6 (permalink)
BIGBOY's Avatar
your welcome, keep us posted.
Old 07-15-11, 10:53 AM   #7 (permalink)
Car 1: Acura legend
I got a few used relays from the junkyard of the same make and model but nothing... I tryed all three main relays.. Im going to c if i can get a new main relay.. Another thing too. Before this incident happened my starter went bad. So i got a used one. I tryed jumpstarting it by putting the + cable to the starter and the negative cable to a good ground. The + cable to the starter started throwing sparks. So im guessing the starter is bad.. Right?? Help
Old 07-15-11, 11:40 AM   #8 (permalink)
BIGBOY's Avatar
There's no way all of the relays are bad, I think you have a bad connection or the starter is garbage. I learned a long time ago that certain things should only be bought new: starters, alternators, master cylinders etc.
When buying stuff from a junk yard you never know what your getting.
Old 07-15-11, 01:29 PM   #9 (permalink)
Car 1: Acura legend
I was surprised too.. Ive spent 10 bucks on the starter and the main relays i just put in my pockects. So really i havent put alot money into it yet.. Im looking at prices for a new starter so i hope its not too expensive. I already ordered a new main relay. That was like 30 bucks.. I just hope its those two things. Im gonna buy new battery terminals and new ground wires.. So wish me luck.. Ill keep u posted.. Thanks for everthing budd..
Old 07-16-11, 06:28 PM   #10 (permalink)
Car 1: Acura legend
I just got my new starter and my new main relay... Its started right up.. Thanks big boy for the help.. If anymore problems occur ill keep u posted..
Old 07-16-11, 09:47 PM   #11 (permalink)
BIGBOY's Avatar
always glad to help man, I'm glad your back up and running.
