Overheating.... Or was it?
Did a complete coolant flush about 3 days ago, no problems at all afterwards. Today we warmed it up to go to Spokane, wasn't on near long enough to overheat, but the needle was in the red. But the over flow tank wasn't bubbling, and the cap wasn't all that hot. I checked around on here to see what the problem may be, found out that I didn't have the bleeder open when I filled it after the flush (stupid me). Well I let it ran, and slowly bled the system to where the needle went down.
Drove to Spokane, was all fine and dandy, pulled into the Costco parking lot, then all of a sudden it was pegged again. Still wasn't bubbling. Did what I did at home, added water, bled it again, etc. Drove to Northtown, was all fine, when I was parked, I looked down.... Pegged. Came out after like 30 mins, was still 'hot' on the needle, but still wasn't bubbling. Well this went on all the way home, so I had the heater on full, pulled into a gas station, checked it, and the rad cap was COOL. Not like cold, it was warm, but less than normal operating temperatures. From there til home the needle was almost at peak, but it never moved an inch. At home I checked again, no bubbling, and cap was normal temp. My only guess since the thermostat is maybe a month old, is that the 18 year old temperature sensor went out. Sorry for the long write up, just thought it could shed some light on the situation. Thoughts? Thank you. ![]()
~Napoleon -"Shocks, pegs..........Lucky!" http://memimage.cardomain.net/member.../2307691_1.jpg http://www.cardomain.com/ride/2307691 |
FRISCO LEGEND BABY!!!!
NEVER ADD WATER!!! Thats gonna create corrosion. Check if your fans kick in on normal temp. If both fans work and the needle is hitting the H mark, check the radiator hoses. Feel them if they are hot/warm/cold. If the upper hose is hot and the lower hose is cold/warm, then that means the thermostat is stuck. Keep us posted, hope you find the solution.
My Legend Is Rising Back From Hell!!!! BEWARE. ![]() 18" Limited 341 Chrome Rims Candy Red Paint Weapon R - Secret Weapon Intake LED Bright White Dash Lights/Floor Kenwood KDC-X590 Excelon Mp3 Deck Ford Taurus Coin/Cup Holder 2 12" Kickers 1200 Watt Sony XM-2200GTX 2-Channel Xplode Amp 2 Rockford fosgate Capacitor Power Acoustic Capacitor Clear Rear Turn Signal More to come............... |
#5 (permalink) | |
I already drained the water out. We bought some Factory Honda coolant yesterday. ![]()
Update:
Took out block drainplug, and ran heater till everything was out. Added Honda coolant with bleeder valve open till nice smooth stream came out. Closed valve, let engine get to normal operation tempature... now the guage is staying where it should be, dunno why... oh well. Opened the bleeder some, let a bit more air out till stead stream, closed it. Drive the car around for about 3 miles, with spirited driving, and no rise, just normal. Checked lower radiator hose, and it's warm also. Note: Lower radiator hose doesn't warm up as fast as top. (that normal?) Regardless, heater works, temp needle is where it should be, car isn't overheating. No coolant leaks, nothing. Weird ass cars, haha.
Ya its normal. The upper hose will heat up quicker than the lower one. I'm glad it stopped overheating.
Gangstar* User
s;djfl
Same problem, even with a coolant change, every once in while the needle will jump with no lag just BAM!!
to the H mark i think its the pig tail but i replaced it with one off of another motor, but who knows it could be bad too haha Newho Glad to hear yours is not overheating !!!! |
His name is Robert Palson
Are you guys bleeding with the heater on full blast? It also might help to have the car parked on an incline (ie facing up a hill, or the front wheels on ramps or even 2x4s). This will help force any trapped air to the bleeder and to the top of the radiator with the cap off....
#11 (permalink) | |
I ran the car with the system full of Blue, until I saw a steady stream of Blue through the bleeder, which meant all old was out 100%. All is fine now. ![]() 236K+ and still going strong and will do 140+. ![]()
Ahh, and our gaskets are borderline blown. Were leaking in some spots, but the main reason for the flush was that we used some of the K&W Nanotechnology Head Gasket & Block Repair. Let me say too, it's working.
#14 (permalink) |
Matthew is THE USER!
Yea thats what i thought... my temp reads like 75% to H but i dont think its actually over heating at all.. .. wierd cars. im chandging my thermostat and bleeding the system tonight .. i hope it'll fix the problem... there is prolly air in the system.. from when i filled up not too long ago.. it was an emergency fill up of antifreeze so .. i did a shabby job
#15 (permalink) |
Good luck to all !!!!!
[url]http://www.myspace.com/jinxednco Car List 81 CJ7 restoring 93 Ac Legend Sedan (starting fresh headed for VIP) 93 Ac Legend Sedan (Undecided) 70 Olds Cutlass Supreme w/ the 455&turbo400trans 91 Nissan 240sx 5spd. (wifeys Whip) she wants to learn to drift? [color="Blue"][u]92 Ac Legend Coupe (Daily Driver)TypeII Intake+Injectors and rail+Throttle Body, EGR Blocked off, Venom 400, Rebuilt at 130,000 due 2 BHG, custom grille, Weapon R Intake and CAB, Factory option upgraded wheels,[/COLOR] |
