oxygen sensor - The Acura Legend & Acura RL Forum
Old 01-09-11, 12:30 PM   #1 (permalink)
Car 1: 1990 acura legend L
oxygen sensor
Hey guys, wondering if anyone has any idea why this happened. i have a 90 legend L and it was running fine but It was throwing a 1 code, front oxygen sensor. So i put in a new bosch oem replacement sensor and fired it up. Now its revving real high and throwing an 8 code. TDC sensor. Now i just replaced that about 2 years ago, and it wasnt acting up until the oxygen sensor got replaced so im pretty sure thats not the problem.
Any thoughts what it could be??
I appreciate any advice!!
rich06 is offline   Reply With Quote
Old 01-09-11, 04:42 PM   #2 (permalink)
test TDC sensor for the code and see if adjusting the throttle will change higher revs. the idle could have been adjusted for the bad O2 sensor.
0(#^ is offline   Reply With Quote
Old 01-09-11, 07:00 PM   #3 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Bosch O2 sensors are garbage for the G1. When you replaced the O2, did you reset the ECU by removing the alternator fuse in the Engine Bay?
Old 01-09-11, 09:44 PM   #4 (permalink)
im not sure
what u mean by testing the TDC sensor. I put it in 2 years ago and never had a problem until after i replaced the 02 and started it up.
I did pull the alt fuse but i could try disconnecting the bat maybe that will work
Old 01-09-11, 09:46 PM   #5 (permalink)
check engine light now on as well...wasnt on before the 02 change
Old 01-10-11, 02:16 AM   #6 (permalink)
l4zy415's Avatar
Check your ECU again for codes.
Old 01-10-11, 03:20 PM   #7 (permalink)
what i mean is get the FSM and test the sensor.
then try adjusting your idle screw.
Old 01-10-11, 09:02 PM   #8 (permalink)
ECU still 8 flashes since changing the O2 sensor. Engine light on too. Running high idle then dies down, then revs up high again and keeps repeating.
This thing ran great before the O2 change, just changed it to pass smog and only because one flash (O2 sensor) on ECU wouldnt let me pass. TDC sensor only 2 years old, working great...definately shouldnt have gone bad just like that because i changed the O2 sensor...
Just weird man
Old 01-11-11, 03:15 AM   #9 (permalink)
l4zy415's Avatar
Might want to change the O2 to NGK. For the code 8, make sure the plug to the dizzy is plugged in, or else you'll just have to end up replacing it again.
Old 01-14-11, 10:49 PM   #10 (permalink)
I ordered up a NGK O2. What the hell's a dizzy? distributer maybe? never heard that before...anyway ill post back when i get the new 02 in...thanks for your help
Old 01-15-11, 04:05 AM   #11 (permalink)
GI Joe Scuba Sweep Champion
Ophidian's Avatar
Car 1: 90 LS Coupe 5speed
iTrader Score: 11 reviews
Dizzy = distributor, yes.
Ophidian is offline   Reply With Quote
Old 01-18-11, 05:52 PM   #12 (permalink)
Car 1: 1990 Acura Legend LS Sedan
Car 2: 1990 Acura Legend LS
Car 3: 1982 DeLorean
Can someone please post pictures of where the O2 sensors are located? I can't find them on the workshop manual as the manuals provided online seem incomplete.
Thanks,
T.
cleandmc is offline   Reply With Quote
Old 01-18-11, 07:02 PM   #13 (permalink)
l4zy415's Avatar
There are 2 sensors, one in the front and rear. If you look at the header, follow it down till you see a single wire that goes to the O2 sensor.
Old 01-25-11, 09:56 PM   #14 (permalink)
Hey you guys... i replaced the sensor with the one you suggested. The revving up and down is gone now and so are the lights on the computer. But its still staying high in park all the time...about 1500rpm warmed up, about 1100-1200 in gear and sitting still.
Ive never adjusted the idle on it and have had the car since new. Could it have adjusted it self due to the bad 02?
Any ideas would be geat... and where the heck is the idle adjustment???
Thanks
