Painted Calipers and SS Brake Lines Install
Note: Was looking through the new "archive" thread and realized that I posted this at acuraworld.com, but never here...I think the forum was having issues then. So either way...here is a copy for the A-L crowd.
Hey guys, Installed my Stainless Steel Brake lines this weekend. Also took the opportunity to Paint the calipers since the hoses were removed. Painted them Ford blue…didn’t want to go red like everyone else…and wanted to pay tribute to my Bronco. Lines were acquired from www.kingmotorsports.com for $112.06 Part number AC 910. These are the SS lines that are encapsulated in Clear PVC. Made by Techna-fit. It’s a six piece set with a single line for each front brake and a two piece line for each rear brake. Installation went smoothly…took about a day since I had to wait for layers of paint to dry. Paint was hi temp engine enamel. Used Brake cleaner and a wire brush to clean prior to painting. Rolled up bits of newspaper was used to keep paint out of internals and bolt hole threads. Bled them today and the feel is much firmer on the lower 2/3rds of the pedal stroke. Here are some pics… Later Parts removed and disassembled. ![]() Comparison of brake lines…front old and new. ![]() Painting ![]() Painted caliper with paint removed from banjo bolt “sealing area” paint removed with fine wire brush on a dremel. ![]() Front completed project…slotted/drilled rotors installed about 6 months ago. ![]() Rear completed project. ![]()
1990 LS coupe - 5 speed - 160,000 miles ram CAI - grounding wires - B&M FPR and gauge D/S rotors - ceramic pads - SS brake lines - driving lights alpine HU - infinity components - profile 4ch amp "My other love is a Ford Bronco" |
I do remember this. Be aware....that another member talked about the stainless brake lines and how they were prone to failure !
yeah...i remember greylegend saying something about that...mine are fine so far...knock on wood
Mr. X (aka #5)
Car 1: 1989 White Coupe (dead) my baby! Car 2: 1987 Brown Coupe L Car 3: 1994 Accord Sedan EX iTrader: (3)
don't you have stock rims? if so, how well can you see the painted calipers through the rims? and why not drilled and slotted on the back?
Bitter Old Man
The technique for fastening the fitting to the hose is what makes some prone to failure. Supposedly there are D.O.T.-certified hoses that should be just as long-lasting as the standard rubber hoses.
The braided lines on my Sentra have been there since 1997. No problems yet, though the car has hardly been driven since 2002.
Bruce in Houston 2007 Mazda MX-5 Touring 2002 Dodge Dakota QC tow beast, stock! 1998 Suzuki Bandit 1200S w/ $tuff 1994 Nissan Sentra SE-R w/ $tuff converting to ITA 1990 Acura Legend LS sedan leaving the stable |
#7 (permalink) | |
![]() The rear rotors weren't worn out when I replaced the fronts with the D/S. I also think that D/S is less important in the rear than in the front as far as performance is concerned.
here is another shot where you can see the blue...it's subtle
5 Speed Operator
is there a noticable increase in stopping power with the drilled and slotted rotors? I was thinking of upgrading the front brakes on my car since i have never been satisfied with how they perform. Are you running ceramic pads as well?
Originally Posted by Jrod@Buschur@ evowned.com DSM's..... turning the everyday Joe into a tool throwing, foul mouthed, alcoholic since 1989. 1990 Legend LS Sedan 5 spd 1989 Legend LS Sedan Auto(For Parts, Bad Trans) G1 FAQ If Your Legend Stalls or Doesnt Start, CLICK HERE |
#11 (permalink) | |
rotors were 75 off ebay...was able to pick them up locally to save on shipping. Pads were 40 bucks from here
brake lines I described above...112 from www.kingmotorsports.com you can find some good deals on ebay...persistence
